Posted: Wed Sep 01, 2010 8:54 am Post subject: Sir Joseph Lucas: "The Prince of Darkness" |
To all those who have having electrical pump problems. This may be the information you need, forwarded to me by a mate who is an ex NZAF flight engineer. I would stress that this electrical theory does not only apply to English Electrical Components. It is applicable to everything that needs `smoke` to make it work.
Pat
I have only a limited knowledge of such things; however a reliable correspondent asserts they are true. I do believe this theory to be absolutely proven. Actually, Sir Joseph Lucas is commonly known as The Prince of Darkness."
As written by the Prince of Smoke himself...
ELECTRICAL THEORY BY JOSEPH LUCAS
Positive ground depends on proper circuit functioning, which is the
transmission of negative ions by retention of the visible spectral
manifestation known as "smoke".
Smoke is the thing that makes electrical circuits work. We know this to be
true because every time one lets the smoke out of an electrical circuit, it
stops working. This can be verified repeatedly through empirical testing.
For example, if one places a copper bar across the terminals of a battery,
prodigious quantities of smoke are liberated and the battery shortly ceases
to function. In addition, if one observes smoke escaping from an electrical
component such as a Lucas voltage regulator, it will also be observed that
the component no longer functions. The logic is elementary and inescapable!
The function of the wiring harness is to conduct the smoke from one device
to another. When the wiring springs a leak and lets all the smoke out of the
system, nothing works afterward.
Starter motors were considered unsuitable for British motorcycles for some
time largely because they consumed large quantities of smoke, requiring very unsightly large wires.
It has been reported that Lucas electrical components are possibly more
prone to electrical leakage than their Bosch, Japanese or American
counterparts. Experts point out that this is because Lucas is British, and
all things British leak. British engines leak oil, British shock absorbers,
hydraulic forks and disk brake systems leak fluid, British tires leak air
and British Intelligence leaks national defense secrets.
Therefore, it follows that British electrical systems must leak smoke. Once
again, the logic is clear and inescapable.
In conclusion, the basic concept of transmission of electrical energy in the
form of smoke provides a logical explanation of the mysteries of electrical
components - especially British units manufactured by Joseph Lucas, Ltd.
And remember: "A gentleman does not motor about after dark, he stays home and drinks warm beer from his Lucas refrigerator."
Joseph Lucas
(1842-1903)
Release Date: 08/31/10 11:34:00
Thom Riddle
Posted: Thu Sep 02, 2010 3:05 am Post subject: Re: Sir Joseph Lucas: |
Pat,
Having endured Lucas' Magic in several English vehicles over the years, I can confirm the apparent truth in the retained smoke theory. However, sometimes the smoke gets away without notice, but the device still dies.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
TheWrathPrince
Posted: Thu Sep 09, 2010 8:43 pm Post subject: Re: Sir Joseph Lucas: |
well!! that's the work of The Prince of Darkness (Sir Lucas)
_________________ "All that is your is rightfully mine, and mine it will be." - The Wrath Prince |
