sarg314(at)gmail.com Guest
Posted: Mon Sep 27, 2010 12:05 pm Post subject: db connector hold-down screws |
I had a problem with the DB9 on my Lightspeed ignition coming loose. A Lancair builder put me on to these screws
AN500-AD4-7
which I ordered from aircraft spruce. They are drilled fillister head screws and were perfect for the task.
On Mon, Sep 27, 2010 at 10:56 AM, j. davis <jd(at)lawsonimaging.ca (jd(at)lawsonimaging.ca)> wrote:
| Quote: | --> AeroElectric-List message posted by: "j. davis" <jd(at)lawsonimaging.ca (jd(at)lawsonimaging.ca)>
Greetings...
I remember seeing an article on how to fabricate hold-down screws for db connectors
installed with no shells, but now can't locate it. I know it's not exactly rocket science, but would like to re-read the article. I'm pretty sure it was aeroelectric list related...
Thanks!
Tom Sargent
james(at)etravel.org Guest
Posted: Mon Sep 27, 2010 2:28 pm Post subject: db connector hold-down screws |
J, Bob posted some alternatives here:
http://www.aeroelectric.com/Pictures/Connectors/D-Subminature/DIY_Jackscrews.jpg
Hopefully that's what you were after.
James
On 27 September 2010 18:56, j. davis <jd(at)lawsonimaging.ca> wrote:
Greetings...
connectors
Thanks!
Regards, Â J.
Sonex #325 C-FJNJ, Jabiru 3300a, Prince P-Tip, Aerocarb
restoring the Johnston Special
http://cleco.ca
| Â J. Davis, M.Sc. Â Â Â Â Â Â | (computer science) Â Â Â Â Â Â |
| *NIX consulting, SysAdmin  | email: jd at lawsonimaging.ca |
I went to a general store, but they wouldn't let me buy
anything specific.
                --- Steven Wright
jd(at)lawsonimaging.ca Guest
Posted: Tue Sep 28, 2010 4:39 am Post subject: db connector hold-down screws |
On 09/27/2010 06:21 PM, James Kilford wrote:
Thanks to all!
On 27 September 2010 18:56, j. davis<jd(at)lawsonimaging.ca> wrote:
> Greetings...
> connectors
> Thanks!
Regards, J.
http://cleco.ca
| J. Davis, M.Sc. | (computer science) |
Yesterday I parked my car in a tow-away zone...when I came
back the entire area was missing...
--- Steven Wright
Sam
Posted: Sun Oct 03, 2010 6:07 am Post subject: db connector hold-down screws |
You can purchase ready made connector hold down screws from Stein Air, in Minnesota. They are about 1.5" long and have a knurled post. I bought several and will be switching them out every time I undo a connector.
They may not be in the on-line offering. Just give them a call, they are very helpful.
Sam
On Tue, Sep 28, 2010 at 6:18 AM, <bakerocb(at)cox.net (bakerocb(at)cox.net)> wrote:
[quote]--> AeroElectric-List message posted by: <bakerocb(at)cox.net (bakerocb(at)cox.net)>
9/28/2010
Hello J. Davis, You wrote: ".....how to fabricate hold-down screws for db connectors
installed with no shells, but now can't locate it."
See my posting of 5/29/2010 copied below.
'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge."
PS: Phillips drive machine screws are an abomination. Every builder who has converted to the Torx (6 lobe) drive screws has been delighted with the results.
Time: 11:03:43 AM PST US
From: "j. davis" <jd(at)lawsonimaging.ca (jd(at)lawsonimaging.ca)>
Subject: db connector hold-down screws
Greetings...
science,
related...
Thanks!
Regards, J.
Match: #2Message: #49535From: <bakerocb(at)cox.net>Subject: D-subminiature ConnectorsDate: May 29, 2010
5/29/2010
Hello Fellow Builders, Here is what we are writing about:
http://en.wikipedia.org/wiki/D-subminiature
Bob Nuckolls writes: "It's a fact that the majority of d-sub connectors come
with short, slotted-head 4-40 jack screws that are EXCEEDINGLY
difficult to work with in confined spaces traversed by wire
bundles." ..and ... "the inconvenience of stock, slot-head jack-screws."
{RESPONSE} He offers a screw handling solution here:
http://tinyurl.com/34nrdd5
I'd like to offer another solution -- use #4-40 machine screws with hex
socket (Allen wrench) drive heads. The hex socket drive head allows one to
manuever the small screws in a manner vastly superior to a straight slot or
phillips drive head screw.
See here for a source of such screws:
http://www.microfasteners.com/catalog/products/SSC.cfm
Here is just one source of tools for handling these screws:
http://www.bondhus.com/
Conventional Allen wrenches work fine for most handling of these screws, but
these Prohold tools will give even more control if needed:
http://www.bondhus.com/features/prohold/body-0.htm
'OC' Says: "The best investment we can make is the effort to gather and
PS: An aerospace vehicle with hex socket or Torx / six lobe / star drive
fasteners is much easier to work on than a vehicle with straight slot or
Phillips drive fasteners. See here for some handy tool kits to work with the
hex socket or Torx / six lobe / star drive fasteners:
http://www.chapmanmfg.com/
DO NOT ARCHIVE
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
