Posted: Thu Sep 23, 2010 3:30 pm Post subject: pin confirmation |
Bob, Group,
My IRFP3703 MOSFET arrived today. In doing a little research on it, the best I can tell is
the pins are 1,2 & 3, from left to right, if the MOSFET is facing you and the pins are down,
and you can read the product information.
If we assume the pins are as described above, can someone confirm which pin is which?
>From I could find out, it looks like the pin #3 is the source, pin #2 the gate, and pin #1 the drain.
But, I am not sure at all.
Thanks, Mike Welch
Posted: Thu Sep 23, 2010 5:34 pm Post subject: pin confirmation |
[quote]But, I am not sure at all.
Thanks, Mike Welch | Quote: | | Group, From what it appears, from the TO247AC description (the MOSFET's case),it looks like pin #1 is the gate, pin #2 is the drain, and pin #3 is the source,not the way I described them above.Mike Welch |
pmather
Posted: Fri Sep 24, 2010 5:09 am Post subject: pin confirmation |
Peter,
Thanks for the reply. I have looked at that data sheet probably 10 times, but I couldn't
seem to locate where it says what the pin assignment is. But, I just saw at the very bottom,
in the right corner of the last page, where it lists the pin assignments.
Thanks, Mike
[quote] | Quote: | From what it appears, from the TO247AC description (the MOSFET's case),it looks like pin #1 is the gate, pin #2 is the drain, and pin #3 is the source,Mike Welch
| [b]
Posted: Fri Sep 24, 2010 5:13 am Post subject: pin confirmation |
At 06:20 PM 9/23/2010, you wrote:
Bob, Group,
Don't need to assume anything. Here's a view I captured from
the data sheet.
[img]cid:7.1.0.9.0.20100924080214.01230128(at)aeroelectric.com.0[/img]
122.7 KB |
4533 Time(s) |
Posted: Fri Sep 24, 2010 5:49 am Post subject: pin confirmation |
Thanks Bob!
