		| Author | Message |
		| frans(at)privatepilots.nl Guest
				|  Posted: Sun Sep 12, 2010 12:31 pm    Post subject: Bing Carb Checks ----- FAA investigated fatal  accident.. |   |
				| On 09/12/2010 07:32 PM, Guerner Remi wrote:
  	  | Quote: |  	  |
 The reason for two carbs on the Rotax is not redundancy but performance.
 I am pretty sure that if one carb fails completely on the Rotax, the
 engine runs so rough that you had better stop it immediately and land.
 There is a solution to that:
 http://www.flygas.info/en/kit-intake-manifold.html
 This set replaces the balance tube between the carbs by a much larger
 balance tube, so each carb can feed both halves of the engine. It also
 doesn't matter much anymore if your carbs are balanced or not, you can
 just loose a carb and the engine keeps running on 4 cylinders.
 It also makes retrofitting fuel injection easier, as these inlet
 manifolds have already the fuel injector bosses in them. You only have
 to bore them out and tap a thread in them.
 The new billet pump (see Rob Borgers reports) is capable of feeding an
 injector system directly, as it can produce a sufficiently high
 pressure. So all one need after that is four injectors and a universal
 EFI-box. You keep the carbs, they are now just playing the role of
 throttle body.
 The nice thing with such a setup is that you can in flight switch
 between carbs and EFI. So you keep the carbs as a backup.
 I feel a project coming.
 Frans
		| Back to top |  |
		| rampil
				|  Posted: Mon Sep 13, 2010 8:30 am    Post subject: Re: Bing Carb Checks ----- FAA investigated fatal  accident. |   |
				| Hi Frans,
 I looked at that referenced Italian site for FlyGas.
 They gave no indication that their mod had been operationally tested
 in any way as of this data (Sep 13, 2010)
 Their cross tube looks to be about an inch +/- in diameter. At about
 a foot long, my back of napkin estimate is that there would be quite
 a pressure drop across that tube at WOT, causing an imbalance in
 MP across the engine.  Looks doubtful to reduce carb imbalance
 vibration on that basis, but will likely cause an RPM related imbalance
 of its own which would not be adjustable.
 Before we jump on another bandwagon lets see some actual operational
 data, preferably with an accelerometer quantifying vibration.
 Cheers,
 Ira
 Ira N224XS
		| Back to top |  |
				|  Posted: Mon Sep 13, 2010 9:47 am    Post subject: Bing Carb Checks ----- FAA investigated fatal  accident.. |   |
				| On 09/13/2010 06:30 PM, rampil wrote:
  	  | Quote: |  	  | Their cross tube looks to be about an inch +/- in diameter. At about a foot long, my back of napkin estimate is that there would be quite
 Pressure drop? Both halves of the engine carry the same manifold
 pressure. If there is no inbalance, the air inside the cross tube is
 more or less static, although it will cancel out the intake pulses, so
 the air will be thrown left and right but never actually leave the tube.
 This is a good thing by itself, because it will soften the intake
 pulses. This will even out the mixture between the front and rear cylinder.
 Let me explain this further: I guess everyone knows that the front
 cylinders of a Rotax get a different mixture than the rear cylinders.
 Some people think it has something to do with the distance to the carbs.
 Wrong. The reason is that the Rotax fires two cylinders at each side,
 and then fires the cylinders on the other side. So at each engine halve,
 you will find two intake cycles, and then nothing for a while (during
 this time the other cylinders on the opposite engine half have their
 intake cycles.
 This means that the airflow in one carb has to accelerate at the first
 intake cycle, and when that intake valve closes, the other cylinder has
 its intake cycle. This cylinder benefits from the air already at speed
 through the carb. All this has to do with inertia. For the first
 cylinder, apart from the fact that is has the task to accelerate the
 mixture after it came to a halt during the pause, the acceleration of
 the fuel is lower than the acceleration of the air. So the first
 cylinder at each engine halve gets a leaner mixture than the one that is
 to fire just after it.
 So, the idea of a balance tube is to keep the air up to speed, because
 both engine halves have the same problem, but at alternating moments.
 Balance tubes are common things in cars, both for the intake as well as
 for the exhaust. But usually they have a much larger diameter.
 But all this has nothing to do with carb imbalances, this is just an
 additional advantage. So, let's go back to the claim that this larger
 cross tube makes imbalances less obvious:
  	  | Quote: |  	  | Looks doubtful to reduce carb imbalance vibration on that basis,
 Never took the small balance tube away (for pneumatic carb balancing)?
 Without the tube, imbalances become more obvious. Put the tube in, and
 some of the imbalance is gone, because the tube allows some of the
 mixture from the higher manifold pressure side to flow to the lower
 manifold pressure side. Put even more tube in (i.e. a larger diameter)
 and more mixture can flow through it, making the difference in MAP
 between both halves even less, and thus lessening the imbalance.
  	  | Quote: |  	  | Before we jump on another bandwagon lets see some actual operational data, preferably with an accelerometer quantifying vibration.
 Fine, if there is such data. If there isn't, we'll have to revert to
 basic physics and engine knowledge.
 I might install a larger cross tube some day (not for the cross tube
 actually, but for the option to fit fuel injectors), and I will let you
 know what I find.
 Frans
		| Back to top |  |
		| rampil
				|  Posted: Mon Sep 13, 2010 10:47 am    Post subject: Engine Engineering (was Bing carb recall |   |
				| Hi Frans,
 I mentioned the cross tube since you had mentioned the failure of a carb
 and that both sides could be fed through the single carb and the"fat"
 cross tube. Outside that scenario, there should normally be little flow
 and resistive drop.
 I am not sure what a cross tube does to "soften" the incoming air pulses.
 The flow rate is mainly determined by the linear speed profile and the
 fixed surface area of the downgoing piston with the major flow restriction
 at the intake valve orifice. The extra compliance of the cross tube is
 probably only a small increment to the supply through the carb unless
 the butterfly is nearly closed.
 Sadly there is no public detailed spec on the Rotax 9xx series, but I do
 try to relate its operation from what I learned from Charles Taylor, John Heywood, and Will Pulkrabek's books.
 For most pilots wanting to learn a bit more about their engines (I.e.,
 Lycosaurus types), John Schwaner's Engineering Manual is great! Full
 of easy to read facts, not conjecture or rumor from a very experienced A&P. (www.sacskyranch.com)
 Ira N224XS
		| Back to top |  |
		| air.guerner(at)orange.fr Guest
				|  Posted: Mon Sep 13, 2010 12:02 pm    Post subject: Bing Carb Checks ----- FAA investigated fatal  accident.. |   |
				| Hi Frans,
 Looks like an interesting modification.  But I am wondering if there is any inconvenience with this system. If not, why did Rotax design the engine manifolds with a small balance tube?
 Remi
 <<<<There is a solution to that:
 just loose a carb and the engine keeps running on 4 cylinders.>>>>>>>
		| Back to top |  |
				|  Posted: Mon Sep 13, 2010 12:26 pm    Post subject: Bing Carb Checks ----- FAA investigated fatal  accident.. |   |
				| On 09/13/2010 08:47 PM, rampil wrote:
  	  | Quote: |  	  | I am not sure what a cross tube does to "soften" the incoming air pulses.
 Ok, I will try to explain some more.
 The firing order of the Rotax is 1-4-2-3. The intake order is of course
 similar.
 Now, let's see what happens.
 For ease of explanation, we will start with cylinder 4. The order we
 will follow is thus 4-2-3-1.
 Intake of #4 opens. Air starts to accelerate through the carb.
 At the moment #4 closes, intake #2 opens. This cylinder is on the same
 carb as #4. The air is already up to speed through the carb, it only has
 to take the next exit.
 Intake #2 closes. As on this side of the engine there are no more
 intakes, and we now have to wait for the two cylinders on the other side
 of the engine to complete their intake cycle, the air comes to a
 screaching halt. There is nowhere to go for the air, all intakes on this
 side are closed!
 At the same time #2 closes, intake #3 opens. This one is on the other
 carb. The air has been come to a stop there, because while the engine
 was working on #4 and #2, this carb had no throughput at all. So intake
 #3 has the task to start accelerating the air. When #3 closes, #1 opens,
 same bank, so the air can just go through. And when #1 closes, this bank
 is done, air comes to a stop, and we switch over to intake #4. The whole
 cycle repeats itself here.
 Ok, now with the balance tube. This will fit in between previous paragraphs.
 At the moment intake #2 closes, there are no open intakes on that side
 anymore. The air however is at speed, and due to inertia the air wants
 to keep going. (keep in mind that the engine runs at 5000 rpm, and at
 this speed, inertia of the gasses plays a significant role). Luckily
 there is a balance tube, and the air still rushing through the carb
 (remember, there is a whole column of air up to speed from the airbox
 that doesn't know that intake #2 just closed) takes the only exit
 remaining: the balance tube.
 At the moment intake #2 closed, intake #3 opens. This one is at the
 other side. Luckily, there is just a bunch of air arriving through the
 balance tube! This air fills up the gap, at the moment the air through
 the carb of #3 has to start moving. Of course the flow through the
 balance tube doesn't last very long, but at the moment it ceases, the
 column of air through its own carb has just accelerated enough to take over.
 This is of course a simplified explanation, you'd better think of all
 this as pressure waves. To complicate things further, the column of air
 rushing in that finds all doors shut, bounces back. This backwards
 pressure wave interferes a moment later with the start of a new inlet cycle.
 So, this is what a balance tube is for. Maintaning a smooth air stream
 is more efficient and is easier on the carbs. Usually this translates in
 more power, and a more even distribution of density and mixture.
 Unfortunately, the balance tube of the Rotax is very small, and probably
 doesn't do much at WOT.
 Frans
		| Back to top |  |
				|  Posted: Mon Sep 13, 2010 12:40 pm    Post subject: Bing Carb Checks ----- FAA investigated fatal  accident.. |   |
				| On 09/13/2010 09:55 PM, Guerner Remi wrote:
  	  | Quote: |  	  | Looks like an interesting modification.  But I am wondering if there is any inconvenience with this system. If not, why did Rotax design the
 Looks like a question that fits into the same category as some other
 questions:
 1) Why is the carb attached to a flange that often ruptures and we have
 to inspect regularly? Why don't they fix it? On how many cars do the
 carbs once in a while just fall off?
 2) Why did Rotax not install a carb heater on the 912?
 3) Why does Rotax still sell a voltage regulator which is not up to its
 task?
 4) Why is the TCU data cable a RS232 and not an USB, and do I have to
 find a DOS computer to read out the engine parameters? Why can't they
 write a decent program for their clients who pay a lot of money for this
 engine?
 5) Why did Rotax not install a billet pump on the 914, and forces us to
 rely on two electrical fuel pumps instead?
 6) Why do I need to manually disconnect the wastegate servo in case the
 system starts surging, and is the TCU unable to recognize and solve the
 problem on its own? How many cars exhibit this behaviour?
 Etc.
 Of course, Rotax may have had a reason for this one. But then again,
 they might have not.
 The whole balance tube looks as an afterthought, something they came up
 with after the design was ready and the molds for the intake manifold
 where already done. So there we have it, way too small, floating in the
 air, and it gave them a good opportunity to attach two springs to it to
 prevent the carb from falling off when the famous flange ruptures.
 Who knows?
 Frans
		| Back to top |  |
		| fklein(at)orcasonline.com Guest
				|  Posted: Mon Sep 13, 2010 1:09 pm    Post subject: Bing Carb Checks ----- FAA investigated fatal  accident.. |   |
				| On Sep 13, 2010, at 1:36 PM, Frans Veldman wrote:
  	  | Quote: |  	  | 1) Why is the carb attached to a flange that often ruptures and we have
 its
 task?
 this
 engine?
 to
 the
 the
 Etc.
 Frans...All excellent questions...
  	  | Quote: |  	  | >  On how many cars do the carbs once in a while just fall off?
 ..I'll just bite my tongue and resist further comment...afterall, I'm
 still building...
 Fred
		| Back to top |  |
				|  Posted: Mon Sep 13, 2010 1:38 pm    Post subject: Bing Carb Checks ----- FAA investigated fatal  accident.. |   |
				| On 09/13/2010 11:03 PM, Fred Klein wrote:
  	  | Quote: |  	  | >>  On how many cars do the carbs once in a while just fall off?
 ...I'll just bite my tongue and resist further comment...afterall, I'm
 still building...
 Don't get me wrong. I'm happy with my Rotax 914. It is a nice and
 reliable engine. But it doesn't mean that it is perfect, or that nothing
 can be improved upon.
 I think there is a lack of competition here. Why should they improve it?
 It sells anyway.
 Do they actually still have a development department? Or have they left
 years ago because they harvested enough money? Is that why there is no
 EFI version of the 914, no Windows version of the TCU-program, etc?
 Frans
		| Back to top |  |
		| grahamsingleton(at)btinte Guest
				|  Posted: Mon Sep 13, 2010 2:20 pm    Post subject: Bing Carb Checks ----- FAA investigated fatal  accident.. |   |
				| Fred
I have to smile, why indeed. Why did they not have a proper breather on the coolant collector bottle. If they had I might not have got a black eye and some broken bones.
 We must keep on learning and sharing information.
 Graham
 Sent: Monday, 13 September, 2010 22:03:43
 Subject: Re: Europa-List: FW: Bing Carb  Checks ----- FAA investigated fatal  accident..
 --> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)>
 ..I'll just bite my tongue and resist further comment...afterall, I'm still building...
 Fred
		| Back to top |  |
		| josok-e
				|  Posted: Tue Sep 14, 2010 1:44 am    Post subject: Re: Bing Carb Checks ----- FAA investigated fatal  accident. |   |
				| Two years ago, one day before my second birthday, we happened to be at the same table with the brass of the Rotax factory in Wels. And of course the question about injection popped up. The anwser was that yes, they were working on that, and their main difficulty was to make the efi programmers understand that in case of any error the engine was not to shut down, but continue running, They also suggested that there was an injection engine up and running.
Rotax probably still fails to find a programmer that will and can do that special job. As for the other items to be improved: Remember there is a certified engine. Getting a new certification because parts change seems to be very costly... Changing parts on non-certified engines and divert from the approved stuff could be very costly because of the US liability threats.
		| Back to top |  |
				|  Posted: Tue Sep 14, 2010 5:04 am    Post subject: Bing Carb Checks ----- FAA investigated fatal  accident.. |   |
				| Hi, Justin,
 This confirms what Jerry said. Good to know!
 Remi
 <<<<Thus I can say that a Rotax 912s will give 4000 rpm on the
 starboard carb o
 nly. >>>>>
		| Back to top |  |
				|  Posted: Tue Sep 14, 2010 5:42 am    Post subject: Bing Carb Checks ----- FAA investigated fatal  accident.. |   |
				| Frans,
 Here are my answers to some of your questions below:
 have to inspect regularly? :
 the problem with the rubber flanges is  known to happen on basic
 microlight installations where each carb have its own air filter with
 no further mechanical support. The carbs then oscillate vertically and
 flex the rubber flange, leading to fatigue rupture. When you are using
 a properly supported airbox this does not happen.  However with the
 914 it is a different story as the internal pressure will tend to
 disconnect the carbs and the airbox.
 Lycoming and Continental are not supplying a carb heat system ether.
 Carb heat installation is usually designed and made by the aircraft
 manufacturer.  However Rotax offers an optional airbox fitted with the
 provision for hot air for the 912 series. It work fine on my Europa.
 its task?
 From my experience the Ducati voltage regulator works fine as long
 it is cooled properly.  There are two ways to do it: on a metal
 aircraft, bolt the regulator to the structure which will act as an
 heat sink.  On composites, provide fresh air with a SCAT ducting to
 the cooling fins of the regulator casing.
 Remi
 F-PGKL Monowheel, 912ULS, 800 hours
		| Back to top |  |
		| rampil
		| Back to top |  |
				|  Posted: Tue Sep 14, 2010 8:09 pm    Post subject: Bing Carb Checks ----- FAA investigated fatal  accident.. |   |
				| On Sep 13, 2010, at 2:33 PM, Frans Veldman wrote:
  	  | Quote: |  	  | --> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
  	  | Quote: |  	  | ...I'll just bite my tongue and resist further comment...afterall, I'm
 still building...
 reliable engine.
 Frans,
 ...not at all surprised that you feel that way...and I believe your feelings expressed above mirror those of (literally) hundreds of other Europa owners. And I admire your open mind and innovative thinking behind the mods you've done, on your cooling system for example.
 My reluctance to make further comments was solely based on my building around an alternative fuel-injected engine, with the outcome of that decision being still uncertain...I'm grateful for my high tolerance of ambiguity.
 Fred
		| Back to top |  |
