kolb stall
Goto page Previous  1, 2
russkinne(at)mac.com
PostPosted: Sun Sep 19, 2010 4:34 pm    Post subject: kolb stall Reply with quote
Can you access the subject of VG's thru Matt or somehow? (Vortex
Generators)
There's been a lot of talk about them in the past
Worth reading.
On Sep 19, 2010, at 6:37 PM, gtaylor wrote:
<gtaylor35918(at)roadrunner.com>
Not to ask a stupid question, I am familiar with CG, is VG a typo,
or something else.
Thanks, Greg
PostPosted: Sun Sep 19, 2010 10:01 pm    Post subject: kolb stall Reply with quote
I'm not sure who Matt is, I am new to the list, a 250 hr pilot with IFR, but
I have only about 1.5 in my Kolb Firestar. I bought it already built, went
through it pretty thoroughly and then test flew it. I have seen all the
threads about Scott's accident and was worried that his wife could be
monitoring the list and see all the comments. This is something that she
doesn't need right now, what she needs is our condolences and our prayers.
As pilots we all know and I remember my ground school instructor telling us
that airspeed is your life, so the most important thing in flying is
managing that air speed.
I told myself what testing I was going to do on my initial flight, and
I wound up just flying around the patch several times and doing touch and
goes. I did no stalls, or any of the testing I was planning on doing. This
was about a month or two ago maybe longer, since then I have mowed a runway
off behind my house and tried to fly out of it. I only have about 400 ft of
good usable runway maybe five, and I learned the hard way how easy it is to
put the nose in the dirt, I aborted a take off because when I was ready to
leave the ground at a certain point on the runway the plane wasn't. I went
past the end of my runway because the breaks weren't strong enough and went
into some high weeds which along with full breaks caused me to put the nose
in the dirt. After repairing the nose cone and replacing the tube/hinge for
the rudder pedals I have decided that I need to go back to the airport,
maybe even fly from there to a local grass strip to do some more testing
before I play bush pilot out of my back yard. I don't consider myself to be
an elite pilot at 250 hrs nor will I at a thousand, It seems that I have
read before that we are all student pilots because there is always something
new to learn in aviation, Its when we think we know it all that we get
ourselves into trouble, that's why I talked to a lot of people with
experience with Kolb's and ultralights to learn as much as I can and I
believe it saved my life because I had never heard of aileron flutter
before, I saw it on a thread on this list and ask a local guy who is in the
know when comes to building ultralights and LSA, and sure enough on my first
go around the pattern I experienced it turning on final because I let my
airspeed get to high, I did what Mike said that he did when he experienced
it, and it came right out of it.
Thanks, Greg
Dana
PostPosted: Mon Sep 20, 2010 1:56 am    Post subject: kolb stall Reply with quote
Matt is the list owner. However, there is no need to contact him to
make a search; the list website has a good search function and you'll
find all you ever wanted to know (and then some!) on the subject of
VG's.
-Dana
"gtaylor" <gtaylor35918(at)roadrunner.com> wrote:
(09/20/2010 01:57)
PostPosted: Mon Sep 20, 2010 6:43 am    Post subject: kolb stall Reply with quote
Thanks, Greg
Greg/Gang:
Did you install aileron counterbalance weights to prevent aileron flutter
after you discovered it would flutter?
If you get into flutter once without aileron counterbalance weights, you
will probably get into it again without them.
Rock House, OR
PostPosted: Mon Sep 20, 2010 9:04 pm    Post subject: kolb stall Reply with quote
I haven't istalled counter balances as of yet, but after that first time I
did several more take off and landings and had no trouble. The big thing was
letting the air speed get to high, after that first trip around the patch I
watched the airspeed closer and had no further problems.
Thanks, Greg
slyck(at)frontiernet.net
PostPosted: Tue Sep 21, 2010 5:03 am    Post subject: kolb stall Reply with quote
I put off installing them too, until one day I encountered heavy turbulence which will give you radically variable airspeeds.
40 one second, 80 the next. I definitely had flutter, enough to loosen a hinge pin pretty good.
Those balancers went on right after.
BB
On 21, Sep 2010, at 1:01 AM, gtaylor wrote:
I haven't istalled counter balances as of yet, but after that first time I did several more take off and landings and had no trouble. The big thing was letting the air speed get to high, after that first trip around the patch I watched the airspeed closer and had no further problems.
Thanks, Greg
zeprep251(at)aol.com
PostPosted: Tue Sep 21, 2010 5:41 am    Post subject: kolb stall Reply with quote
Greg/list.
You should take the flutter seriously.It can destroy structure quickly and take you with it.Fix it now.Just one comment on first flights, in a new airplane or even one that's just new to you.It's like a test drive in a car.Take some time with it. If it feels stable and controllable stay in it for an hour.Get the feel of it at different speeds,the low end for sure.If your not comfortable stalling,don't,but you have to know what it feels like slow,and you can do that away from the ground, safely.
G.Aman
racerjerry
PostPosted: Tue Sep 21, 2010 5:55 am    Post subject: Re: kolb stall Reply with quote
PLEASE install those aileron counter-balance weights NOW, before further flight. I will consider it a personal favor to me. Flutter can happen in the blink of an eye and in another blink can tear the ailerons off the airplane. It takes a trigger to start flutter. If the trigger occurs at higher airspeed, next time you may not have warning nor time to slow down before the ailerons depart.
AOPA has a great video and story on the subject here:
http://flash.aopa.org/asf/pilotstories/mayday/MaydayatMountMcKinley/
Jerry King
PostPosted: Tue Sep 21, 2010 7:04 am    Post subject: kolb stall Reply with quote
> john h
> mkIII
> Rock House, OR
Greg T/Gang:
Reread my the note above. It has been proven true many times.
by0ung(at)brigham.net
PostPosted: Tue Sep 21, 2010 9:26 am    Post subject: kolb stall Reply with quote
Thanks, Greg
this is all good till you end up going somewhere and get in some weather / wind conditions that take you by supprise..... a few years back i had just come over a set of mountains,,,, got cought up in some type of rotor, the asi jumped from 40 to 90 mph back and forth in about 1/4 to 1/2 second intervals, that would not be a good time to be wishing you had counter balances.
boyd young mkIII
Ralph B
PostPosted: Fri Sep 24, 2010 2:26 pm    Post subject: Re: kolb stall Reply with quote
That "nasty" Kolb stall is due to wing loading. My Firestar has a gentle stall with 148 sq feet of wing. Take that same wing and double the wing loading like the Kolbra, and it can be a killer if you're not careful. When I was transitioning to the Kolbra, I would ask Mark why it wanted to drop as we were landing. I told him that my Firestar didn't do that. He couldn't give me an answer because that was the only Kolb he has flown. To keep from dropping the wing, I stay well away from stall. It scares me to slow it up on landing, and for good reason. On the other hand, if I do a power on stall at altitude, it refuses to drop because of the VG's.
Ralph
I made a discovery since this last post. I have always landed the Kolbra solo without using the flaperons because this was the way Mark recommended it and I've always landed it hot, so it wouldn't drop. It's been awhile since I had the chance to fly solo, so this past Wednesday I decided to put the flaperons down on landing. I purposely slowed it up to see if it would drop. Would you believe it landed pretty much like the Firestar where the tailwheel hit first and the mains came down ever so softly? I was surprised and happy to see this. One would think that I would have experimented with this a long time ago, but I'm a person of habit and if I'm trained to do it one way, I keep doing it that way. Now, I also have to say the flaperons on the Kolbra don't go down too far, but enough to change the center of lift on the wing and eliminate the drop while flaring.
Ralph
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
Thom Riddle
PostPosted: Sat Sep 25, 2010 2:51 am    Post subject: Re: kolb stall Reply with quote
re: I have always landed the Kolbra solo without using the flaperons
Ralph,
Does your Kolbra have in-flight adjustable elevator trim? Does it exhibit much pitch change when adding flaperons or slowing down from normal cruise speed to final approach speed?
I'm asking out of curiosity. What I've noticed in my SS is that when I slow down from my normal cruise speed all trimmed out for cruise, to final approach speed, the nose up pitch increases so I have to push the stick forward or add nose down elevator trim to compensate. I've discovered that by adding full flaperons at final approach speed, the nose-down pitch response from the flaperons is just right so that changes in elevator trim from normal cruise setting is not required to relive the small amount of stick pressure.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Ralph B
PostPosted: Sat Sep 25, 2010 5:58 am    Post subject: Re: kolb stall Reply with quote
Thom Riddle
Ralph,
Thom,
My Kolbra has an inflight adjustable elevator trim. It consists of a motorized bungee cord on the stick that tightens when the motor is energized with a toggle switch. It's crude and simple, but works. I only use it for solo and passenger flight. I engage the toggle one way for solo and the other way if I carry a passenger. This takes care of the fine elevator adjustment. The course adjustment is a ground adjustable trim on the elevator that Mark put in. When I fly solo, I toggle the switch for nose down and will have to hold a little forward pressure on the stick, but on landing it seems to be perfect. When carrying a passenger, I toggle the switch for nose up and don't seem to have any other pitch adjustments in flight or on landing.
Ralph
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
Page 2 of 2
