				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| sidsel.svein(at)oslo.onli Guest
				|  Posted: Thu Oct 21, 2010 1:24 am    Post subject: SV: Rotax fuel flow detection |   |
				| Graeme,
 I installed the Electronics International fuel flow instrument with
 differential module:
 http://www.buy-ei.com/Pages/FP-5P/FP-5P_Details.html
 One transducer measures flow to the carbs, another measures the return flow
 and the differential module sends the net flow data to the instrument.  I
 have used it for two years now, VERY pleased with its accuracy (easy
 comparison of fuel used shown by the instrument and quantity to top up the
 tank again). I have not done any recalibration. User friendly.  Easy to
 install.  I placed one transducer between the engine driven fuel pump and
 the right side carb, the other in the return line in the tunnel.
 Great instrument for determining fuel efficiency (range) under various
 conditions as you fly and showing remaining fuel.  Only thing to remember is
 to update the fuel quantity in the tank when you start the engine if you
 have refueled since last flight - flashing light on the instrument reminds
 you to do this.
 Svein
 LN-SKJ
 -----Opprinnelig melding-----
 Fra: owner-europa-list-server(at)matronics.com
 [mailto:owner-europa-list-server(at)matronics.com] På vegne av graeme bird
 Sendt: 21. oktober 2010 10:37
 Til: europa-list(at)matronics.com
 Emne: Rotax fuel flow detection
 Just sorting the fuel system on my new build. I am considering including an
 RS type flow sensor for future use but what confuses me on the 912 install
 is that some of the fuel comes back which would make the reading useless
 unless a return sensor was also fitted. This is the reason my fuel
 calculator in my C42 is worse than useless. Any advice appreciated.
 Graeme Bird
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| rampil
				|  Posted: Thu Oct 21, 2010 4:21 am    Post subject: Re: SV: Rotax fuel flow detection |   |
				| the return fuel rate in the 912s is tiny.
the 914 is on the other hand a significant fraction of total flow
 Ira N224XS
		| Back to top |  |
				|  Posted: Fri Oct 22, 2010 10:38 am    Post subject: SV: Rotax fuel flow detection |   |
				| Remi,
 At first sight, your proposal may look like the obvious solution.  With
 respect, however, I think it is not to be recommended for 912ULS
 installations (I do not know enough about 914 to comment on that engine).
 Contrary to what seems to be a common assumption, the return flow through
 the restrictor is not insignificant - it is roughly 10 litres per hour (i.e.
 roughly half of the net cruise consumption, or roughly 1/3 of the fuel going
 to the engine is flowing back to the tank).  The reason for this relatively
 high surplus circulation is of course to reduce the time the fuel is exposed
 to heat before it reaches the carbs, by increasing the flow velocity through
 the fuel line.  According to the build manual, the return line branches off
 at the point farthest from the pump, just before the left side carb
 (assuming the fuel line goes from the pump to the right side of the engine
 with a short branch off to the right carb, and from there across the back of
 the engine to the left carb).
 Moving the return line branch-off upstream (closer to the pump) increases
 the risk of vapour forming in the fuel lines downstream from this branch-off
 point.  By how much, I do not know, but maybe it is critical under
 unfavourable circumstances.  "Maybe's" under the cowling are not nice - - -
 Svein
 LN-SKJ
 [mailto:owner-europa-list-server(at)matronics.com] På vegne av Guerner Remi
 Sendt: 22. oktober 2010 19:53
 Til: Europa-List Digest Server
 Thank you Ian for posting the LAA mod.
 I have not installed a fuel flow in my aircraft but if I had to, I would use
 the attached schematic which allows measuring the flow to the carbs with a
 single sensor, therefore improving accuracy and reliability and reducing
 cost.
 The same principle can be used for the 914. In that case the single flow
 sensor would be installed between the pressure regulator and the carbs.
 Remi Guerner
 F-PGKL
		| Back to top |  |
				|  Posted: Sat Oct 23, 2010 3:09 am    Post subject: SV: Rotax fuel flow detection |   |
				| Remi,
 The Rotax manual shows a principle, not one that is optimal for all actual
 installations.  Different aircraft will have different under-the-cowl
 arrangements, different cool air flows under the cowl, etc.  Europa shows
 another arrangement, which of course is better but I cannot say by how much
 or whether it will matter. The difference in fuel tube length at high vs low
 flow velocity is small, and if the tube is placed in a heat shield the
 increase in vapour lock risk may be acceptable.
 Svein
 Sendt: 23. oktober 2010 10:44
 Svein,
 I basically agree with what you wrote. However  my proposed schematic
 is very close to the one recommanded (and optionally  supplied) by
 Rotax in the 912 Install Manual (see attached). This arrangement works on
 most LSAs so I do not see why it would not work with the addition of the
 fuel flow sensor as propsed.
 Remi Guerner
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
