Overhead Console Vents
n223rv(at)wolflakeairport
PostPosted: Tue Aug 10, 2010 10:38 am    Post subject: Overhead Console Vents Reply with quote
What is everyone using for overhead console vents, and are you happy with the vent quality? I see vents range from $59 to almost $200. I don't want to overpay, but I want a quality vent....
-Mike
aerosport1
PostPosted: Tue Aug 10, 2010 10:41 am    Post subject: Overhead Console Vents Reply with quote
Use the vents Stein air sells. They are worth the money and shut off tight.
Not the cheapest but are the best.
Geoff
Geoff Combs
President
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
rvdave
PostPosted: Tue Aug 10, 2010 5:48 pm    Post subject: Re: Overhead Console Vents Reply with quote
Which vents that Steinair sells will fit in the overhead console? There are 2 types, one that receives scat tube directly and one with a plenum. I'm not sure if the plenum will fit in the overhead space?
Dave Ford
Cadillac, MI
rleffler
PostPosted: Tue Aug 10, 2010 6:25 pm    Post subject: Overhead Console Vents Reply with quote
You answered your own question. With the overhead, the entire overhead is
pressurized and you don't need scat tube connected directly to the vents.
The smaller vent is the one you want. The smaller one is also what you'll
need if you have the Aerosport panel for the front vents too. The larger
vent is just too big for either location.
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
rvdave
PostPosted: Tue Aug 10, 2010 7:06 pm    Post subject: Re: Overhead Console Vents Reply with quote
Oh yea, that's right, thanks
Dave Ford
Cadillac, MI
