elleryweld(at)aol.com Guest
Posted: Fri Sep 17, 2010 4:40 pm Post subject: Upgrading from current 4.00-6 "Garden" tires. |
get a set of 8.00 X 6 tires and you will be happy and it will give you that bush plane look I think your looking for
Ellery Batchelder Jr.
rickofudall
Posted: Fri Sep 17, 2010 5:08 pm Post subject: Upgrading from current 4.00-6 "Garden" tires. |
I second Ellery's recommendation. Run them at about 12 psi for that Nerf tire effect.
Rick Girard
On Fri, Sep 17, 2010 at 7:24 PM, Ellery Batchelder Jr <elleryweld(at)aol.com (elleryweld(at)aol.com)> wrote:
[quote]get a set of 8.00 X 6 tires and you will be happy and it will give you that bush plane look I think your looking for
gotime242
Joined: 09 Jul 2010 Posts: 52 Location: West Palm Beach, FL
Posted: Sat Sep 18, 2010 5:59 am Post subject: Re: Upgrading from current 4.00-6 |
Thanks, i just wanted to be sure it was ok/safe to go wider than recommended or than the width of the rim since there is only 4.00's on there now.
