2 Fat Wires on a single terminal post?
tsts4
PostPosted: Tue Sep 21, 2010 9:41 am    Post subject: 2 Fat Wires on a single terminal post? Reply with quote
Hi,
What's the best way to mount 2 fat wires on a single terminal post on the battery contactor? Do you just clock the lugs so they lay flat one on top of the other or should a spacer (ie like a plain nut) be placed between the lugs in order to physically separate the wires along the post? Or does it even matter?
Thanks!
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
longg(at)pjm.com
PostPosted: Tue Sep 21, 2010 11:00 am    Post subject: 2 Fat Wires on a single terminal post? Reply with quote
Todd,
If it were me, and I wanted it to be functional, look good and be safe I
would find a terminal connector that would fit both wires. Crimp and
solder. That not moving. That setup will place less stress on the
terminal connector than having two ends doubled-up.
Glenn E. Long
tsts4
PostPosted: Tue Sep 21, 2010 11:17 am    Post subject: Re: 2 Fat Wires on a single terminal post? Reply with quote
Hmmm. I could see doing that for say 18-20AWG size wires, but I'm talking about a 2AWG and a 4AWG on the same post. Is doing that common for fat wires? I could be mistaken, but I don't thinking combining them into a single lug is an option.
Todd Stovall
longg(at)pjm.com
PostPosted: Tue Sep 21, 2010 11:48 am    Post subject: 2 Fat Wires on a single terminal post? Reply with quote
Todd,
If you mean do they make a connector to fit 2 such wires, that would be
a yes. Whether that suits your installation setup...
Glenn E. Long
tsts4
PostPosted: Tue Sep 21, 2010 11:56 am    Post subject: Re: 2 Fat Wires on a single terminal post? Reply with quote
Thanks Glenn. You happen to a have a source? None of the usual aviation sources carry anything like that so I'm guessing Mouser, Digikey, or similar? Also does the connector have any special nomenclature that would help in narrowing the search?
Thanks again!
Todd Stovall
Allen Fulmer
PostPosted: Tue Sep 21, 2010 3:06 pm    Post subject: 2 Fat Wires on a single terminal post? Reply with quote
AC 43.13-1B, chapter 11, page 11-76, has several sketches of lugs connected
to various bolts, studs, etc. Depictions of installation order of washers,
lock washers, lugs, etc. I didn't look for similar data on connections to
contactors but I'll bet the book has something to say about that.
Allen Fulmer
RV7 working on cowling
N808AF reserved
RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL
tsts4
PostPosted: Tue Sep 21, 2010 3:29 pm    Post subject: Re: 2 Fat Wires on a single terminal post? Reply with quote
I re-read Chapter 11 before my original post and didn't come away with a definitive answer (except the max limit for terminating wires at a given terminal is 4). I think clocking the lugs so they don't interfere with one another with a terminal boot over the lug on top is probably the I'm going to go unless this is a violation of acceptable practices.
Todd Stovall
