KR86 42b ADF
Skillet
PostPosted: Mon Nov 01, 2010 7:26 am    Post subject: KR86 42b ADF Reply with quote
I have a King KR86 with the 42B antenna. the24' cable has been cut.
Can I splice it back together or cut it to 15'. The manual instructs; Do not change cable length. King offered the cable (at) either 24' or 15'.
Where the 15' and 24' cables identical other than length?
The part #'s for the 15' and 24' differ only by the last letter/digit.
Thank You
PostPosted: Mon Nov 01, 2010 12:44 pm    Post subject: KR86 42b ADF Reply with quote
either 24' or 15'.
Those fixed length cables were designed
to present a certain capacitance to critically
tuned circuits within the receiver. If I
recall correctly, the "coaxial" cable wasn't
really an impedance-matched material . . . the
center conductor was a very fine wire compared
to the inside diameter of the shield. I suspect
that the material for both cables is the same
and the 15' cable has a capacitor added inside
one of the connector shells to compensate for
the shorter cable's lower capacitance.
Just an educated guess.
Suggest you splice it with a minimum removal
of original cable.
Skillet
PostPosted: Mon Nov 01, 2010 6:10 pm    Post subject: Re: KR86 42b ADF Reply with quote
Thanks that was helpful.
Brian
