mouser
Joined: 02 Feb 2010 Posts: 14 Location: Los Alamos, NM
Posted: Fri Aug 06, 2010 6:54 am Post subject: Elevator Trim Bellcrank Binding |
I've got my elevator trim bellcrank parts all fabricated and primed, and I've test-assembled the F-1095 assembly and all its accessories. There is definitely some friction when I rotate the F-1095B bellcrank. It's not bad, and I bet the servo will be able to rotate it... but the instructions say to make sure that it rotates "freely." Has your experience been that this piece will rotate more or less free of friction? I've got only the -L sized washers in there and can't find a thinner substitute... Any advice on how to grind them down, or what to do to alleviate the friction?
_________________ RV-10 #40988
http://mouser.org/projects/rv-10/
KLAM |
40950(at)rv10.net Guest
Posted: Fri Aug 06, 2010 3:24 pm Post subject: Elevator Trim Bellcrank Binding |
Had similar problems. Here's what I did:
http://mykitlog.com/users/display_log.php?user=tkoelzer&project=714&category=0&log=98935&row=7
Tom Koelzer
#40950 Wings LB
On Aug 6, 2010, at 9:54 AM, mouser wrote:
RV-10 #40988
KLAM
http://forums.matronics.com/viewtopic.php?p=307776#307776
