Posted: Tue Nov 09, 2010 10:25 am Post subject: instrument sub-panels |
I'd very much appreciate counsel tempered by experience on the
desireable thickness of aluminum sheet for the instrument sub-panels.
I've used some .040" 6061-T6 which was laying around, but I've
concluded it's way too thin.
Many thanks,
Fred
Rocketman
Posted: Tue Nov 09, 2010 1:26 pm Post subject: instrument sub-panels |
Fred, .063 works fine in Baby Blue. .080 is good, too, but heavier and,
in my opinion, not necessary...
Jeff
On 11/9/2010 12:14 PM, Fred Klein wrote:
I've used some .040" 6061-T6 which was laying around, but I've concluded
it's way too thin.
Many thanks,
Fred
david steade
Posted: Wed Nov 10, 2010 1:14 am Post subject: instrument sub-panels |
Fred
I used .080" (2mm) seemed about right . After I cut all the holes there is not much left and the panels have to support a lot of weight after they are populated.
David Steade
_________________ David Steade |
Posted: Wed Nov 10, 2010 2:41 am Post subject: instrument sub-panels |
On 11/10/2010 10:02 AM, Steade wrote:
| Quote: | I used .080" (2mm) seemed about right . After I cut all the holes there
they are populated.
I used 2mm too. Keep in mind that my panel is much larger than the
standard Europa panel; if it works for me it should work for you too. It
is true that after the holes are cut the panel appears weakened, but
populating the panel stiffens it up considerably. Actually it is more
rigid than before, as the instruments have less tendency to bend and
flex than the aluminium sheet itself.
I used one horizontal T-shaped stiffener reduxed in halfway down the
panel. The panel is strong enough to support all instruments, but I made
an additional support at the rear of my electrical gyro because of its
length and thus leverage.
I operate the Europa mainly from a bumpy soft field, transport the
Europa for every flight over the road on its trailer, so it sees a lot
of vibration and bumps. So far, after nearly 100 hours, the panel is
holding up very well with no signs of fatigue.
Frans
paul.the.aviator(at)gmail Guest
Posted: Wed Nov 10, 2010 5:14 am Post subject: instrument sub-panels |
Fred,
If you want something with a real "cool factor" you can use carbon fiber sheet. Take a look at http://www.dragonplate.com/default.asp
Paul
On Tue, Nov 9, 2010 at 12:14 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
[quote] --> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)>
I'd very much appreciate counsel tempered by experience on the desireable thickness of aluminum sheet for the instrument sub-panels.
I've used some .040" 6061-T6 which was laying around, but I've concluded it's way too thin.
Many thanks,
Fred
Posted: Wed Nov 10, 2010 9:46 am Post subject: instrument sub-panels |
Thanks to all who've responded to my question...wow!...the world of
carbon fiber is something to behold...a tad spendy...easy to see why
our airframes are FG instead of CF...looks like .080" alum. would
serve me well...
Fred
