Acceptable horizontal stabilizer adjustment
Goto page Previous  1, 2
PostPosted: Mon Aug 09, 2010 1:03 pm    Post subject: Acceptable horizontal stabilizer adjustment Reply with quote
John- I think it might have been Larry Cottrel that did the video. It
does show an amazing amount of tail twisting, and I think it's the boom.
Or, it might be some kind of illusion. It is a very impressive piece of
footage.
Bill Sullivan
Windsor Locks, Ct.
FS 447
Bill S/Gang:
Very familiar with Larry C's FSII. Flown it, and helped a little bit when
it came to fine tuning it.
I still believe most tail section movement is caused by loose tail wires.
There is a lot of flex in the tailboom tube, but it won't flex unless
something else ask it to flex, like a tailsection that is dancing around
back there.
Next time you fly your Kolb, fly it with loose tail wires, and see how it
performs.
Then, tighten them down really good, then tighten some more. Go fly, check
the tail, and see if it hasn't been tamed a bit.
That is the way it works for me.
pcarillonsr(at)neo.rr.com
PostPosted: Mon Aug 09, 2010 2:30 pm    Post subject: Acceptable horizontal stabilizer adjustment Reply with quote
boom. Or, it might be some kind of illusion. It is a very impressive
piece of footage.
Bill Sullivan
Windsor Locks, Ct.
FS 447
Bill and gang :
That video of the tail shake was by Chris Ambrose, Ces308
Goto YouTube and type in Ces308 and you will get his videos, There are a
couple showing the rear view. One is shot thru his plastic enclosure
which makes it look like the tail is really shaking bad. Another video
is taken without the enclosure, looks better.
Jack Carillon FSII Akron, oh.
zharvey(at)bentoncountyca
PostPosted: Mon Aug 09, 2010 5:21 pm    Post subject: Acceptable horizontal stabilizer adjustment Reply with quote
John, when you say "tail wires" are you talking about the stabilizer wires?
I'm finding I am having issues with needing to keep left rudder all the time in straight and level flight with my KXP. Other than a trim tab, anyone have any ideas on correcting?
Gene
PostPosted: Mon Aug 09, 2010 5:34 pm    Post subject: Acceptable horizontal stabilizer adjustment Reply with quote
Gene
Gene/Gang:
I have found, since I started building and flying Kolbs, a rudder trim tab works best.
Your mileage may vary.
hauck's holler, alabama
PostPosted: Mon Aug 09, 2010 5:39 pm    Post subject: Acceptable horizontal stabilizer adjustment Reply with quote
John, any chance you can send me a photo. I don't wish to try to reinvent the wheel. Do you use fixed or adjustable?
Gene
PostPosted: Mon Aug 09, 2010 5:49 pm    Post subject: Acceptable horizontal stabilizer adjustment Reply with quote
Sorry, Gene, forgot to answer your first question.
I am talking about the tail wire bracing.
Guess I was so excited about being able to climb up on a 60 year old McCormick W-9, fire it off after turning one cylinder, first time it has cranked in more than three months. I got the airstrip cut, but the grass was so thick I had to pull the 6' bush hog in 3d gear most of the time and 2d when it really got thick. This old McCormick has a lot of guts and normally cut the airstrip in 4th, along with most of the pastures.
First time I have been on a tractor since I crashed my MTB. I could fly if I could get the mkIII out of the hanger, but I need a medical and a BFR. Not going to take a chance breaking my airplane until I am legal once again.
Depending on my old flight surgeon, I can get a medical if he will give me one before I start walking without the walker or a cane. Got somebody lined up to give me a BFR soon as I am ready, after the medical.
Life is good!
PostPosted: Mon Aug 09, 2010 5:53 pm    Post subject: Acceptable horizontal stabilizer adjustment Reply with quote
Let me look on my computer. I am home, hauck's holler, for a few days.
The rudder trim tab we use on the mkIII's are about twice as large as you would need on a Firestar.
Using .025" aluminum would make a nice easily adjustable tab.
If I can't find a photo, hopefully, someone else on the list with a Firestar may be able to provide a copy.
john
Gene
[quote] [b]
rickofudall
PostPosted: Mon Aug 09, 2010 7:09 pm    Post subject: Acceptable horizontal stabilizer adjustment Reply with quote
On my Mk III what causes the movement is rudder flutter pure and simple. If I take my feet off the rudder peddles the tail starts to shake with increasing amplitude. It's why after 150 + hours Zulu Delta is still in phase 1 testing and my flying is limited to my test area given me by my FSDO. The cure, for me is to remove all the dead weight from the improperly applied Aerothane by re-covering the empenage and balancing the surfaces. Until then I cannot in good conscience sign off the logbook that the aircraft has no dangerous tendencies. My experiment, my solution.
There's a part of me that would love to put a Vee tail on the airplane with full flying ruddervators, but that's another experiment for another day.
Rick Girard
On Mon, Aug 9, 2010 at 3:39 PM, william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)> wrote:
[quote]   John- I think it might have been Larry Cottrel that did the video.  It does show an amazing amount of tail twisting, and I think it's the boom.  Or, it might be some kind of illusion.  It is a very impressive piece of footage.
                                                  Bill Sullivan
                                                  Windsor Locks, Ct.
                                                  FS 447
tp://forums.matronics.com
rickofudall
PostPosted: Mon Aug 09, 2010 7:41 pm    Post subject: Acceptable horizontal stabilizer adjustment Reply with quote
Chris, Use a plumb line, and a water level. You can level your plane within a gnat's posterior that way.Make a couple of stands with 1" X 2" wood. For a Kolb I'd make the vertical post at least 6' tall
But 50' of 1/4" vinyl tubing, hang from stands, fill with water mixed with red food coloring. The water in the two tubes will always be at the same level relative to each other. Measure from that.
If you need more than two references you can use plastic fuel line tees, or drip irrigation tees to add as many lines and stands as you think you need. As long as they are all connected all the levels in the vertical tubes will be the same.
Hang a plumb line from the ceiling of your hangar, make a stand like those for water level. Mearure from the plumb line to the rudder post, when the measurement is the same top and bottom of the post it's dead on vertical.
Rick Girard
On Mon, Aug 9, 2010 at 11:18 AM, chris davis <capedavis(at)yahoo.com (capedavis(at)yahoo.com)> wrote:
[quote] --> Kolb-List message posted by: chris davis <capedavis(at)yahoo.com (capedavis(at)yahoo.com)>
Chris , I think you have  your aircraft well within acceptable limits for the
speeds at which we fly , the 1.5 inch difference in your cables was most likely
the most out of whack measurement that you had and you fixed that ! With your
measurements within 1/8 inch and considering the fact that I never  had my tail
wires so tight that I couldn't move my horizontal stabilizer 1/8 inch up and
down I think you should be all right . just my 2 cents. Chris
 Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Richard Pike
PostPosted: Tue Aug 10, 2010 5:30 am    Post subject: Re: Acceptable horizontal stabilizer adjustment Reply with quote
[quote="rickofudall"]On my Mk III what causes the movement is rudder flutter pure and simple. If I take my feet off the rudder peddles the tail starts to shake with increasing amplitude. It's why after 150 + hours Zulu Delta is still in phase 1 testing and my flying is limited to my test area given me by my FSDO. The cure, for me is to remove all the dead weight from the improperly applied Aerothane by re-covering the empenage and balancing the surfaces. Until then I cannot in good conscience sign off the logbook that the aircraft has no dangerous tendencies. My experiment, my solution.
Rick Girard
A counterbalance on the rudder works just as well for the rudder as a counterbalance for the aileron works for the aileron. You mention lightening the surfaces and balancing them, that will help. I suspect that due to the prop pulsing against the rudder, that simply lightening the rudder without a counterbalance will not resolve the problem.
Richard Pike
MKIII N420P (420ldPoops)
rickofudall
PostPosted: Tue Aug 10, 2010 9:20 am    Post subject: Acceptable horizontal stabilizer adjustment Reply with quote
"by re-covering the empenage and balancing the surfaces." Richard, I believe that's what I said.
Rick
On Tue, Aug 10, 2010 at 8:30 AM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
[quote] --> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Rick Girard
Richard Pike
http://forums.matronics.com/viewtopic.php?p=308190#308190
le, List Admin.
Page 2 of 2
