				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| kheindl(at)msn.com Guest
				|  Posted: Tue Nov 02, 2010 4:44 pm    Post subject: Engine not turning over |   |
				| Hi,
 I found myself stranded with an engine that would not start. There was only a click from the relay, but no movement up front. I got the aircraft home on my trailer, it was to be my last flight this season anyway.
 I assume it is a broken sprag clutch. Has anyone got experience in that area ? My question is: does it require removal of the engine ?
 I removed the starter motor and it checks out okay. Hand turning the prop is also no problem.
 Appreciate any advice.
 Karl
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| kingsnjan(at)westnet.com. Guest
				|  Posted: Wed Nov 03, 2010 12:36 am    Post subject: Engine not turning over |   |
				| Karl,
 Sounds like you might have a flat or faulty battery to  me.  Have you tested the battery under load?
 Kingsley in Oz
 [quote]   ---
		| Back to top |  |
		| ptag.dev(at)tiscali.co.uk Guest
				|  Posted: Wed Nov 03, 2010 1:43 am    Post subject: Engine not turning over |   |
				| Hi! Karl
It sounds like a starter solenoid not passing current to the starter. Automotive /agricultural solenoids could be parted out and the contact washer rotated to remake contact.
 Otherwise probably the ground circuit to the engine is inadequate or even not passing electricity.
 Certainly not the sprag clutch the other end of the engine !
 Assuming you have taken Kingsley’s advice.?
 Bob Harrison G-PTAG
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Kingsley Hurst
 Sent: 03 November 2010 08:27
 Subject: Re: Europa-List: Engine not turning over
 Karl,
 Kingsley in Oz
		| Back to top |  |
		| gregoryf.flyboy(at)comcas Guest
				|  Posted: Wed Nov 03, 2010 2:44 am    Post subject: Engine not turning over |   |
				| Karl,
 If the battery checks out (and no loose connections), then check the  output of the clicking solenoid to verify it is supplying power to the  starter.  The contacts may have moved apart due to melted plastic, or they  could be corroded, etc. There should be voltage to the starter,  when the solenoid is clicked on.
 Greg Fuchs
 ______________________
 Hi,
 Karl
		| Back to top |  |
				|  Posted: Wed Nov 03, 2010 2:47 am    Post subject: Engine not turning over |   |
				| Oops, just saw this advice, or would not have sent it out,  since mine is just the same...
 From: owner-europa-list-server(at)matronics.com  [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Robert C  Harrison
 Sent: Wednesday, November 03, 2010 2:37 AM
 To:  europa-list(at)matronics.com
 Subject: RE: Engine not turning  over
 Hi!  Karl
 Bob Harrison  G-PTAG
 Karl,
 Kingsley in Oz
		| Back to top |  |
				|  Posted: Wed Nov 03, 2010 4:03 am    Post subject: Engine not turning over |   |
				| Thanks for all replies. I was hoping for a simple explanation but:I tried using a booster battery from the airport and bypassed the solenoid with a jumper cable. The engine was turning over fine just seconds before this. Cable connections to the engine case and motor were tight. So I'm puzzled by all this.
Karl
 Date: Wed, 3 Nov 2010 03:45:05 -0700
 .ExternalClass .ecxshape {;}       (at)page Section1 {size:612.0pt 792.0pt;} .ExternalClass P.ecxMsoNormal {font-family:'Times New Roman';font-size:12pt;} .ExternalClass LI.ecxMsoNormal {font-family:'Times New Roman';font-size:12pt;} .ExternalClass DIV.ecxMsoNormal {font-family:'Times New Roman';font-size:12pt;} .ExternalClass A:link {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass SPAN.ecxMsoHyperlink {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass A:visited {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass SPAN.ecxMsoHyperlinkFollowed {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass P {font-family:'Times New Roman';margin-left:0cm;font-size:12pt;margin-right:0cm;} .ExternalClass PRE {font-family:'Courier New';font-size:10pt;tab-stops:45.8pt 91.6pt 137.4pt 183.2pt 229.0pt 274.8pt 320.6pt 366.4pt 412.2pt 458.0pt 503.8pt 549.6pt 595.4pt 641.2pt 687.0pt 732.8pt;} .ExternalClass SPAN.ecxEmailStyle19 {font-family:Arial;color:navy;} .ExternalClass SPAN.ecxSpellE {;} .ExternalClass SPAN.ecxGramE {;} .ExternalClass DIV.ecxSection1 {page:Section1;}    Oops, just saw this advice, or would not have sent it out,  since mine is just the same...
 Hi!  Karl
 Bob Harrison  G-PTAG
 Subject: Re: Engine not turning  over
 Karl,
 Kingsley in Oz
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
