		Don Pfeiffer
  Joined: 10 Nov 2010 Posts: 3 Location: Poplar Grove airport
				 Posted: Thu Nov 11, 2010 6:14 am    Post subject: Windows and hysol |
				Can anybody recall what the problem was in using hysol for the rv 10 windows
				 Posted: Thu Nov 11, 2010 7:37 am    Post subject: Windows and hysol |
				On 11/11/2010 9:11 AM, dapb37(at)aol.com (dapb37(at)aol.com) wrote:      	  | Quote: | 	 		  Can anybody         recall what the problem was in using hysol for the rv 10 windows
       | 	       If you are referring to a Hysol epoxy, the issue is that epoxy does     really adhere well to plexiglass.
				 Posted: Thu Nov 11, 2010 8:40 am    Post subject: Windows and hysol |
				Don’t know.  I used Hysol EA 9394 (the product used for Lancair windows) with just a little flox mixed in to thicken it.  I also put a couple of bids of medium glass over the glued section on the outside.  While this adds strength to the install, my main reason for the glass was to prevent the paint cracking around the window that I noticed on some RV-10s, and to better blend the windows with the canopy top.  Make sure you use 32 or so grit paper to rough up the glass.  Talking to Lancair builders, this is the most common mistake made – not preparing the glass to work with the Hysol.
 I recognize the added glass will make window replacement harder, but I suspect replacement with all but the Silpruf install method will screw up the paint anyway.
 I know another very nice RV-10 that used 3M Scotch Weld Adhesive (available at Aircraft Spruce), again with a little flox mixed in as needed.  I used this product on the control surface trailing edge as well as to adhere the NACA ducts.  It is a good product.
 Carl
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of dapb37(at)aol.com
 Sent: Thursday, November 11, 2010 9:11 AM
 Subject: Windows and hysol
 Can anybody recall what the problem was in using hysol for the rv 10 windows 	  | Quote: | 	 		  |  <======================</     -- Please Support Your Lists This Month nbsp;    (And Get Some AWESOME FREE    November is the Annual List Fund Raiser.  Click below to find out more Free Incentive Gifts bsp;    * AeroElectric www.aeroelectric.com<www.buildersbooks.comwww.homebuilthelp.comhttp://www.matronic================= | 	  http://forums.matronics.com[/url]=====[/b][b]
		dmaib(at)mac.com Guest
				 Posted: Thu Nov 11, 2010 7:01 pm    Post subject: Windows and hysol |
				If I recall correctly, Rob Hickman bumped one of his windows that had been installed with Hysol and it popped right out. I was planning on using Hysol, but changed back to Weld-On after reading Rob's write up on it.
 David Maib
 40559
 Flying
 href="http://www.aeroelectric.com">www.aeroelectric.com
 href="http://www.buildersbooks.com">www.buildersbooks.com
 href="http://www.homebuilthelp.com">www.homebuilthelp.com
