philperry9(at)gmail.com Guest
Posted: Sat Oct 30, 2010 3:26 pm Post subject: Airflow control on the Oil Cooler |
Quick question as I'm doing some planning.
What's the general consensus on the need for a push/pull baffle to control airflow to the oil cooler on the RV-10?
Have some of the folks had issues at altitude with cold oil temps? I'm pretty sure some of the ground ops in the northern states have reported issues with cooler temps.
I'm wondering if I should dedicate a spot on the panel for the push/pull cable.
Phil
Robin(at)PaintTheWeb.com Guest
Posted: Sat Oct 30, 2010 3:55 pm Post subject: Airflow control on the Oil Cooler |
When you don’t have it and you need it you have few options.
It really allows you to optimize oil temps. Better now than later.
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Phillip Perry
Sent: Saturday, October 30, 2010 4:17 PM
Subject: Airflow control on the Oil Cooler
Phil
= Use the Matronics List Features Navigator to browse[/b] | [/b][/quote] Day Browse, Chat, FAQ,[/b]w.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV1[/quote] =======================[/b][/quote] m">http://forums.matronics.com[/b][/quote] -Matt Dralle, List A; http://www.matronics.com/contribution[/b][/quote] =======================[/b] [/quote]
Checked by AVG - www.avg.com
amekler
Posted: Sat Oct 30, 2010 4:55 pm Post subject: Airflow control on the Oil Cooler |
I live in New Hampshire and I think it is not a necessity but nice to have.
Alan
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Saturday, October 30, 2010 7:53 PM
Subject: RE: Airflow control on the Oil Cooler
Robin
Phil | Quote: | | = Use the Matronics List Features Navigator to browse |
Day Browse, Chat, FAQ, | Quote: | | w.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV1 |
m">http://forums.matronics.com -Matt Dralle, List A; [/b] [/quote]0123456789 | Quote: | | = Use the Matronics List Features Navigator to browse | 0 | Quote: | | = Use the Matronics List Features Navigator to browse | 1 | Quote: | | = Use the Matronics List Features Navigator to browse | 2 | Quote: | | = Use the Matronics List Features Navigator to browse | 3 | Quote: | | = Use the Matronics List Features Navigator to browse | 4 | Quote: | | = Use the Matronics List Features Navigator to browse | 5 | Quote: | | = Use the Matronics List Features Navigator to browse | 6 | Quote: | | = Use the Matronics List Features Navigator to browse | 7 | Quote: | | = Use the Matronics List Features Navigator to browse | 8
CyberDefender has scanned this email for potential threats.
Version 2.0 / Build 4.03.29.01
Get free PC security at http://www.cyberdefender.com [quote][b]
partner14
Posted: Sat Oct 30, 2010 6:29 pm Post subject: Airflow control on the Oil Cooler |
I love it.... made my own... 95% of the time, you tell me the oil temp you want, and I can deliver it. I found that without it in the winter time you may not be able to get your oil temp much over 160 degrees.... if that. With it, you can dial in 180 on the same day with the same conditions.
Don
--- On Sat, 10/30/10, Phillip Perry <philperry9(at)gmail.com> wrote:
Date: Saturday, October 30, 2010, 4:16 PM
Phil
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
40636 |
Posted: Mon Nov 01, 2010 5:55 am Post subject: Airflow control on the Oil Cooler |
I'm torn in my mind as to whether it is necessary or not. Really, the vernatherm in the engine should control the temperature of the oil to what it needs to be by allowing or not allowing oil to go through the cooler (just like the thermostat in your car). On very cold days in the northern states, the small amount of oil that is allowed to go through the cooler to keep the oil from congealing in the cooler might be enough to keep the temperatures down, so blocking the airflow could likely cause a difference there. Also, for the same reason, on cold days it could allow you to get your oil temperatures up before takeoff so you don't have to run so long on the ground. My main question is, what happens if the cable becomes disconnected during flight, especially on a warm day. If the valve is designed in a way that it will stay open, then I wouldn't be concerned, but if it could possibly close or, even worse, get jammed in the closed position, then I would be very careful in making the decision whether or not to install it.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Oct 30, 2010, at 7:16 PM, Phillip Perry wrote:
[quote]Quick question as I'm doing some planning.
Phil
| [b]
Posted: Mon Nov 01, 2010 6:45 am Post subject: Airflow control on the Oil Cooler |
I have a butterfly oil cooler air valve in my 8A, and am putting one in the 10 as well. I found it very useful to get oil temps up to 180 in the wintertime.
Jesse makes some good points. Some thoughts:
<![if !supportLists]>- <![endif]>As we know, the veratherm valve does not stop oil flow through the cooler, it just opens a bypass for oil to go around the cooler as well as through it. I found that on cold days there was still enough oil flow through the cooler to keep temps well below 180 degrees.
<![if !supportLists]>- <![endif]>On the issue of the air valve sticking shut, I designed the butterfly valve such that some air still got to the cooler even with the valve fully shut. Another thought is if the valve sticks shut, you probably had it shut because it was a cold day so you should be ok to make a convenience landing someplace to fix it. In cruise on cold days with the valve fully shut I get 180 degrees. I never had the valve stick (open or shut).
<![if !supportLists]>- <![endif]>Oil pre-heat is a must on cold days. I have the electric strips that bond to the sump that Van’s sells. They work very well and I recommend them. I plug them in an hour or two before takeoff, longer on really cold days. DO NOT leave them plugged for prolonged periods as they will allow the moisture driven off from the oil to condense on the cooler engine parts higher up (e.g. cam shaft).
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Monday, November 01, 2010 9:53 AM
Subject: Re: Airflow control on the Oil Cooler
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Phil
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com/">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/contribution |
0123456789 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 4 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 5 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 6 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 7 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 8 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 9 | Quote: | | href="http://forums.matronics.com/">http://forums.matronics.com | 0 | Quote: | | href="http://forums.matronics.com/">http://forums.matronics.com | 1 | Quote: | | href="http://forums.matronics.com/">http://forums.matronics.com | 2 | Quote: | | href="http://forums.matronics.com/">http://forums.matronics.com | 3 | Quote: | | href="http://forums.matronics.com/">http://forums.matronics.com | 4
partner14
Posted: Mon Nov 01, 2010 6:47 am Post subject: Airflow control on the Oil Cooler |
I made my butterfly valve easy to remove.. so that is what I have done in the past... remove it in the summer months.... also, I made the butterfly smaller than the openning by 1/4" to 3/8" so that if it were to fall off the shaft and lodge itself in the scat, there would still be airflow... the ole "ask me how I know" statement applies here.... when that did happenned, it was in the winter and the oil temps were perfect, so I didn't mess with it for a couple of weeks. Since then I changed how it's mounted so it should never come loose again.
Don McDonald
--- On Mon, 11/1/10, Jesse Saint <jesse(at)saintaviation.com> wrote:
Date: Monday, November 1, 2010, 6:52 AM
Jesse Saint
C: 352-427-0285
F: 815-377-3694
| Quote: | Quick question as I'm doing some planning.
Phil
ollow target=_blank>www.aeroelectric.com
/" rel=nofollow target=_blank>www.buildersbooks.com
ofollow target=_blank>www.homebuilthelp.com
40636 |
Posted: Thu Nov 04, 2010 6:44 am Post subject: Airflow control on the Oil Cooler |
Along the same lines, are there any pireps regarding Van's oil cooler vs others that are out there?
Phil
rleffler
Posted: Thu Nov 04, 2010 8:59 am Post subject: Re: Airflow control on the Oil Cooler |
There seems to be a preference for the AirFlow Performance 2006X. Recalling stories from the RV-10 HQ at OSH, I believe that it keeps temps lower 10-15 degrees. But since I'm not flying yet, I have no first hand knowledge.
bob
_________________ Bob Leffler
N410BL - Phase I
Posted: Thu Nov 04, 2010 9:31 am Post subject: Airflow control on the Oil Cooler |
Does anybody have a link for the people who sell the butterfly valve for the -10?
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Lew Gallagher
rleffler
Posted: Thu Nov 04, 2010 2:48 pm Post subject: Airflow control on the Oil Cooler |
Nonstopaviation.com and it's resold by Avery too.
bob
N410BL - Phase I
