Covering up the contactors
james(at)etravel.org
PostPosted: Fri Nov 05, 2010 5:04 pm    Post subject: Covering up the contactors Reply with quote
Gents,
I have three contactors mounted on the engine side of the firewall,
along with a battery. Everything else (regulator, busses, etc.) is
inside the cabin. Is there any value in covering up my contactors, or
are they alright as they are?
Many thanks,
James
PostPosted: Fri Nov 05, 2010 9:07 pm    Post subject: Covering up the contactors Reply with quote
At 08:01 PM 11/5/2010, you wrote:
Gents,
Here's the firewall of an A36 Bonanza.
http://aeroelectric.com/Pictures/Wiring_Technique/A36_Firewall_A.jpg
http://aeroelectric.com/Pictures/Wiring_Technique/A36_Firewall_B.jpg
with contactors, fuseblocks, current limiters, etc
hung out in behind Continental and everybody.
I think your electro-whizzies will be fine without
extra-ordinary cover.
PostPosted: Sun Nov 07, 2010 10:41 am    Post subject: Covering up the contactors Reply with quote
Thanks for that Bob. Even after a couple of years on the firewall in
the hangar, the contactors are already quite dull. They're not
corroded, as I put some Vaseline (petroleum grease) on them and the
various connections.
That Bonanza certainly looks pristine! Is there a trick to keeping
everything so sparkling?
James
On 6 November 2010 05:04, Robert L. Nuckolls, III
> Gents,
PostPosted: Sun Nov 07, 2010 5:02 pm    Post subject: Covering up the contactors Reply with quote
I took that on the production line . . . so it's a sure
bet that the 'shine' goes away after a few years. But
shine doesn't help the electrons get from point-A to
point-B. The gas tight joint and designing switching
devices to meet service life in the proposed application
side steps the lack of luster.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
