ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Mon Oct 18, 2010 12:14 pm Post subject: New Video..... |
Hello All...
I went up today to try my new Sensenich prop and shot this short video..
enjoy,
http://www.youtube.com/watch?v=tCR4DcakaI8
chris ambrose
M3X/Jabiru
N327CS
Posted: Mon Oct 18, 2010 3:26 pm Post subject: New Video..... |
crankin'! loved Jimi too.
BB
On 18, Oct 2010, at 4:14 PM, ces308 wrote:
zeprep251(at)aol.com Guest
Posted: Mon Oct 18, 2010 3:33 pm Post subject: New Video..... |
Chris,
Do your exhaust gas temps always stay below 1200 at cruise?
G.Aman
ces308
Posted: Mon Oct 18, 2010 4:33 pm Post subject: Re: New Video..... |
Gary,
Yes...pretty much so...I will keep a closer watch and report..but usually what you see is what you get....not sure why more people don't go with the Jab ...
chris ambrose
M3X/Jabiru 151.6 hrs
N327CS
Thom Riddle
Posted: Tue Oct 19, 2010 3:41 am Post subject: Re: New Video..... |
Gary,
You didn't ask me, but I figured you might want to hear from other Jab owners too. My Jab stays pretty much under 1200F EGT most of the time in cruise. I do not have the economy tuning kit installed so under full power the EGTs regularly go above 1200F and sometimes as high as 1300F. I have a second Bing 94 carb with the economy tuning kit installed (newer carb) but have not bothered to try it out yet.
If it ain't broke don't break it.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Tue Oct 19, 2010 5:25 am Post subject: New Video..... |
Chris,
You must have solved the noise problem pretty well,the only draw back of the Jabiru in pusher mode.The inquiry about the temps was because of the low indications in the video.Mine run 1400-1425 with the factory install economy jetting.But my C model is slower by 10-15 mph than yours as well.At 2750 it burns less than 3 gph but only gives me about 70-75mph.Nice video by the way
G.Aman MK-3C Jabiru 2200A 595hrs
Posted: Tue Oct 19, 2010 5:34 am Post subject: New Video..... |
Tom,
Don't think I noticed the egt's on any of your pictures,but can't mistake the sound of the Jabiru.Have flown over the Niagara Falls area frequently heading up to Rice lake.It's been a few years so really enjoyed the Videos you posted.The noise level isn't bad in the videos.The aerodynamics of that airframe must be a lot cleaner than the Mk-3.
G.Aman
Thom Riddle
Posted: Tue Oct 19, 2010 5:43 am Post subject: Re: New Video..... |
Gary,
At 2700 rpm, the noise is not bad but starts getting a lot worse above 2800 rpm. The 64" diameter prop is a lot noiser than the shorter props at the same rpm. If I remember correctly, you and Chris both run 58" props on your Jabirus. I'm looking forward to flying a friend's Jab 2200 powered Sonex soon which has a 54" diameter prop. I expect that to be a lot quieter.
Buffalo, NY (9G0)
- Anonymous |
Posted: Tue Oct 19, 2010 6:25 am Post subject: New Video..... |
Thom Riddle
Tractors are always much quieter than pushers.
The tractor configured Kolb Flyer with Warp Drive taper tips was almost
stealth mode. Same engine/prop on a MKIII would blow you away.
Rock House, OR
_________________ John Hauck
Titus, Alabama |
