		Tom Jones
  Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
				 Posted: Thu Aug 05, 2010 3:12 pm    Post subject: Key West Voltage Regulator |
				This is on a 503 rotax.
 My Tympanium voltage regulator went bad so I replaced it with a Key West regulator.  I had the 12VDC output wire from the old tympanium regulator connected to the starter side of the master contactor so This is where I connected the Key West 12V DC output wire.  My Hobbs meter is also connected to the same terminal on the starter side of the master contactor.
 I noticed my Hobbs kept running when the master is off.  I disconnected all the wires on the Key west and checked for voltage.  There is 4.3 volts DC between the key west ground terminal and 12V DC output terminal.  Is it normal to have some residual voltage in the Key west?
 I guess I need to move the output wire from the key west regulator to the battery + terminal so that 4.3 volts doesn't touch the hobbs wire??  Am I on the right track?
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
		brubakermal(at)yahoo.com Guest
				 Posted: Thu Aug 05, 2010 8:20 pm    Post subject: Key West Voltage Regulator |
				mine did samething simular but the hobs just ran down to stop maybe 8 seconds  it seems yours sounds like it is dooing something different
 Malcolm Brubaker
 Michigan Sport
 Pilot Repair
 LSRM-A, PPC, WS
 (989)513-3022
 Sent: Thu, August 5, 2010 7:12:20 PM
 Subject: Key West Voltage Regulator
 --> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)>
 Tom Jones
 Classic IV
 Ellensburg, WA
 http://forums.matronics.com/viewtopic.php?p=307710#307710
		Tom Jones
				 Posted: Fri Aug 06, 2010 6:18 am    Post subject: Re: Key West Voltage Regulator |
				Thanks Malcolm,  After reading your post this AM I went out and hooked everything back up and turned the master switch on for a minute and then off.  My multimeter showed 4.3 volts on the Key west out put terminal and  the Hobbs continued to run for 60 seconds then stopped.  I then checked the out put terminal and it was down to 2.5 volts and dropping.
 I think I will leave it wired as is.  I like the voltage regulator to be off line with the master off.  I don't know why, it just seems like a good thing to me.
Classic IV
Ellensburg, WA |
