kearney
Posted: Thu Oct 21, 2010 4:51 pm Post subject: Rudder Pedal Mounting |
Hi
I was wondering what the list consensus is regarding using the forward or after rudder pedal mounting holes.
What are people using and are you happy with the location. For those who answer this query, it would also be useful to know your height to see if there is a correlation.
Inquiring minds need to know…
Les
#40643 [quote][b]
Bob Turner
Posted: Thu Oct 21, 2010 5:23 pm Post subject: Re: Rudder Pedal Mounting |
Disclaimer: my -10 is not yet flying.
I am 5'6" and put the pedals in the aft position. I've sat in the seat, with the foam in place, and I'm glad I didn't put them forward.
_________________ Bob Turner
RV-10 QB |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Thu Oct 21, 2010 5:36 pm Post subject: Rudder Pedal Mounting |
I put mine aft. I am 5-10. I have flown Scotts plane and his is in the forward position. I can use either location it just seemed more centered on the track for me in the aft position.
On Oct 21, 2010, at 18:48, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Hi
Les
#40643
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
philperry9(at)gmail.com Guest
Posted: Fri Oct 22, 2010 6:34 am Post subject: Rudder Pedal Mounting |
6' 2" and forward for me.
Just a tip as you get to this section. See this thread.
http://www.vansairforce.com/community/showthread.php?t=57070&highlight=kerf
Phil
On Thu, Oct 21, 2010 at 8:23 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote] --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=316628#316628
le, List Admin.
partner14
Posted: Fri Oct 22, 2010 6:51 am Post subject: Rudder Pedal Mounting |
I also put mine forward. I'm 6'.... I added rudder pedal extensions for my wife... at 5' 1", it wouldn't have mattered whether they were mounted foreward or aft, she would have needed extensions anyway.
Don McDonald
--- On Fri, 10/22/10, Phillip Perry <philperry9(at)gmail.com> wrote:
Quote: |
Subject: Re: Re: Rudder Pedal Mounting
Date: Friday, October 22, 2010, 7:28 AM
Phil
Quote: | --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
le, List Admin.
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
40636 |
Tim Olson
Posted: Fri Oct 22, 2010 7:25 am Post subject: Rudder Pedal Mounting |
Ditto...it's a height dependent decision.
I am 6'1" and going Forward was the way to go for me
for sure. I needed extensions on the pedals for my
wife, who's 5'2".
I would look at who your primary pilots are and adjust
it accordingly. Not sure where the break-point is, but
I've had people who were 5'6"-5'7" do fine in the plane.
Certainly by 5'9-10" you should be able to go forward.
The side benefit of forward pedal position is it
allows your seat to also be a little forward, giving
you a little C.G. boost to the forward position, giving
you a slightly increased margin for carrying baggage.
I would not want to have to sit 2" further aft in
my plane, because I pile in the baggage pretty
good. I need all the margin I can get.
In fact, I would actually recommend before you close
up the area under the panel, fit a seat and rails,
and mount the pedals, and try it for yourself. If
you can reach the pedals in the forward position,
I'd recommend going for it. If not, then move the
pedals aft.
At 6'1", I have PLENTY of room and can move my
seat back quite a bit, so taller people will
do well in this plane. Also, at 6'1", I have my
seat moved back a good 2-4" I think from forward
position...so I have some good margin to move
it forward if I need.
But in general, I'd recommend to look at your own
height, and that of the primary pilots, and then
make your decision...favoring the forward position
when possible, to allow you to keep your C.G.
as forward as possible. THIS PLANE IS NOT NOSE
HEAVY when you travel. In fact, on our trips,
the C.G. moves aft so far that on rotation, you have
to make very sure to not be as aggressive on the
rotation, because it is much more sensitive...and
on roll-out, I can hold the nose up even down
to 10-15mph sometimes. You don't want to build
a plane to be less noseheavy if possible. Remember
that the RV-10 is an X/C plane....it's built to
carry baggage. If you want to carry ballast (I
don't need to), to help with the flare when
empty, then great...but don't build it with the
idea of trying to move the C.G. aft...that would
be a mistake.
On 10/22/2010 9:49 AM, Don McDonald wrote:
Quote: | I also put mine forward. I'm 6'.... I added rudder pedal extensions for
Don McDonald
<http://www.vansairforce.com/community/showthread.php?t=57070&highlight=kerf>
Phil
<http://us.mc537.mail.yahoo.com/mc/compose?to=bobturner(at)alum.rpi.edu>>
forward.
Bob Turner
RV-10 QB
le, List Admin.
rene(at)felker.com Guest
Posted: Fri Oct 22, 2010 7:56 am Post subject: Rudder Pedal Mounting |
I am 5"9" and used the aft position. I fly with the seat in the third
detent (2" to 3" inches back?). I am with Tim, set the pedals for the
primary pilot.
Also, you can made minor adjustments with the length of the interconnect
between the rudder cables and the pedals......
Rene' Felker
N423CF
801-721-6080
