aadamson
Posted: Fri Aug 20, 2010 10:51 am Post subject: Audio Panel hookup |
I've seen this referenced on one other forum, but no responses, so I figured I'd try it here.
I've got an SL30 and SL40 that I'm trying to wire to a PSE 8000/9000 type audio panel.
The radio's each have the following
Mic
Mic lo
Phone
Phone lo
tx key
The audio panel however only has
Mic
Phone
Com lo
tx key
Basically there is only one ground or lo for the radio on each at the audio panel. So do you use it to connect both the mic lo *and* the phone lo?
Secondly, if connecting multiple unswitched outputs that all have their own output adjustment levels, do you still need to connect a 100ohm, 1/2w resistor in series with their output at the audio panel?
Thanks in advance,
aadamson
Posted: Fri Aug 20, 2010 11:59 am Post subject: Re: Audio Panel hookup |
Answered my first question and for those that might need to know.
Yes, on the radios to audio panel, you connect the to "lo"'s together and then to the phone low on the audio panel.
As for the unswitched audio's.... I'm still checking on that one.
Alan
