Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Mon Jul 19, 2010 12:15 pm Post subject: Turbo nozzle manifold |
With the Sam James cowl and plenum, I am using turbo nozzles (Which Aerosport Power was gracious enough to do the mod for me). I have the nozzles, but does anyone know where to get the manifold, or have a parts list? I scoured Deems site and got lots of good pics of what it should look like, just don't know where to get the stuff to install, or make myself.
Eric Kallio
Still fitting cowling and plenum.
Deems Davis
Posted: Mon Jul 19, 2010 3:36 pm Post subject: Turbo nozzle manifold |
Eric you can get the turbo rails from Don (at)airflow performance.
Deems
On Jul 19, 2010, at 1:15 PM, "Eric_Kallio" <scout019(at)msn.com> wrote:
Eric Kallio
http://forums.matronics.com/viewtopic.php?p=305475#305475
Robin(at)PaintTheWeb.com Guest
Posted: Mon Jul 19, 2010 3:50 pm Post subject: Turbo nozzle manifold |
Deems did his w/o a manifold. You may want to consider his approach which
will save you much weight (Manifold is heavy) plus I have my Manifold pick
up in the air box which is correct for flying but may be an issue during
ground ops where you may actually crate a slight vacuum in the system.
My condolences on your James cowl.
Robin
Dual James Cowl Owner
