skyking76t(at)verizon.net Guest
Posted: Mon Oct 11, 2010 7:06 pm Post subject: External Tanks |
Could someone out there maybe help with a problem? I am preparing to transfer my newly acquired L-29 from Minnesota to Virginia. I am trying to install the external fuel tanks but can't get the hardpoint hooks to close on the support rods. I was told all that was needed was to push the support rods into the latches. When this is done, the hook closes around the rod but doesn't lock. As soon as pressure is released, the hooks springs open. Seems to be in the jettison position all the time.
We've tried all the switch combinations on the armament panel and still open. Checked all the right panel switches in the F/C and R/C and schematics but still no cigar. Could someone tell me how to set the hooks into the closed position? Only other solution is to put a bolt thru the mechansim to hold the hook in the closed position.
Another issue. Can the Czech NO2 and O2 bottles be hydro tested in the US and be DOT approved if they pass? I've heard they had to be replaced if they are removed from the aircraft. Is this correct or can they be hydro tested?
Any advise would be appreciated
Anthony
| | - The Matronics L29-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
ainut(at)knology.net Guest
Posted: Mon Oct 11, 2010 8:12 pm Post subject: External Tanks |
I wonder if a scuba dive shop would check those bottles? They check
scuba bottles, up to 5-7,000 psi routinely.
If you need a copilot for your MN to VA trip and can use a copilot with
zero hours jet time, I might be available. Depends on the time frame.
David
| Quote: | Could someone out there maybe help with a problem? I am preparing to
all the time.
Anthony
If you're an American, just say NO to the Obamanation, to socialism, and get rid of Soros.
bculberson(at)staraviatio Guest
Posted: Mon Oct 11, 2010 9:15 pm Post subject: External Tanks |
A few quick thoughts. Is the power on when you try to lock the control rods? It could be de-activated that way with a wiring change to the armament panel or a short somewhere grounding the solenoid for the release. If it locks with power off and releases with power on, that could be it. Mine has no ARM panel, but the connector is there, I rigged a safety switch so I could drop in emergencies.
O2 and Air bottles are the big elephant in the room no one wants to talk about. I tried all sorts of places, no ones willing to take liability for the inspection. My A&P "visually inspects" per the maintenance docs, but that's it. I've been thinking about replacing them with scuba and aircraft O2 tanks, haven't decided yet.
Bill
251 716 8119
SD737(at)aol.com Guest
Posted: Mon Oct 11, 2010 9:29 pm Post subject: External Tanks |
Aviation Classics in Reno, Nevada has a facility that will hydro the bottles.
775-972-5540 Ask for Lyn Jenkins.
They handle the L-39's and Migs.
In a message dated 10/12/2010 12:15:24 A.M. Central Daylight Time, bculberson(at)staraviation.com writes:
Bill
251 716 8119
Posted: Tue Oct 12, 2010 1:01 pm Post subject: External Tanks |
Hey David,
Wish I could accomodate you but I am taking an instructor along and this will be my training for the type rating. I had an LOA in 2000 but didn't change it to a type rating. So I have to do the training over. But I'll keep you in mind for the future.
Tony
--- On Tue, 10/12/10, David <ainut(at)knology.net> wrote:
Subject: Re: External Tanks
To: l29-list(at)matronics.com
Date: Tuesday, October 12, 2010, 12:12 AM
--> L29-List message posted by: David <ainut(at)knology.net (ainut(at)knology.net)>
I wonder if a scuba dive shop would check those bottles? They check scuba bottles, up to 5-7,000 psi routinely.
If you need a copilot for your MN to VA trip and can use a copilot with zero hours jet time, I might be available. Depends on the time frame.
David
| Quote: | Could someone out there maybe help with a problem? I am preparing to transfer my newly acquired L-29 from Minnesota to Virginia. I am trying to install the external fuel tanks but can't get the hardpoint hooks to close on the support rods. I was told all that was needed was to push the support rods into the latches. When this is done, the hook closes around the rod but doesn't lock. As soon as pressure is released, the hooks springs open. Seems to be in the jettison position all the time.
Anthony
-- If you're an American, just say NO to the Obamanation, to socialism, and get rid ; - The L29-List tp://www.matronics.com/Navigator?L29-List" target=_blank>http://www.matro &nbs;--> h=
| [quote][b]
Posted: Tue Oct 12, 2010 1:22 pm Post subject: External Tanks |
Bill,
We've tried with power on and power off. We can hear the hardpoints clicking, like they may be in the release mode but the hooks won't lock with the power on or off. Doug Weske of Air Investments said the power didn't need to be on...just shove the supports in. So we tried that..didn't work.
The owner took the armament panel out and just unplugged the cannon plug and removed the panel. We just plugged it back in and tried different switch positions. The ARM and Jettison switches have been tried as well as making sure the circuit breakers were on. I had a PhD in Electrical Engineering and a Mechanical Engineer working with me and we couldn't figure it out. So many interlocks.
Was hoping maybe someone else has had an issue like this and knew what to look at next.
Yeah, Virginia has never had an L-29 in the state and I had to make sure the local FSDO would sign off the inspection program and Ops Limitations before I bought it. They made sure I was made aware the tanks need to be changed if they were out of the hydro limit and removed . The 29's approved inspection program has in it to maintain with the DOT regulations so I was hoping to get by with a hydro test and hopefully pass, just to get the aircraft back to VA. Then I would just change out to scuba tanks.
Thanks for the inut.
Tony
540 320 7597
--- On Tue, 10/12/10, Bill Culberson <bculberson(at)staraviation.com> wrote:
From: Bill Culberson <bculberson(at)staraviation.com>
Date: Tuesday, October 12, 2010, 1:13 AM
Bill
251 716 8119
Posted: Tue Oct 12, 2010 1:24 pm Post subject: External Tanks |
Thanks for the info on the bottles!
Date: Tuesday, October 12, 2010, 1:25 AM
[quote] A few quick thoughts. Is the power on when you try to lock the control rods? It could be de-activated that way with a wiring change to the armament panel or a short somewhere grounding the solenoid for the release. If it locks with power off and releases with power on, that could be it. Mine has no ARM panel, but the connector is there, I rigged a safety switch so I could drop in emergencies.
Bill
251 716 8119
transmatch(at)aol.com Guest
Posted: Tue Oct 12, 2010 2:28 pm Post subject: External Tanks |
Contact me thru my private e-mail or by phone about the hydrostatic testing. It can be done.
Gene Freeman
N229DD
e-mail: transmatch(at)aol.com (transmatch(at)aol.com)
cell: 702-545-7313
delfin(at)mail.pf Guest
Posted: Tue Oct 12, 2010 2:53 pm Post subject: External Tanks |
The hard point for the release of external fuel tanks have to be mechanically re-armed with a special L-29 tool.
[b][i][b][i][b][i]Jean de Roubin
B. P. 8455
98 703 - FAA'A
Polynésie française
Tel : (+689)742620
Mail :[i] delfin(at)mail.pf (delfin(at)mail.pf)
[/i]
[/i][/b][/i][/b]
[/i][/b]
Le 12 oct. 2010 à 11:18, Anthony Royal a écrit :
Bill,
Tony
540 320 7597
--- On Tue, 10/12/10, Bill Culberson <bculberson(at)staraviation.com (bculberson(at)staraviation.com)> wrote:
From: Bill Culberson <bculberson(at)staraviation.com (bculberson(at)staraviation.com)>
To: l29-list(at)matronics.com (l29-list(at)matronics.com)
Bill
251 716 8119
Posted: Tue Oct 12, 2010 6:22 pm Post subject: External Tanks |
Thank you! Would you know of anyone in the US that would have such a tool? I need to have the drop tanks for the extra fuel to fly the 29 to it's new home.
Anthony
--- On Tue, 10/12/10, delfin(at)mail.pf <delfin(at)mail.pf> wrote:
Date: Tuesday, October 12, 2010, 6:51 PM
[b][i][b][i] [b][i]Jean de Roubin
B. P. 8455
98 703 - FAA'A
Polynésie française
Tel : (+689)742620
Mail : [i] delfin(at)mail.pf (delfin(at)mail.pf)
[/i]
[/i][/b][/i][/b]
[/i][/b]
Bill,
| [quote][b]
czech6(at)mesanetworks.ne Guest
Posted: Tue Oct 12, 2010 7:31 pm Post subject: External Tanks |
go to the hardware store, buy approx 1/4" box (square) steel pinch it together to form an oval. it will work.
Posted: Tue Oct 12, 2010 7:35 pm Post subject: External Tanks |
If you hang one tank with the power on, it releases automatically. Safety. You don't want to fly with one full tank hanging so it releases both. Just leave the power off until both hooks are in place.
Posted: Tue Oct 12, 2010 7:36 pm Post subject: External Tanks |
who did you buy it from?
Posted: Tue Oct 12, 2010 7:46 pm Post subject: External Tanks |
That's right, your the man...
ncam(at)wave.co.nz Guest
Posted: Tue Oct 12, 2010 9:24 pm Post subject: External Tanks |
If I was doing it again, I would replace the nitrogen and oxygen tanks with removable dive tanks, clipped in, and take them out and just get them refilled, lots of tyre shops use nitrogen, but I just used air in mine.Regards
Neville
On 13/10/2010, at 4:33 PM, Bill Geipel wrote:
[quote]who did you buy it from?
[quote]---
Posted: Wed Oct 13, 2010 7:00 am Post subject: External Tanks |
So, dry air can be used in place of the nitrogen? Great idea and cheaper too. Plenty of SCUBA shops around my area. I under stand they are 20 cu/ft tanks. Should be able to get aluminum tanks that are DOT approved and that solves the FAA problem.
Thanks!
Tony
Date: Wednesday, October 13, 2010, 1:16 AM
If I was doing it again, I would replace the nitrogen and oxygen tanks with removable dive tanks, clipped in, and take them out and just get them refilled, lots of tyre shops use nitrogen, but I just used air in mine. Regards
Neville
[quote] who did you buy it from?
Posted: Wed Oct 13, 2010 7:53 am Post subject: External Tanks |
Dry air is never dryer than Nitro. But it works.
Posted: Wed Oct 13, 2010 10:31 am Post subject: External Tanks |
Maybe better to stay with the nitrogen than dry air?
Date: Wednesday, October 13, 2010, 11:50 AM
Posted: Wed Oct 13, 2010 11:10 am Post subject: External Tanks |
I have used scuba air for the last 3 years and they guy that had it
before me used scuba seven years before that. I have spent some time
working on mine recently making sure it will hold air as long as
possible. In doing so, I have removed a check a number of components and
have had no corrosion to speak of. As long as it's DRY, I think that is
the most significant issue. I'd be curious to know what other L-29 guys
are using....
BTW, I found a pretty cool ultrasonic leak detector from Grainger that
is pretty amazing. It surprised me how many really small leaks I had.
Detector was so sensitive and found so many leaks (and one bad reducer)
that she will hold 70 bar for months at a time now...
Bill
[mailto:owner-l29-list-server(at)matronics.com] On Behalf Of Anthony Royal
Sent: Wednesday, October 13, 2010 1:27 PM
Posted: Wed Oct 13, 2010 11:31 am Post subject: External Tanks |
Bill,
Do you have the part number for the leak detector?
Tony
Subject: RE: External Tanks
Date: Wednesday, October 13, 2010, 3:09 PM
I have used scuba air for the last 3 years and they guy that had it before me used scuba seven years before that. I have spent some time working on mine recently making sure it will hold air as long as possible. In doing so, I have removed a check a number of components and have had no corrosion to speak of. As long as it’s DRY, I think that is the most significant issue. I’d be curious to know what other L-29 guys are using….
BTW, I found a pretty cool ultrasonic leak detector from Grainger that is pretty amazing. It surprised me how many really small leaks I had. Detector was so sensitive and found so many leaks (and one bad reducer) that she will hold 70 bar for months at a time now…
Bill
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of Anthony Royal
