Lenny Iszak
Posted: Tue Nov 02, 2010 2:54 pm Post subject: headrest foam |
Does anyone know if the front seat headrest foam came with the kit or not?
I can't find them anywhere...
Lenny
Tim Olson
Posted: Tue Nov 02, 2010 3:07 pm Post subject: headrest foam |
It did I'm pretty sure.
On Nov 2, 2010, at 5:54 PM, "Lenny Iszak" <lenard(at)rapiddecision.com> wrote:
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Nov 02, 2010 3:35 pm Post subject: headrest foam |
Yep
On Nov 2, 2010, at 16:54, "Lenny Iszak" <lenard(at)rapiddecision.com> wrote:
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Lenny Iszak
Posted: Tue Nov 02, 2010 4:30 pm Post subject: Re: headrest foam |
Then I'll just have to look for them some more.
Thanks!
Lenny
Bob Turner
Posted: Tue Nov 02, 2010 5:13 pm Post subject: Re: headrest foam |
You should have 4 pieces for each seat: cushion and seat back, plus the headrest and a lumbar support (which gets glued to the seat back at a location depending on your body). If I remember right these last two were together in one plastic bag.
_________________ Bob Turner
RV-10 QB |
Lenny Iszak
Posted: Tue Nov 02, 2010 6:12 pm Post subject: Re: headrest foam |
Just found them tucked away in the hangar. For some reason I only kept the bottom and the back cushions at home to play with.
Thanks!
Lenny
| Bob Turner wrote: | | You should have 4 pieces for each seat: cushion and seat back, plus the headrest and a lumbar support (which gets glued to the seat back at a location depending on your body). If I remember right these last two were together in one plastic bag. |
philperry9(at)gmail.com Guest
Posted: Wed Nov 03, 2010 4:56 am Post subject: headrest foam |
Yep. Mine was bundled in a bag with the lumbar inserts. Each seat should be made up of 4 pieces. I wonder if you are missing the lumbar supports too? On Nov 2, 2010 5:59 PM, "Lenny Iszak" <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:> --> RV10-List message posted by: "Lenny Iszak" <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)>
| Quote: | Does anyone know if the front seat headrest foam came with the kit or not?
Lenny
e Builder's Bookstore www.buildersbooks.com
com/contribution">http://www.matronics.com/contribution
ad, 7-Day Browse, Chat, FAQ,
> http://www.ma=====
> http://forums.matronics.com
