GROUND LOOPS
tim2542(at)sbcglobal.net
PostPosted: Tue Aug 10, 2010 8:20 am    Post subject: GROUND LOOPS Reply with quote
So I left my Aerolectric book at work and have a quick question.
Composite A/C, rear engine, Battery.
IIRC, I will need to run power and ground runs to the Strobe power pack, Fuel Pump and Nav lights, the grounds running all the way back up to the panel ground. I can’t just hit the local ground that is right there at the Battery near these components. Is this correct practice? I’d be tempted to use the Firewall ground for the NAV and Fuel pump.
(rnbraud(at)yahoo.com)
Thanks, Tim Andres
MauleDriver(at)nc.rr.com
PostPosted: Tue Aug 10, 2010 9:21 am    Post subject: GROUND LOOPS Reply with quote
If you just keep it going straight, no ground loops!
Mauledriver (sorry)
Fuel pump.
Thanks, Tim Andres
PostPosted: Tue Aug 10, 2010 1:01 pm    Post subject: GROUND LOOPS Reply with quote
These devices are neither potential antagonists
or victims. As shown in Z-15, they can be grounded
"locally" on a metal airplane. This translates
to "closest practical" locations on a plastic
airplane,
Bob . . . [quote][b]
tomcostanza
PostPosted: Wed Aug 11, 2010 2:33 am    Post subject: Re: GROUND LOOPS Reply with quote
Hey Bob,
Could you explain, or point me to an explanation of, what kinds of things qualify as antagonists? From your reply to this question, it's clear I don't understand.
Clear Skies,
Tom Costanza
-- in year 17 of a 3 year project
PostPosted: Wed Aug 11, 2010 7:59 am    Post subject: GROUND LOOPS Reply with quote
At 05:33 AM 8/11/2010, you wrote:
<Tom(at)CostanzaAndAssociates.com>
Hey Bob,
99% of the time, antagonists are generally those devices
which generate noise in the form of electrical "wiggles".
These include radios that are poorly shielded. Motors. Strobe
power supplies. Certainly alternators. Instruments with
poorly shielded/filtered LCD power supplies. Switchmode
power adapters common to many hand-held devices including
GPS, cellphones, PDA, MP3 players, etc.
There are some instances where non-wigglers like incandescent
landing lights, pitot heaters, nav lights, etc can influence
other systems . . . like the example I gave for poorly grounded
engine instruments being affected by variations in current
flowing through a crankcase-to-battery ground conductor.
Even if the device IS a potential antagonist (like a strobe
power supply), not carrying it's power ground back to a
single point does not represent a risk as long as POTENTIAL
victims do not share the same ground path.
This is discussed in some detail in chapter 16 of the
'Connection. In that work I attempt to explain that
potential victims and antagonists can and do coexist
in airplanes as long as you make sure there is no
PROPAGATION mode for the conveyance of malicious
energy between them. Breaking of propagation pathways
includes but is not limited to certain kinds of shielding,
filters, modification of design to reduce noise and
installation practices to eliminate shared ground paths.
I can tell you that airplanes like the Beechjet have
HUGE potential antagonists, and exceedingly vulnerable
victims that for the most part have worked side by side
for a long time. This is a design goal for every TC
aircraft and should be a goal for OBAM aircraft as well.
The vast majority of your potential victims reside on
the panel. Judicious attention to grounding at the
panel will greatly reduce potential for problems
no matter how your ground other accessories scattered
about the airplane.
tomcostanza
PostPosted: Thu Aug 12, 2010 3:52 am    Post subject: Re: GROUND LOOPS Reply with quote
Bob,
OK. Maybe I understood more than I thought. What you wrote in your reply to me, is what I thought was an antagonist (motor, strobe power supply). But in your earlier response to Tim (the one that confused me), you said a fuel pump (motor) and strobe power supply were not potential antagonists (hence my confusion). What am I missing?
IIRC, I will need to run power and ground runs to the Strobe power pack, Fuel Pump and Nav lights, the grounds running all the way back up to the panel ground. I can�t just hit the local ground that is right there at the Battery near these components. Is this correct practice? I�d be tempted to use the Firewall ground for the NAV and Fuel pump.
airplane,
Thanks again,
-Tom
Clear Skies,
Tom Costanza
PostPosted: Thu Aug 12, 2010 6:24 am    Post subject: GROUND LOOPS Reply with quote
Bob,
Sorry, they're not potential PROBLEMS . . . assuming that
the potential victims are corralled off on their own
ground system. After all the panel mounted stuff is
protected, you can do about anything you want elsewhere
on the airplane. While outlying devices ARE capable
of being antagonists, they are not potential victims
and will not interfere with each other. Let's hear
it for precise speech! Your diligence in the quest
is commendable.
