		rrh(at)rrhoyt.com Guest
				 Posted: Thu Nov 04, 2010 9:42 am    Post subject: Restarting a Stored 912ul |
				The engine ran fine when it was removed from the aircraft. It was
 prepared for storage according to Rotax operating instructions about 4
 years ago. I can't get it to restart when remounted on an aircraft.
 There is fuel in the float bowls. The A and B mag switches ground the
 mag circuits at the junction on the engine. The starter provides 250 rpm
 and maximum fuel pressure around 5 psi. The throttle is at minimum and
 the choke is on maximum.
 The carburetor throats are dry after cranking the engine enough to get
 50 psi of oil pressure. (The filters were removed)
 I would like to verify that the ignition is working before I rebuild the
 carburetors.  Is there a safe/recommended way (Propeller avoidance) to
 verify the spark at the plugs?
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rickofudall
				 Posted: Thu Nov 04, 2010 1:22 pm    Post subject: Restarting a Stored 912ul |
				Ron, Yes there is. Get an inline ignition spark checker and plug it into a spark plug wire between the wire and the plug. The checker has a nice bright light and is easy to see in all but the brightest mid day sun. Harbor Freight has them (pn 36258) as does Sears, Snap On, Matco, etc. HF sells them for about $3. Snap on for about $20. The rest are some place in between.
 Rick Girard
 On Thu, Nov 4, 2010 at 12:38 PM, Ron Hoyt <rrh(at)rrhoyt.com (rrh(at)rrhoyt.com)> wrote:
  	  | Quote: | 	 		   --> RotaxEngines-List message posted by: Ron Hoyt <rrh(at)rrhoyt.com (rrh(at)rrhoyt.com)>
  The engine ran fine when it was removed from the aircraft. It was prepared for storage according to Rotax operating instructions about 4 years ago. I can't get it to restart when remounted on an aircraft.
  There is fuel in the float bowls. The A and B mag switches ground the mag circuits at the junction on the engine. The starter provides 250 rpm and maximum fuel pressure around 5 psi. The throttle is at minimum and the choke is on maximum.
  The carburetor throats are dry after cranking the engine enough to get 50 psi of oil pressure. (The filters were removed)
  I would like to verify that the ignition is working before I rebuild the carburetors.  Is there a safe/recommended way (Propeller avoidance) to verify the spark at the plugs?
  om" target="_blank">www.aeroelectric.com
  ooks.com" target="_blank">www.buildersbooks.com
  et="_blank">www.homebuilthelp.com
  le, List Admin.
  -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
  http://forums.matronics.com
 Zulu Delta
 Kolb Mk IIIC
 582 Gray head
 4.00 C gearbox
 3 blade WD
 Thanks, Homer GBYM
 It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
   - G.K. Chesterton
		rickofudall
				 Posted: Thu Nov 04, 2010 1:27 pm    Post subject: Restarting a Stored 912ul |
				Dang, hit the send button while my brain was in neutral. I did my 582 up with misting oil and followed the directions for all the rest. The idle passages in the carbs still plugged up with gelled fuel. Once they were cleaned out the engine started and idled like a champ.
 Rick
 On Thu, Nov 4, 2010 at 4:15 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
  	  | Quote: | 	 		   Ron, Yes there is. Get an inline ignition spark checker and plug it into a spark plug wire between the wire and the plug. The checker has a nice bright light and is easy to see in all but the brightest mid day sun. Harbor Freight has them (pn 36258) as does Sears, Snap On, Matco, etc. HF sells them for about $3. Snap on for about $20. The rest are some place in between.
 Rick Girard
  le, List Admin.
 Zulu Delta
 Kolb Mk IIIC
 582 Gray head
 4.00 C gearbox
 3 blade WD
 Thanks, Homer GBYM
   - G.K. Chesterton
 Zulu Delta
 Kolb Mk IIIC
 582 Gray head
 4.00 C gearbox
 3 blade WD
 Thanks, Homer GBYM
   - G.K. Chesterton
		Thom Riddle
				 Posted: Fri Nov 05, 2010 4:49 am    Post subject: Re: Restarting a Stored 912ul |
				There was no mention that you removed the plugs and cleaned them after storage. Every time I've stored an engine according to manufacturer's instructions, I had to clean the plugs thoroughly to get it started. AND that is all I had to do if it was running fine before storage.
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
				 Posted: Fri Nov 05, 2010 7:05 am    Post subject: Restarting a Stored 912ul |
				Richard
 Thanks for the info. I thought there was something like that.
 Tom
 I pulled a plug and it was Carmel colored and dry. I will clean all the
 plugs and see if it works.
 Ron
  between.
  Rick Girard
 > is on maximum.
