don.honabach(at)pcperfect Guest
Posted: Wed Aug 18, 2010 7:45 pm Post subject: ghost in the engine 2200A |
I would have sworn you bumped the intake house during the annual as it sounded like turbulent air going into the carb which would have also made sense considering the cylinders temps, etc.
I didn't see anything in your message about fuel testing beyond electric fuel pump on/off. Is it possible the mechanical fuel pump is bad/going bad (I'm assuming the 2200 has a mechanical fuel pump as my 3300A does?). Might be worth it to setup a temporary gravity feed setup that goes direct to the carb so you can bypass all fuel pumps.
Good luck and please share when you find out the cause.
Don Honabach
| - The Matronics Jabiru-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Jabiru-List |
Clive J
Posted: Mon Aug 23, 2010 1:02 am Post subject: ghost in the engine 2200A |
Have drained the fuel and filled up with fresh?
Regards, Clive
