kearney
Posted: Wed Nov 03, 2010 12:01 pm Post subject: O2 / Headset Connections |
Hi
I read in a recent post about plumbing heatset / O2 connectons into an overhead consol. I still have this option but would like some real world insight before I make the plunge. Has anyone done this yet? Where seems to be the best location for the connecions? Is it much of a distraction for the rear seat passengers?
Inquiring minds need to know
Les
#40643 [quote][b]
Kelly McMullen
Posted: Wed Nov 03, 2010 12:27 pm Post subject: O2 / Headset Connections |
I know you Canadians have some of the most innovative ways to keep
warm, but plug-in heat sets? Rear seat pax will be distracted if you
are warm and they are cold.
How much do you want hanging off the ceiling? You will already have
shoulder belts. Headset wires and O2 hoses as well? Everyone has
differing missions. I don't expect to carry backseat pax and go to O2
altitudes. My only debate is where to put front seat jacks to keep
them out of way of seat belts, stick, etc. O2 will likely be on tunnel
between rear seats so I can reach valves on cylinder.
On Wed, Nov 3, 2010 at 12:58 PM, Les Kearney <kearney(at)shaw.ca> wrote:
| Quote: | Hi
>>> I read in a recent post about plumbing heatset / O2 connectons into an<<<<
A&P/IA, EAA Tech Counselor
KCHD |
Deems Davis
Posted: Wed Nov 03, 2010 1:17 pm Post subject: O2 / Headset Connections |
Les, I plumbed the O2 connections (distribution block) into the overhead console: http://deemsrv10.com/album/Sec%20The%20Home%20Stretch/slides/DSC06124.html (click forward for 5 pics).
The position is such that for the pilot and copilot the O2 is behind the heads and out of the way, with easy access to control. For the rear seaters its an easy access, but does cause some plumbing to hang in front of them. It was a trade-off, easy installation by having a single distribution point, versus convienience and aesthetics, by placing each O2 in their armrest/panel. I can say that in 2 years and 200+ hours, I've not needed or used O2 for rearseaters.
WRT the headphones, I wouldn't even consider putting them in the overhead console.
Deems
On 11/3/2010 12:58 PM, Les Kearney wrote: [quote] O2 / Headset Connections
Hi
Les
#40643 [b]
kearney
Posted: Sun Nov 07, 2010 6:38 am Post subject: O2 / Headset Connections |
Hi Deems
Thanks for the opinion. In the absence of any compelling reason to put them above, I think I'll take your suggestion and move the headset connections elsewhere. I may put my O2 lines above, however, as I would like to keep the O2 away from anything that carries hydrocarbons (which means the tunnel etc). For some reason they don't coexist too well.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis
Sent: November-03-10 3:14 PM
Subject: Re: O2 / Headset Connections
Deems
Hi
Les
#40643
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
kearney
Kelly
Sure make fun of my typing. Then again, perhaps this worth a look:
http://www.seatheaters.ca/products.php
Cheers
Les
Kelly McMullen
Posted: Sun Nov 07, 2010 7:46 am Post subject: O2 / Headset Connections |
I know Les. Just figured you had drafted your message without
remembering to deburr it be for sending 8^) and yes, like I said,
Canuckistan has the best vehicle heating products around. Every engine
heater, battery heater, interior heater, etc that we used in
Alaskistan was imported from Canuckistan.
In case you wondered, I am going a bit crazy, spending 6 weeks doing
an annual on my Mooney(which required substantial sheet metal work
fabricating some new engine baffles, among other things) while waiting
even longer for my finish kit to arrive. I am certain you know the
feeling.
Kelly
KCHD |
Posted: Sun Nov 07, 2010 9:33 am Post subject: O2 / Headset Connections |
I like having the headset jacks preferably on the panel but in any
case somewhere that they can be easily seen and touched in flight.
Headset seem take more attention than most builders anticipate. Once
a headset quits working (yours or a passengers) it's pretty easy to
get distracted trying to fix it.
The new Bose/Zulu style connectors are a lot better than the old
two-pronged approach. They lock more positively and rarely
disconnect. They could be retrofitted to any headset.
My jacks are on the outboard sides of the panel (for the front seats)
and admittedly don't provide the most convenience for entry and exit.
But it's workable and easy to deal with in flight.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
| Quote: | Hi
Les
#40643
Posted: Sun Nov 07, 2010 10:10 am Post subject: O2 / Headset Connections |
I was going to mount my jacks on left/right lower panel (need to fill
those holes!), but since I'm going to hang headsets on my overhead
plenum when not in use, I mounted them on the tunnel covers between the
seats.
Linn
On 11/7/2010 12:27 PM, Dave Saylor wrote:
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Wed, Nov 3, 2010 at 12:58 PM, Les Kearney<kearney(at)shaw.ca> wrote:
> Hi
> Les
> #40643
