		chris Sinfield
  Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
				 Posted: Fri Sep 03, 2010 4:17 am    Post subject: pitot static plumbing |
				Ok now for the exciting stuff
 has anyone used the quick push in couplings for their air lines?
 which to get Stein Air's? , Spruce??
 Also going to use the second pipe on the Zenith Pitot tube for AOA and putting in 2 fuse static ports
 please post your comments..
 Chris
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		jaybannist(at)cs.com Guest
				 Posted: Fri Sep 03, 2010 4:28 am    Post subject: pitot static plumbing |
				Chris,
  My DAR says he really prefers the push-on barbed connections for pitot and static.  Once on there, they will not come off.  They must be cut off and a new piece of tubing installed.  He says the compression type connections tend to leak and fail a pressure check.
  Jay Bannister
		naumuk(at)windstream.net Guest
				 Posted: Fri Sep 03, 2010 5:37 am    Post subject: pitot static plumbing |
				Chris-
     If you're talking about the couplings shown on the HH DVDs, I never got
 an answer from Mark Townsend where he procured them, and I never saw them
 offered the last time I was at Oshkosh. Neat idea if you can find them.
     Bill
				 Posted: Fri Sep 03, 2010 5:38 am    Post subject: pitot static plumbing |
				Jay-
      Interesting. Since I couldn't  find the "quick disconnect" couplings for sale, your suggestion is the route I  took.
        Bill
                                            do  not archive
  [quote]   ---
		Afterfxllc(at)aol.com Guest
				 Posted: Fri Sep 03, 2010 5:48 am    Post subject: pitot static plumbing |
				Chris
  It depends of the type line you run also. If you run rubber hose (like fuel  line) use clamps , if you run 1/4 inch nylon use compression, and if you use the  clear rubber you can use barbed fittings. We do a pitot static check of each  aircraft and most have leaks and we repair them with compression fittings and  nylon lines. If your brake lines don't leak then that's pretty good  evidence it works and works well.
  Jeff
   In a message dated 9/3/2010 8:18:38 A.M. Eastern Daylight Time,  chris_sinfield(at)yahoo.com.au writes:
   	  | Quote: | 	 		  -->    Zenith601-List message posted by: "chris Sinfield"    <chris_sinfield(at)yahoo.com.au>
 Chris
 Read    this topic online    here:
 http://forums.matronics.com/viewtopic.php?p=311206#311206===============================================
 _-=    Use the  ties  Day  ================================================               - MATRONICS WEB FORUMS  ================================================             - List Contribution Web Site  sp;                             ===================================================
		wa7dvd
  Joined: 27 Oct 2006 Posts: 11 Location: Salt Lake City, Ut
				 Posted: Fri Sep 03, 2010 10:00 am    Post subject: Re: pitot static plumbing |
				I used the Safe Air quick connects that are now sold by Steinair.  I have not had the official static test done yet but from the testing I did they seal very well when using the nylon tube they sell for it
 -Bruce-.
  _________________ BK Johnson
Zodiac 601XLb
Jabiru 3300a
N601BK |
		johnd
				 Posted: Fri Sep 03, 2010 10:10 am    Post subject: pitot static plumbing |
				I've used the SafeAir fittings as well and have not had any problems
 with my Pitot Static tests. You can also purchase them from
 www.safeair1.com.
 John Davis
 N601JD - 601XL
 On 9/3/2010 2:00 PM, wa7dvd wrote:
  -Bruce-.
  BK Johnson
  Zodiac 601XLb
  N601BK
  http://forums.matronics.com/viewtopic.php?p=311266#311266
		chris Sinfield
				 Posted: Fri Sep 03, 2010 2:55 pm    Post subject: Re: pitot static plumbing |
				Thanks  Gang
 I was going to use the Safe air stuff but have just read it works only with their tubing.. Thats why I was looking at the Stein Air fittings.
 I have as l  have ready run the Zenith supplied 1/4 inch stuff, maybe the barbed T's and stuff are the way to go. where do we get them from Spruce?
 Chris
		scottbevier
		rolif6 Guest
				 Posted: Fri Jun 28, 2024 11:48 am    Post subject: Re: pitot static plumbing |
				Pitot static plumbing in aircraft refers to the intricate network of tubes and sensors designed to measure air pressure for critical flight data, such as airspeed and altitude. This system includes both pitot tubes, which capture ram air pressure, and static ports, which sense ambient air pressure. Proper maintenance and calibration of these components are crucial for accurate readings, ensuring the safety and efficiency of flight operations. Click here https://clearwateremergencyplumber.com/sewer-backup/ for more detailed information on pitot-static plumbing and its importance in aviation.
