				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| peter.rees01(at)tiscali.c Guest
				|  Posted: Sat Apr 29, 2006 2:13 pm    Post subject: VOR Aerial / Antenna |   |
				| Gents
 I'm looking at installing a VOR / ILS receiver in G-MFHI and am looking for
 some advice on a suitable aerial. Spruce have some which look like long thin
 strips with a BNC in the centre - easy enough to bond into the back of the
 fuse. The Bob Archer ones they offer also look pretty good but as they are
 designed for horizontal mounting, may be a bit harder to mount in the back
 without having to build a platform over the rudder cables etc.
 Can anyone who has installed a VOR please let me know what aerial / antenna
 you've used and any opinions about it.
 I believe that the instrument I'm going to fit (Narco 122) has a marker
 beacon receiver built in - any ideas as to a suitable aerial for this would
 also be appreciated.
 Peter
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| rholder(at)avnet.co.uk Guest
				|  Posted: Sat Apr 29, 2006 11:28 pm    Post subject: VOR Aerial / Antenna |   |
				| Peter Rees wrote:
  	  | Quote: |  	  | I'm looking at installing a VOR / ILS receiver in G-MFHI and am looking for some advice on a suitable
 into the back of the fuse. The Bob Archer ones they
 offer also look pretty good but as they are designed
 in the back without having to build a platform over the
 rudder cables etc.
 what aerial / antenna you've used and any opinions
 about it.
 122) has a marker beacon receiver built in - any ideas
 as to a suitable aerial for this would also be
 appreciated.
 I have 3 Bob Archer antennae in G-OWWW. The COM and NAV
 are the thin strips and I have the "two sided printed
 circuit board" Transponder antenna.
 G-OWWW is (mainly) a Classic and the wings were closed
 when purchased.
 The COM antenna is placed vertically just behind the fuel
 filler on the starboard side. The NAV antenna is placed
 across the top of the fuselage. It is perfectly OK for the
 ends of the ali strips to be bent out of the horizontal plane.
 Remember the COM antenna must be vertical and the NAV
 horizontal as these are the orientation of the radio waves !
 The NAV antenna will provide VOR and Localiser
 information. The Glideslope in a ILS is different
 altogether and needs  extra kit.
 HTH
 Richard
 G-OWWW High Cross
		| Back to top |  |
		| carl(at)flyers.freeserve. Guest
				|  Posted: Sun Apr 30, 2006 12:21 am    Post subject: VOR Aerial / Antenna |   |
				| VOR/ ILS
 We have a single aerial for the VOR/ ILS and the VOR works fine. We havent
 had the opportunity to test the ILS ever. Its a copper tape dipole aerial
 mounted horizontally inside the rear fuselage og the AC. (I have loads of
 spare copper tape if you want to experiment).
 Personally I cant see the point of having ILS (or VOR) these days on an
 aircraft like a Europa. GPS does the same job better and its even possible
 to have pseudo ILS on your GPS receiver that will be nearly as accurate.
 My understanding is that unless you can test and callibrate your ILS
 receiver you could never rely on it in a real life situation.
 I have
		| Back to top |  |
		| acrojim(at)cfl.rr.com Guest
				|  Posted: Sun Apr 30, 2006 5:20 am    Post subject: VOR Aerial / Antenna |   |
				| Peter
 I have the XS Monowheel. We installed all Bob Archer Antenna's in our
 Europa. The VOR antenna was installed overhead in the cockpit-baggage area
 at the suggestion of Bob Archer. We have a Narco Nav 122 VOR / ILS and this
 combination is working very well for us over the past 6years.
 Jim Brown
 N398JB
		| Back to top |  |
		| europa flugzeug fabrik
				|  Posted: Sun Apr 30, 2006 6:16 am    Post subject: Re: VOR Aerial / Antenna |   |
				|  	  | carl(at)flyers.freeserve. wrote: |  	  | Personally I cant see the point of having ILS (or VOR) these days on an aircraft like a Europa. GPS does the same job better and its even possible to have pseudo ILS on your GPS receiver that will be nearly as accurate.
 My understanding is that unless you can test and callibrate your ILS receiver you could never rely on it in a real life situation.
 The NAV-122 has a very good reputation, and they are not cheap here even on eBay -- "working when removed."
  An approach plate in visual conditions on an ILS tests everything.
 A GPS with approaches, with WAAS (vertically guided approaches) is really expensive, for just emergency use or keeping a rating current, if that's the intent.  If I ever got caught in unforecast conditions and needed a quick approach clearance, the GPS is the last thing I'd like to fiddle with to get set up, whilst conversing with Approach Control.  Plus, w/o WAAS, the GPS approaches may not give you much for minimums.  We got one here at the home field which is 1100 feet, a/k/a VFR!
 Fred F.
		| Back to top |  |
				|  Posted: Sun Apr 30, 2006 6:38 am    Post subject: Re: VOR Aerial / Antenna |   |
				|  	  | peter.rees01(at)tiscali.c wrote: |  	  | Spruce have some which look like long thin strips with a BNC in the centre... |
 That is a plain dipole, but compromised in providing one length for COM and NAV.  Straight legs are not ideal either.  However, the negative effect probably isn't much, and copper tape may not be much different, unless each cut and tuned to mid-band with a VSWR meter.
  	  | Quote: |  	  | I believe that the instrument I'm going to fit (Narco 122) has a marker beacon receiver built in - any ideas as to a suitable aerial for this would also be appreciated. |
 A "boat" type marker antenna would be the easiest route.  The NAV-122 has more than enough sensitivity for this compromised device.
 For GS antenna, I would make a dipole by splitting the end of RG-58 coax, 7.5" each of shield and center conductor.  Find a place somewhere on the plastic instrument panel which works in testing.  Like behind the flat part of the right side of the panel, provided a big battery isn't on the other side.
 Fred F.
		| Back to top |  |
		| paul.mcallister
				|  Posted: Sun Apr 30, 2006 10:18 am    Post subject: VOR Aerial / Antenna |   |
 Peter,
 I have a Narco 122 installed in my Europa.  I have a single whip antenna for
 the Marker Beacon and a Bob Archer VOR Antenna mounted in the roof.  I use a
 splitter for the glideslope antenna.
 Unlike Jim Brown's, mine works "just okay".  I seem to have a distinct lack
 of localizer sensitivity, although the VOR woks fine.  I haven't invested a
 lot of time in debugging it and I suspect at the end of the day it probably
 won't be an antenna location issue.
 An alternative location is the wing, although it means you have one more
 cable to connect / disconnect when you install / remove the wings.  You will
 also need to give some thought as to how service the antenna, for example if
 you have to replace the coaxial cable.
 As far as the comments about GPS / WAAS, at this time I am not bought in.
 WAAS enabled approach certified GPS units are expensive.  I have an Apollo
 GX60 approach certified box, and yes, they are cool but there can be an
 awful lot of button pushing going on compared to a LOC/GS or a VOR/Alpha
 approach.
 Regards,  Paul
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
