		dwight purdy
				 Posted: Sun Apr 30, 2006 9:25 am    Post subject: tail spring |
				I have finally experienced the rudder stopping power of the dreaded broken
 tail spring.
    Is anyone selling them for the model II? Have a fly-in this weekend I
 hate to miss.
 dwight
 No virus found in this outgoing message.
 Checked by AVG Anti-Virus.
 Version: 7.1.385 / Virus Database: 268.5.1/327 - Release Date: 4/28/2006
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ dwight
model II |
		kr2(at)earthlink.net Guest
				 Posted: Sun Apr 30, 2006 11:33 am    Post subject: tail spring |
				testing my email,sorry no tail spring here
				 Posted: Sun Apr 30, 2006 12:01 pm    Post subject: tail spring |
		dwight purdy
				 Posted: Sun Apr 30, 2006 1:20 pm    Post subject: tail spring |
				Way to break my heart?
                        Dwight
model II |
		clemwehner(at)sbcglobal.n Guest
				 Posted: Sun Apr 30, 2006 4:34 pm    Post subject: tail spring |
				Dwight,
 A friend of mine, John Perry, (who is on this list) had a new spring for
 his model II made locally at a spring shop. Cost him about $75 to have
 an exact duplicate made. Interestingly, the shop guy told him the
 original spring as supplied by Denney Aerocraft was not spring steel but
 cheap steel about like you'd find on a farm implement.
 You might try that approach if you can find a metal shop who works with
 spring steel.
 Clem
 Lawton, OK
 KFIV-912
		dwight purdy
				 Posted: Sun Apr 30, 2006 6:41 pm    Post subject: tail spring |
				Do not know if the one I broke was original or not. The break sure looked
 like something hard. I personally had over 500 hours on it. I am a
 machinist and could play around but do not want to take a chance of ruining
 the rudder.
                           Thanks Dwight
 At 07:31 PM 4/30/2006 -0500, you wrote:
 Dwight,
 spring steel.
 Clem
 Lawton, OK
 KFIV-912
model II |
		Jim Shumaker
				 Posted: Sun Apr 30, 2006 8:41 pm    Post subject: tail spring |
				Dwight
   I had a tailspring break and bought a tailspring out of Aircraft Spruce.  Specifically, the 06-14500 for homebuilts.  I had to redrill one end, cut off some extra length and belt sand the width to fit my Maule tailwheel.  But it only required about an hour to modify and fit up.
   Jim Shumaker
 clemwehner <clemwehner(at)sbcglobal.net> wrote:
 Dwight,
 spring steel.
 Clem
 Lawton, OK
 KFIV-912
  _________________ Jim Shumaker |
				 Posted: Sun Apr 30, 2006 9:27 pm    Post subject: tail spring |
				Bad steel?  That might explain some of the earlier
 breaks.  SS might not have known.
 Kurt S.
 --- clemwehner <clemwehner(at)sbcglobal.net> wrote:
  	  | Quote: | 	 		   Dwight,
  about $75 to have
  told him the
  implement.
  shop who works with spring steel.
  Clem
  Lawton, OK
  KFIV-912
 Do You Yahoo!?
 Tired of spam?  Yahoo! Mail has the best spam protection around
 http://mail.yahoo.com
		shoeless(at)barefootpilot Guest
				 Posted: Mon May 01, 2006 3:01 am    Post subject: tail spring |
				Contact John McBean at http://www.sportplanellc.com/
 I helped him with the dimensions for a steel tailwheel spring last year and
 I'm flying with the prototype, it's purrrfect. I know that he had made a
 small batch of them and might have some left.
 Stay away from the aluminum springs! I broke two of them.
 Cliff
		Ben-PA
				 Posted: Mon May 01, 2006 5:03 am    Post subject: tail spring |
				That's interesting, Cliff. I went to a spring maker here to get a steel =
 spring and he told me that aluminum is better than steel for springs and =
 that the big trucks are using aluminum.
 Ben
  _________________ Sign up on the Kitfox Frappr Map:
http://www.frappr.com/kitfox
You can see where fellow Kitfoxers live and pictures of their planes. Be sure to post some pictures of you, your plane, or share the scenery of the Kitfox world. |
		janderson412(at)hotmail.c Guest
				 Posted: Mon May 01, 2006 10:50 am    Post subject: tail spring |
				Cliff, did your springs break due to normal flexing or was it because a weak
 point was created from the spring rubbing on the steel mount/bolts? Heat
 treated aluminum alloy is being used very successfully in many arenas now
 days (spring main gear) but must be softly mounted to stop any chance
 abrasion. John A.
 From:  "Clifford Begnaud" <shoeless(at)barefootpilot.com>
 Reply-To:  kitfox-list(at)matronics.com
 To:  <kitfox-list(at)matronics.com>
 Subject:  Re: tail spring
 Date:  Mon, 1 May 2006 04:57:26 -0600
 Cliff
				 Posted: Mon May 01, 2006 12:18 pm    Post subject: tail spring |
				I think that the problem with using aluminum for a tailwheel spring is the
 way it concentrates the bending force in a small area. I think that the
 aluminum there gets work hardened and brittle. In our main landing gear the
 bending forces are spread out so there is no hardening. I'm not the only
 person to break these aluminum tailwheel springs, beware!
 Cliff
 Ben
				 Posted: Mon May 01, 2006 12:25 pm    Post subject: tail spring |
				John,
 See my other post. The flexing occurs at the bend, this is where it breaks.
 Keep in mind that this happened on two model 5's that I've owned. The
 heavier kitfoxes put more load on the spring than do the earlier models.
 Also, the aluminum spring is very stiff, I never did like the damned thing.
 The 3 leaf steel spring that John McBean made for me is so much nicer. It's
 heavier, but I needed some weight back there anyway. Models 2,3 and 4 could
 probably work fine with only a 2 leaf steel spring.
 Cliff
 abrasion. John A.
 Cliff
		ruebd(at)skymail.csus.edu Guest
				 Posted: Mon May 01, 2006 1:29 pm    Post subject: tail spring |
				Dear fellow Kitfoxers:
 	It strikes me as absurd to use aluminum for a multi leaf spring.
 I suppose the motivation for doing this is weight savings, but the metal
 cannot be a good choice due to it's natural characteristic to work
 harden when flexed to that extent.  Those of us who are flying Foxes
 with heavier power plants actually need some weight back there, so we
 certainly wouldn't want to trade high modulus, spring steel for work
 hardening aluminum, cause the result is tail dragging to an extent we
 really do not want, not to mention the clutter that we would distribute
 on the runway when it breaks.
 	Did Skystar actually supply aluminum springs with the kits, and
 if so on what models?
 Duane Rueb
		wliles(at)bayou.com Guest
				 Posted: Tue May 02, 2006 3:24 pm    Post subject: tail spring |
				I think the aluminum springs were aftermarket.
 The earlier steel springs also had a bit of a problem.  The bend in the
 spring was not gradual, but very sharp, a perfect stress riser and
 guaranteed to eventually break.
 Jerry Liles
 Rueb, Duane wrote:
 Duane Rueb
		Kevin Schlosser
				 Posted: Wed May 03, 2006 8:07 am    Post subject: Re: tail spring |
				I bought this same spring and easily modified as described below to fit - works great on my Model 3
  	  | Jim Shumaker wrote: | 	 		  Dwight
   Jim Shumaker
 Dwight,
 spring steel.
 Clem
 Lawton, OK
 KFIV-912
