rlborger(at)mac.com Guest
Posted: Sun Apr 30, 2006 6:01 am Post subject: VOR Aerial/Antenna |
Peter,
If you go to my build page (URL in signature block), thence to Year
#3, Q1 2004 and on to page 2, you can see how I installed both of my
Nav antennas. One is installed in the aft lower fuselage, the second
in the overhead area above the baggage bay. Each antenna served both
VOR, Localizer and Glideslope through a Bob Archer splitters located
behind the instrument panel (see Year #3, Q3, page 6, bottom of the
page). I run all my antenna cables down the port side and all my
electrical wiring down the starboard side.
I bet you could use a copper tape NAV antenna mounted across the
fuselage floor or roof behind the baggage bay. It would probably be
easier to install. Especially if you spend some extra USD or GBP and
go for one of those nice ones already made up with a BNC connector
built in. You might even splurge for two of them and have a separate
VOR/LOC antenna (upper) & GS antenna (lower) and forget the splitter.
Good building and great flying,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(85%) tail kit done, wings closed, cockpit module installed, pitch
system in, landing gear frame in, rudder system in with Singleton
Mod, outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing
incidence set, tie bar in, flap drive in, Mod 70 done, baggage bay
in. Completing the firewall-aft fuel system and fitting the
instrument panel. Working in - 24 Instrument Panel, 25 Electrical,
28 Flaps, 29 Main Gear, 30 Fuel System, 32 Tail, 34 Door Latches & 35
Doors, 37 Finishing. Preparing for ROTAX 914 installation.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
