Spark plugs & Electronic Ignition
bcondrey
PostPosted: Wed Aug 04, 2010 6:44 pm    Post subject: Spark plugs & Electronic Ignition Reply with quote
I've got 2 Plasma III ignitions and have had zero issues in 2+ years with the standard Denso plugs.
RV-10 N442PM
Tim Olson
PostPosted: Wed Aug 04, 2010 7:24 pm    Post subject: Spark plugs & Electronic Ignition Reply with quote
Same here with 640+ hrs. Plan to replace the plugs at around 100hrs (conservative) to 200hrs (far best case). At 200 they'll be plenty worn. I find 150 or so is maybe perfect. So when you buy them, stock up.
They don't foul at all on top. Can't tell you about if you use them on bottom, but I'd imagine they'd be the same, if you have electric ignition there too.
On Aug 4, 2010, at 9:43 PM, "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com> wrote:
RV-10 N442PM
robertbrunk(at)me.com
PostPosted: Wed Aug 04, 2010 7:28 pm    Post subject: Spark plugs & Electronic Ignition Reply with quote
I use auto plugs. They work fine.
Robert Brunkenhoefer
Sent from my Apple iPad
On Aug 4, 2010, at 9:38 PM, rvdave <davidbf(at)centurytel.net> wrote:
Wondering for those using electronic ignition if you are using automotive or aviation plugs? Was determining factor cost vs. reliability? I'm getting ready to order Plasma III system and trying to decide between the two types. Are automotive more prone to fouling in lower positions than aviation? Is there no difference--not a factor?
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=307575#307575
dmaib(at)mac.com
PostPosted: Thu Aug 05, 2010 5:10 am    Post subject: Spark plugs & Electronic Ignition Reply with quote
Hi Dave,
I have a Plasma III running auto plugs on the top and a Slick mag
running aviation plugs on the bottom. The auto plugs work great and I
have had no issues. I think bottom plugs usually foul more than top
plugs. I know some operators have installed their electronic system
to run the lower plugs with success. It is just easier to mount the
electronic hardware on top of the engine I think is the reason most
use the Plasma on top.
David Maib
40559
Flying
On Aug 4, 2010, at 11:27 PM, Robert Brunkenhoefer wrote:
<robertbrunk(at)me.com>
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
martinaerodrome(at)gmail.
PostPosted: Thu Aug 05, 2010 5:21 am    Post subject: Spark plugs & Electronic Ignition Reply with quote
Dave,
I now have over 1000 hours on my plasma ignition system.  I tried every kind of sparkplug and have obtained the best results with Nipon Denso  GPR27U spark plugs.  Aviation spark plugs did not work well .  You can get the sparkplug adapter bushinngs from Klaus Savior at lightspeed.
I also obtained the longest service life  from MSD racinng coils and sparkplug wire.  Call me (at) 920 619 6968  for further details.
Dick Martin
RV8 N233M
the fast one
On Wed, Aug 4, 2010 at 9:38 PM, rvdave <davidbf(at)centurytel.net (davidbf(at)centurytel.net)> wrote:
[quote]--> RV10-List message posted by: "rvdave" <davidbf(at)centurytel.net (davidbf(at)centurytel.net)>
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
       - The RV10-List Email Forum -
and much much more:
or?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
partner14
PostPosted: Thu Aug 05, 2010 5:23 am    Post subject: Spark plugs & Electronic Ignition Reply with quote
No issues with auto plugs, top or bottom.... fouling? Ain't gonna happen. This system has so much spark, it cleans them right up.
Don dual electronic, and not sorry yet McDonald
--- On Wed, 8/4/10, rvdave <davidbf(at)centurytel.net> wrote:
Subject: Spark plugs & Electronic Ignition
Date: Wednesday, August 4, 2010, 7:38 PM
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
r?RV10-List" target=_blank>http://www.matronics.com/Navigator?RV10-Listhttp://www.matronics.com/contr================
Don A. McDonald
40636
Kelly McMullen
PostPosted: Thu Aug 05, 2010 5:54 am    Post subject: Spark plugs & Electronic Ignition Reply with quote
Anyone placing any bets on Emag, now that their Osh material lowered(?) the release date to a few months?
On Thu, Aug 5, 2010 at 6:22 AM, Don McDonald <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
[quote] No issues with auto plugs, top or bottom..... fouling?   Ain't gonna happen.  This system has so much spark, it cleans them right up.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
hotwheels
PostPosted: Thu Aug 05, 2010 6:32 am    Post subject: Re: Spark plugs & Electronic Ignition Reply with quote
Lightspeed Plasma III come with:
Denso U-Groove, P/N W24EMR-C 4198
Vans Airforce thread...
http://www.vansairforce.com/community/showthread.php?t=13254&highlight=ngk
Jay
hotwheels
PostPosted: Thu Aug 05, 2010 6:47 am    Post subject: Re: Spark plugs & Electronic Ignition Reply with quote
$8.30 each here:
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=9871
Your mileage varies here:
http://www.lightspeedengineering.com/Products/Sparkplugs.htm
Jay
coop85(at)verizon.net
PostPosted: Thu Aug 05, 2010 9:00 am    Post subject: Spark plugs & Electronic Ignition Reply with quote
$4.88 at Amazon:
http://www.amazon.com/Denso-W24EMRC-Performance-Spark-Plug/dp/B002FOOAB4/ref
=sr_1_1?ie=UTF8&s=automotive&qid=1281027412&sr=8-1
Here's a thread from Vansairforce.net regarding NGK plugs as well:
Marcus
jfrjr(at)roadrunner.com
PostPosted: Thu Aug 05, 2010 2:23 pm    Post subject: Spark plugs & Electronic Ignition Reply with quote
For those who are using the denso plugs that have the 3 prong ground, what tool do you use to set the gaps? I can't get my standard single ground tool to fit the 3 ground tabs. Jay Rowe #40301
On Aug 5, 2010, at 10:47 AM, "jayb" <jaybrinkmeyer(at)yahoo.com> wrote:
$8.30 each here:
Jay
40301
http://forums.matronics.com/viewtopic.php?p=307635#307635
