Screws in Fiberglass
rwayne(at)gamewood.net
PostPosted: Sat Oct 16, 2010 12:10 pm    Post subject: Screws in Fiberglass Reply with quote
I need to mount a few things to the fiberglass top using screws (lights,
seatbelt holder, etc). What's the best way to do this? Thanks!
Wayne
N767W
pitts_pilot(at)bellsouth.
PostPosted: Sat Oct 16, 2010 12:44 pm    Post subject: Screws in Fiberglass Reply with quote
I have no idea what the best way is. Wink
What I do is embed a nut in milled fiber with the screw inserted. coat
the screw threads with petroleum jelly so you can get the screw out!!!
I do not like PK screws as they loosen up and if you insert/remove them
enough the hole will get bigger.
Linn
Wayne
N767W
Mauledriver(at)nc.rr.com
PostPosted: Sat Oct 16, 2010 12:52 pm    Post subject: Screws in Fiberglass Reply with quote
I've been using Nutserts pretty successfully. They work in aluminum
too but only recommended there instead of a sheet metal screw (e.g. gear
leg fairings into fuselage)
http://www.aircraftspruce.com/catalog/hapages/nutserts.php
the AAT916 expendable nutsert tool works fine for the number you'll need
to do:
http://www.aircraftspruce.com/catalog/topages/nutserttools.php
I haven't used them in an operational aircraft yet
Bill "wondering why everyone isn't using PreKote" Watson
Wayne
N767W
Lew Gallagher
PostPosted: Sat Oct 16, 2010 1:21 pm    Post subject: Re: Screws in Fiberglass Reply with quote
Hey Wayne,
It's not slick, but works. For the seat belt and headphone holder, I used these T nuts from Lowes or Home Depot: http://www.lowes.com/SearchCatalogDisplay?storeId=10151&langId=-1&catalogId=10051&N=0&newSearch=true&Ntt=t+nut
Drilled for the screw insert first, drilled tiny holes for the "ears" that keep it from turning, then glassed them in. Cover with headliner and you can't tell they're there.
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
ronrvbuilder(at)bigpond.c
PostPosted: Sat Oct 16, 2010 1:41 pm    Post subject: Screws in Fiberglass Reply with quote
Rivnuts worked well for me on the cabin top.
http://www.aircraftspruce.com/catalog/hapages/rivnuts.php
cheers,
Ron
VH-XRM flying in Oz
indigoonlatigo(at)msn.com
PostPosted: Sat Oct 16, 2010 3:48 pm    Post subject: screws in fiberglass Reply with quote
I held my custom overhead console with eight to ten SS screws that went into SS threaded inserts which I epoxied into the cabin top. If you have access to a sandblaster to etch the insert surface even better.
Here is only a link for showing what I am referring to:  [url=http://www.woodcraft.com/Product/2001048/1708/38-24-Brass-Threaded-Inserts-(10).aspx]http://www.woodcraft.com/Product/2001048/1708/38-24-Brass-Threaded-Inserts-(10).aspx[/url]
dave.saylor.aircrafters(a
PostPosted: Sun Oct 17, 2010 2:13 pm    Post subject: screws in fiberglass Reply with quote
There are lots of inserts you can use to put threads into a cored
structure. If you look around (or call me), you can get specialty
inserts made just for bonding into panels. For example, here's a
link:
http://www.gen-aircraft-hardware.com/viewImage.asp?item=NAS1832-3-3&folder=basic
T-nuts and other inserts work almost as well for a few screws here and
there. They take a little more fiddling to get them into the core and
secure, but they cost pennies as opposed to dollars for the inserts
above. Make sure the inserts are securely attached to the core and to
the skin, and test how well they attached by giving the insert a good
tug.
Keep in mind that inserts are for non-structural applications like
consoles, lights, belt and headset racks, etc. Anything that takes a
load like shoulder belts, cargo tie downs, etc., need a much stronger,
tested, engineered solution.
My overhead light console is attached with five very small sheet-metal
screws. It comes off very infrequently so I'm not too worried about
wearing out the holes. I could always push a little epoxy into the
hole if it stripped.
FWIW, I tried to get Vans to sell my overhead console, but they were
worried about the tiny holes in the inner skin of the cabin top. So
keep in mind that Vans isn't going to be happy about hearing that you
put holes in the cabin top. Personally, I'm not worried about what I
did to mine.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Sat, Oct 16, 2010 at 4:43 PM, John Gonzalez <indigoonlatigo(at)msn.com> wrote:
rwwende
PostPosted: Mon Oct 18, 2010 9:24 am    Post subject: screws in fiberglass Reply with quote
Dave,
Can you send me picures of how you attached your overhead console? What
does yours weigh? I just glassed mine in, but may want to reinforce with
screws.
Ross
PostPosted: Mon Oct 18, 2010 10:56 am    Post subject: screws in fiberglass Reply with quote
Ross,
Our console is basically a small pod that closes out the upper strut
attachment and gives you some room for lights, switches, etc. Here's
a picture:
http://www.aircraftersllc.com/products.htm
It's custom made for the 10 so it fits really well. I think it weighs
2 or 3 ounces.
If you glassed yours to the cabin I wouldn't worry about adding any screws.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Mon, Oct 18, 2010 at 10:19 AM, Ross Wendell
<rwendell(at)hydro-splash.com> wrote:
Dave,
screws.
Ross
PostPosted: Mon Oct 18, 2010 5:43 pm    Post subject: screws in fiberglass Reply with quote
Thanks everyone for the great ideas. I'm surprised of so many different
ideas.
Wayne
