Vertex VXA700 information needed
rparigoris
PostPosted: Fri Jul 16, 2010 8:41 am    Post subject: Vertex VXA700 information needed Reply with quote
I am trying to hook up a Vertex VXA700 handheld as a second Com to my PS Engineering PSA4000 audio panel.
Here is link to owners manual (1.01MB):
http://www.vertexstandard.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=204&encProdID=CDA841ED5B9711A5833A60A9115F5EDE&DivisionID=2&isArchived=1
As per manual on page 65 I have a CT-96 headset cable. The problem is I want the audio panel to allow the Pilot and Co-Pilot PTT to transmit on Com 2 (Vertex) when I select Com 2.
Does anyone have a schematic how to wire the CT-96 headset cable to accomplish this task?
I do have as shown on page 65 the external PTT switch.
This is not a simple device that goes in series with the mic jack and pulls PTT wire to ground. It has two switches that I believe could be replicated with a relay that has the coil powered and could look for ground through the PTT pin of Com 2 on the PMA 4000. I think when the external PTT switch/es are pushed, it disables the handhelds internal mic while connecting to the mic on headset.
Vertex was not of much assistance. They sent over a Service manual and a diagram of CT-96, which have errors. When I asked another question that would have solved my issue, Vertex said they don't make the external PTT and couldn't help me any further.
Thx.
Ron Parigoris
rparigoris
PostPosted: Wed Aug 18, 2010 6:13 pm    Post subject: Re: Vertex VXA700 information needed Reply with quote
I wanted to share information I have about hooking up a handheld Vertex VXA700 to an audio panel since help form other sources seems to be in short order:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=81045
This is the cable for vertex that allows you to use an external PTT switch. You can select a higher resolution on top right of page.
Here is completed cable and schematic:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=81445
Ron Parigoris
PostPosted: Thu Aug 19, 2010 3:17 pm    Post subject: Vertex VXA700 information needed Reply with quote
At 09:13 PM 8/18/2010, you wrote:
<rparigor(at)suffolk.lib.ny.us>
Figured I share information I have about hooking up a handheld
This is cable that allows you to use an external PTT switch. You can
Ron, would you scan copies of your schematics
and send them to me? I'd be pleased to post them
to the website. I sucked your posted camera images
into PhotoShop but they were not sufficiently exposed
to pop out the linework.
A paper copy mailed to me or a scanned .jpg/.tiff/.etc
would be better.
ceengland(at)bellsouth.ne
PostPosted: Thu Aug 19, 2010 4:28 pm    Post subject: Vertex VXA700 information needed Reply with quote
On 8/19/2010 6:16 PM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> Figured I share information I have about hooking up a handheld Vertex
> short order:
would be better.
Did you try the higher res image? I couldn't see the small one, but the
hi res version was readable, at least on my screen.
PostPosted: Thu Aug 19, 2010 8:16 pm    Post subject: Vertex VXA700 information needed Reply with quote
At 07:15 PM 8/19/2010, you wrote:
<ceengland(at)bellsouth.net>
the hi res version was readable, at least on my screen.
Missed that. Thanks! I think it will work for
me. Will fiddle with it a bit in the morning.
rparigoris
PostPosted: Fri Aug 20, 2010 2:21 am    Post subject: Vertex VXA700 information needed Reply with quote
Hi BobIf the higher resolution is still unacceptable, let me know and I can e-mail you an even higher resolution photo.Ron Parigoris [quote][b]
sprocket(at)vx-aviation.c
PostPosted: Fri Aug 20, 2010 7:26 am    Post subject: Vertex VXA700 information needed Reply with quote
Hi Ron.
Comment 1: I would recommend a 1N4007 diode snubber across the relay coil
in your PTT circuit. I'm not sure of the internal circuitry to the PM4000,
but this should eliminate any problems.
Comment 2: This whole circuit should work without the relay, with direct
connections between the VXA700 and PM4000. Is there a reason that you added
the relay? I have a VXA700 connected to my audio system and have not
experienced any problems. Is there something I'm missing?
Thanks for sharing this.
Vern
Sent: Wednesday, August 18, 2010 7:13 PM
To: <aeroelectric-list(at)matronics.com>
Subject: Re: Vertex VXA700 information needed
short order:
Ron Parigoris
http://forums.matronics.com/viewtopic.php?p=309347#309347
Checked by AVG - www.avg.com
18:35:00
PostPosted: Fri Aug 20, 2010 9:55 am    Post subject: Vertex VXA700 information needed Reply with quote
At 05:19 AM 8/20/2010, you wrote:
Hi Bob
Ron Parigoris
I can get what I need from the photos.
Thanks!
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
rparigoris
PostPosted: Sat Aug 21, 2010 5:52 pm    Post subject: Re: Vertex VXA700 information needed Reply with quote
Hi Vern
We purchased an adapter cable and an external PTT switch when we purchased our VXA700.
We ohmed out the harness and it indeed has two separate switches, one connects mic high when you push PTT, and the other switch grounds PTT high.
I have a schematic for VXA 700 that Vertex support sent us, it does not include enough information to figure out why the harness would use two switches to do what they are doing.
After several calls and finally cornered the support guy, he bowed out by saying Vertex doesn't make the harness and can't comment on it. He said the VXA 700 is not intended to be hooked up to an audio panel.
I know that when we hook up the VXA 700 to our PMA4000 audio panel and use the harness I have with external PTT switch it works fine.
I talked to PS Engineering and told him I wanted to use the mini DPDT relay as you can see on the right side near coin on second pic I posted to replicate two mechanical switches. I asked him if he thought it was OK to supply power to the coil of relay and have PMA4000 do the grounding when I push the PTT that is located on sticks and he thought that would be fine.
Someone knows why my harness uses two separate switches to transmit. Vertex support does not know why. PS Engineering does not know why. I do not know why.
I do know that the two switch arrangement works fine. My partner is an EE and thinks it best we replicate what we do know. His gut feeling is leaving mic connected all the time may not be a good thing to do. Perhaps someone could speculate why they may do this? Built into unit is a speaker and mic.
Anyway there's our reasoning how and why we connected the four wire Vertex plug to our audio panel.
You mention it may be a good idea to install a diode across the relay coil. We already finished harness and it would be a big effort to open up harness and get close to relay to install diode.
You can see size of relay against a penny on the right side:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=81445&g2_imageViewsIndex=1
You can enlarge the pic to full size by selecting full size on top right of screen. The specifics are listed on schematic about the relay we are using. There is no mA draw of coil on information we have but it is not very much of a draw. Could get information off the data sheet.
My question to you is what potential problem or problems could be caused by not using a diode across the coil of this mini relay?
Do you think I should try harness as it is wired and if we experience a problem/s you describe, then install a diode?
Or perhaps go half way between the two and install a diode about 6" away from the relay? BTW we are supplying power to the relay coil through a #24 wire that is about 20" long.
I also have some snapjacks on hand if you think that a better choice.
Ron Parigoris
rickofudall
PostPosted: Sat Aug 21, 2010 7:16 pm    Post subject: Vertex VXA700 information needed Reply with quote
Ron, I don't know why either, exactly, except that the PTT switch that Icom sold me for my A22 is set up the same way with two switches. Somewhere I got the idea is that one switch is NC and the other is NO. The NC is connected to the transmitter, the NO to the reciever. When the button is just sitting there doin' nothin', the transmitter is grounded and the receiver is open. Push the switch and the opposite happens the receiver is grounded out and the transmitter is open. The idea is to prevent the receiver and the transmitter from forming a feedback loop.  Feel free to tell me I don't know what I'm talking about, there's a good chance I don't, but I seem to remember someone on this forum 'splainin' it that way somewhere in the distant past.Interesting that the VXA 220 uses a single switch in exactly the manner Bob described when I wrote in asking for help just this last May.
Rick
On Sat, Aug 21, 2010 at 8:52 PM, rparigoris <rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us)> wrote:
--> AeroElectric-List message posted by: "rparigoris" <rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us)>
Hi Vern
Or perhaps go half way between the two and install a diode about 6" away from the relay? BTW we are supplying power to the relay coil through a 324 wire that is about 20# long.
Ron Parigoris
http://forums.matronics.com/viewtopic.php?p=309694#309694
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
  - G.K. Chesterton
rparigoris
PostPosted: Sat Aug 21, 2010 9:16 pm    Post subject: Re: Vertex VXA700 information needed Reply with quote
Hi Rick
If your Icom has two switches and is making one connection and breaking another when you push the PTT, it is different than my Vertex that makes two connections.
On my Vertex VXA700 when you push the PTT one switch connects the mic high to pin 3 (mic high), this is a normal opened switch.
The other switch connects mic low to pin 2 (PTT high), this is a normal opened switch.
Thus my single relay is a double pole relay that just makes two connections when the PTT is depressed.
My double pole relay is doing exactly the same thing as pressing the premade harness PTT I have, when the PTT is depressed, two individual single pole switches make.
Would you mind taking an ohm meter to your set up and report back if in fact one switch is making and one breaking?
If it is in fact like my Vertex where both switches make, I will give Icom and pick their brains!
Ron Parigoris
rickofudall
PostPosted: Sun Aug 22, 2010 4:43 am    Post subject: Vertex VXA700 information needed Reply with quote
Sure Ron, happy to help. I'll do it this afternoon when it's too hot to be outside anyway. What can I say, I'm a woose for this hot muggy weather.
Rick
On Sun, Aug 22, 2010 at 12:16 AM, rparigoris <rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us)> wrote:
Hi Rick
Ron Parigoris
http://forums.matronics.com/viewtopic.php?p=309709#309709
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
  - G.K. Chesterton
rickofudall
PostPosted: Sun Aug 22, 2010 7:33 am    Post subject: Vertex VXA700 information needed Reply with quote
Ron, I am completely wrong in my memories about the Icom PTT for their headset adapter (Icom part no. OPC-499). The plug is a monaural 1/8" (two contacts). This switch is connected to the microphone socket only. When the PTT is open the three contacts of the microphone socket are open to each other. When the switch is pressed the middle contact is connected to the ground contact. So, essentially I was completely full of c*** with my memories last night.
Sorry for the misdirection.
Rick
On Sun, Aug 22, 2010 at 7:42 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Rick
Hi Rick
Ron Parigoris
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
  - G.K. Chesterton
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
  - G.K. Chesterton
PostPosted: Sun Aug 22, 2010 5:13 pm    Post subject: Vertex VXA700 information needed Reply with quote
FYI The David Clark PTT switch works the same way-disconnects the MIC until
the PTT is pushed. I don't know why this is essential... it might be that
for battery powered equipment, it reduces current drain (the mic bias) until
required. Sometimes it becomes "because that's the way we've always done
it". Bob may know better.
As for the relay snubber, the diode can be added somewhere else. It's a low
power relay, so the amount of coil energy involved is small-- a regular
diode works fine.
Good Luck
V
Sent: Saturday, August 21, 2010 6:52 PM
Hi Vern
our VXA700.
high.
not know why.
and mic.
Ron Parigoris
06:35:00
