biglar
Posted: Fri Apr 28, 2006 2:57 pm Post subject: Kolb/Harley/0-200 |
In all serious-ness, I gave heavy thought to the 0-200 when I started all
this, because you're right - it's got the torque without the reduction
drive, it's bulletproof, (or very close to it) many of them out
there.......(uh - not really - read on) simple, etc., etc. Then I found
that there is an 0-200A which is what you'll find all over, on Cessna 150's,
etc. We would want the 0-200B which apparently has the thrust bearing area
machined differently for a pusher application. Never did really chase after
one, but haven't ever noticed one, either. I believe they're quite rare.
Then I talked to Klaus at Lightspeed Aviation, who is using the 0-200A with
pleasure and success on his Long EZ's. (I think) Go figure.
Lar. Do not Archive.
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
N78LB Vamoose
www.gogittum.com
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
jadamson
Posted: Fri Apr 28, 2006 3:52 pm Post subject: Re: Kolb/Harley/0-200 |
Here's a link to the company that seems to be the forerunner of the Skyray link referred to in another post: http://www.hog-air.com/hogindex.htm
He used to show some performance specs but I couldn't find 'em since Skyray's now in the picture. As I recall, though, he was running the engine at a fairly high RPM (3500+) to get the good HP/Torque values. Which is a lot higher than I run on the highway in my Geezer Glide.
HD's Evo and TwinCam engines are a heckuva lot more reliable than the Shovels (still the best sounding HD engine, IMO). And, the reduction drive is no more than the standard HD primary case turned vertical. Plus fuel injection, if you want it. On the downside, I'm not sure if dual ignition is available or not.
As for weight. gotta be sure we're comparing apples to apples. 205 lbs all up, including mount, etc. Comparing to the Corvair (and 0-200) and to quote William Wynne (FlyCorvair.com), "I have a lot of data that shows the Corvair has an installed flying weight of about 225-230 lbs. .... This is slightly below the installed weight of a typical O-200 Continental.".
For the cost difference, "user base" and experience with the engine, I'm liking the VW more & more.
Just my 2 pesos' worth to add to the confusion ...
John A
jindoguy(at)gmail.com Guest
Posted: Fri Apr 28, 2006 7:39 pm Post subject: Kolb/Harley/0-200 |
Klause has a Varieze that he's been modifying for years. O2BAD pulls almost
140 HP from the O-200 and gets a top speed in excess of 240 Kts.
150's,
area
after
with
Larry Bourne
Palm Springs, CA
N78LB Vamoose
www.gogittum.com
Posted: Sat Apr 29, 2006 8:41 am Post subject: Kolb/Harley/0-200 |
I tried to talk to Kolb about a 0-200 or some other GA engine a few years
ago. All they would say is "way too heavy". My VW is something like 170 +or-
10 pounds or a whole lot less than a 0-200 or Corvair and I think the VW
it's kind of at the limit for the big Kolbs.
Again my $.02
Rick Neilsen
Redrive VW powered MKIIIc
biglar
Posted: Sat Apr 29, 2006 1:01 pm Post subject: Kolb/Harley/0-200 |
Yah, for sure they're quite a bit heavier, but I've never really been sure
of just what that affects. Let's say you've got a Mk III with a 190# pilot
and a 220# engine. Next to it, an identical (??) Mk III with a 220# pilot
and a 190# engine. Seems to me they should fly the same, assuming
horsepower, etc. are the same. I know, I know, if the 190# pilot had a Mk
III with a 190# engine, he'd certainly see a benefit, but if weights are
equal, performance should be equal..........or am I missing something ??
Larry Bourne
Palm Springs, CA
N78LB Vamoose
www.gogittum.com
Palm Springs, CA
"Vamoose" |
Richard Pike
Posted: Sat Apr 29, 2006 1:17 pm Post subject: Kolb/Harley/0-200 |
I think what you are missing is - It ain't the flying that causes
problems, it's the unplanned sudden stops. Did you see the accident
pictures of the MKIII Xtra that Norm passed away in? When the airplane
pancaked in, the weight of the 912 collapsed the upper fuselage tubes
and the 912 moved down and forward. Not a good thing. That is probably
the reason why Kolb will not approve heavier engines. But if I were in
their shoes, I wouldn't specify the "why" of the details either...
Therefore - even though I have had six Corvairs over the years, and
found the engines to be smooth and bulletproof (although the cars always
rusted - Body by Fisher - salt included - no extra charge) my MKIII
won't ever have a Corvair engine. Too heavy. A Rotax 582 sitting up 3'
behind my head is light enough that if things go really bad, maybe it
will stay 3' up behind my head...
Richard Pike
MKIII N420P (420ldPoops)
Larry Bourne
Palm Springs, CA
N78LB Vamoose
www.gogittum.com
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Sat Apr 29, 2006 1:26 pm Post subject: Kolb/Harley/0-200 |
Leaving CG concerns aside, crush factor could be a limitation.
The upper cage is built to withstand a reasonable downward/forward
force in a crash. 220# might cause some damage not foreseen.
Moving the pilot's position 10" forward would help, along with more
beefing of structure. A MkIII already aint no "ultralight" even though
that's what folks on the ground think they are looking at.
Might better design a whole new plane for the O-200.
-BB do not archive
sure
pilot
pilot
a Mk
are
Larry Bourne
Palm Springs, CA
N78LB Vamoose
www.gogittum.com
Posted: Sat Apr 29, 2006 1:41 pm Post subject: Kolb/Harley/0-200 |
| -BB do not archive
Bob B/Gang:
Heard something similar not too long ago. The aircraft should be
designed around the engine.
Maybe that is what Homer Kolb did, rather than design the airplane,
then go out and try to find a power plant to make it
go.................
_________________ John Hauck
Titus, Alabama |
Posted: Sat Apr 29, 2006 3:29 pm Post subject: Kolb/Harley/0-200 |
Speaking of alternative engines, I actually made my first flight of
the season
before May. This evening I did a little tour about the neighborhood.
My seat belt must have shrunk a little over the winter but I squoze it
down
anyway. Glad it was snug as I did get lifted once out of the seat.
It was a combo joyride and test of the new oil cooler. Being only 60F
it wasn't too necessary but it didn't leak. Little suzuki ran smooth
and cheap. Felt good.
-BB do not archive
On 29, Apr 2006, at 5:42 PM, John Hauck wrote:
| -BB do not archive
Bob B/Gang:
go.................
Posted: Sat Apr 29, 2006 5:33 pm Post subject: Kolb/Harley/0-200 |
Ok Lar
Try this one on. I have a 600lb. MKIIIc and some of this weight is not due
to the VW but anyway it is 600lbs. I weigh 220lbs. I add 60lbs. of fuel and
now I'm having to be very careful how much passenger weight I can add. I
beefed up my wings and have jury struts so I have raised my max gross weight
to 1050lbs. but that only gives me 170lbs. for passenger weight.
If you were to put a 0-200 on the same airplane and the engine weighed 80lbs
more you would have only have 90lbs available for passengers. If you wanted
to stay at the factory recommended max weight you would truly have a single
passenger airplane. And that's not taking into account any CG issues.
See we can have fun even if were not talking about Vamoose.
Rick Neilsen
biglar
Posted: Sat Apr 29, 2006 5:49 pm Post subject: Kolb/Harley/0-200 |
Yah, OK, that would make a difference, wouldn't it ?? Even tho' we don't
PLan on those sudden stops, it's best to keep the possibility in mind.
Do not Archive.
Larry Bourne
Palm Springs, CA
N78LB Vamoose
www.gogittum.com
Palm Springs, CA
"Vamoose" |
biglar
Posted: Sat Apr 29, 2006 5:57 pm Post subject: Kolb/Harley/0-200 |
Yah, thinking useta be fun.......lately it's starting to hurt, then I lose
track. Hope it's not a trend. Do not Archive.
Larry Bourne
Palm Springs, CA
N78LB Vamoose
www.gogittum.com
Palm Springs, CA
"Vamoose" |
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Sun Apr 30, 2006 9:07 am Post subject: Re: Kolb/Harley/0-200 |
| Richard Pike wrote: |
I think what you are missing is - It ain't the flying that causes problems, it's the unplanned sudden stops. |
Richard,
I think that you have this right. Even a hard landing could possibly bend the cage with a heavy enough engine. Same for Firestars. More weight up high could increase the chance turning up-side-down. Mark III's don't seem to have that problem, though.
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
