headrest foam
Lenny Iszak
PostPosted: Tue Nov 02, 2010 2:54 pm    Post subject: headrest foam Reply with quote
Does anyone know if the front seat headrest foam came with the kit or not?
I can't find them anywhere...
Lenny
Tim Olson
PostPosted: Tue Nov 02, 2010 3:07 pm    Post subject: headrest foam Reply with quote
It did I'm pretty sure.
On Nov 2, 2010, at 5:54 PM, "Lenny Iszak" <lenard(at)rapiddecision.com> wrote:
Lenny
http://forums.matronics.com/viewtopic.php?p=317912#317912
Strasnuts
PostPosted: Tue Nov 02, 2010 3:35 pm    Post subject: headrest foam Reply with quote
Yep
Lenny
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
Lenny Iszak
PostPosted: Tue Nov 02, 2010 4:30 pm    Post subject: Re: headrest foam Reply with quote
Then I'll just have to look for them some more.
Thanks!
Lenny
Bob Turner
PostPosted: Tue Nov 02, 2010 5:13 pm    Post subject: Re: headrest foam Reply with quote
You should have 4 pieces for each seat: cushion and seat back, plus the headrest and a lumbar support (which gets glued to the seat back at a location depending on your body). If I remember right these last two were together in one plastic bag.
Bob Turner
RV-10 QB
Lenny Iszak
PostPosted: Tue Nov 02, 2010 6:12 pm    Post subject: Re: headrest foam Reply with quote
Just found them tucked away in the hangar. For some reason I only kept the bottom and the back cushions at home to play with.
Thanks!
Lenny
philperry9(at)gmail.com
PostPosted: Wed Nov 03, 2010 4:56 am    Post subject: headrest foam Reply with quote
Yep.  Mine was bundled in a bag with the lumbar inserts.  Each seat should be made up of 4 pieces.  I wonder if you are missing the lumbar supports too? On Nov 2, 2010 5:59 PM, "Lenny Iszak" <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:> --> RV10-List message posted by: "Lenny Iszak" <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)>
Lenny
http://forums.matronics.com/viewtopic.php?p=317912#317912<==========
= the Contribution link below to find out more about
e Builder's Bookstore www.buildersbooks.com
com/contribution">http://www.matronics.com/contribution
ad, 7-Day Browse, Chat, FAQ,
> http://www.ma=====
