BEBERRY(at)aol.com Guest
Posted: Sat Apr 29, 2006 1:37 am Post subject: (no subject) |
My alternator (generator) has always been a bit reluctant to come on line
and would only do so at quite high revs. The little red light has now decided
to stay on all the time and no amount of reving and switch throwing will
induce it to go out.
Before I start to strip out all the gubbins between me and the generator to
get at the thing, can anyone help by suggesting where I should look first for
a possible minor faulty connection or whatever.? Initial searches have been
non productive.
Thanks.
Patrick G PUDS 914
nwcmc(at)tiscali.co.uk Guest
Posted: Sat Apr 29, 2006 2:48 am Post subject: (no subject) |
I assume we are talking about a Rotax engine? The first check is to
confirm it is not an indication problem. If the voltage at the regulator
output is less than 13 volts at say 3000rpm the generator is not working
as it should. If so the most likely culprit is the regulator. If
possible borrow someone else's regulator to see if the fault disappears.
This is an easy task and would only take a few minutes. Be sure the
grounding connection to the regulator is good otherwise it can do damage
to the regulator.
If the regulator is not the problem and the output is still low then the
generator coils or wiring from them to the regulator are at fault.
Hope this helps.
Nigel Charles
Posted: Sat Apr 29, 2006 1:07 pm Post subject: (no subject) |
............................I assume we are talking about a Rotax engine?
to the regulator.
Thanks Nigel - I will take your advice.
Patrick
SPurpura(at)aol.com Guest
Posted: Sun Apr 30, 2006 6:26 pm Post subject: (no subject) |
VOLTAGE REGULATOR
