		Kelly McMullen
				 Posted: Thu Nov 11, 2010 4:04 pm    Post subject: Looking for a quick build right wing! |
				Yeah, right. Sounds like Ken. Yeah, we've never heard of a (nose wheel
 fork) issue before, or that the supplied nose wheel isn't the correct
 one for a 5X5 tire. The spar carrythrough/wing spar connection isn't
 pre-punched. I suspect it may be CAD drilled, but probably finish
 reamed after that to precise size. Maybe the location precision is
 good enough now, but wasn't long ago if you wanted QB wings and had a
 slow build fuse you had to send the carry through back to be match
 fitted/drilled. I don't recall if that was on the -10 or the 2 place
 models or both.
 On Thu, Nov 11, 2010 at 10:51 AM, David Watterson
 <davidw(at)dddirectories.com> wrote:
 [quote] Just spoke with Vans and they say this is a pre-punched airplane and all
  parts match up perfectly.
  David
  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry
  Sent: Thursday, November 11, 2010 10:53 AM
  Subject: Re: Looking for a quick build right wing!
  If you do discover that you need a new carry through for match drilling, let
  me know.
  They're around $1,300 from Vans and I purchased a second one in the process
  of acquiring a friends kit.  I'll be happy to make you a deal for it because
  I'm not going to be needing it.
  Phil
  On Thu, Nov 11, 2010 at 10:35 AM, Tim Olson <Tim(at)myrv10.com> wrote:
  Could be an easy rebuild even with the bent spar....the
  Van's RV-10 Wing kit is $9250.0   Figure maybe that
  you would have to spend 60% of that ($5550) to buy all
  of the components for one new Starbord wing.  It took
  me maybe 325 hours to build both wings, slow build.
  Cut that by 25% for having done one before and you'd
  be at 250 hrs for a pair, 125 hours for one.
  125 hours could be done in a pretty short time...far
  less than the wait for a quickbuild wing.  Also, if
  you factored in the parts that you could re-use, like
  the control rods, control rod ends, brackets,
  ailerons, flaps, and all the pieces that are easily
  removable, you'd only really have to build the wing
  itself and it would be a whole new wing.  If the
  insurance company let you re-use ailerons/flaps,
  and some control rods and parts, you could probably
  rebuild the entire wing in 100 hours or so,
  and spend less than $5000 doing it. If you could
  talk them into obtaining a couple quotes for new
  wings from other sources, maybe they'd cut a check
  for >$5000 and you could end up with getting some
  money back for the time invested, too.
  Tim Olson - RV-10 N104CD
  On 11/11/2010 10:03 AM, David Watterson wrote:
  Watterson"<davidw(at)dddirectories.com>
  Thank you for your comments. The spar is bent! The insurance company
  recommended a full wing replacement. I am talking with a few local builders
  to determine the best action to take.
A&P/IA, EAA Tech Counselor
KCHD |
		philperry9(at)gmail.com Guest
				 Posted: Thu Nov 11, 2010 5:08 pm    Post subject: Looking for a quick build right wing! |
				I purchased the carry through with the fuselage and separate from the wings Kelly.  They never asked me to return it for match drilling, so I suspect they're right in this case.
 But you're right.  It wasn't too long ago that they were match drilled so a set of wings only matched one carry through.
 Phil
 On Thu, Nov 11, 2010 at 6:01 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
 [quote] --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
  models or both.
  > David
  > From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)
  > [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Phillip Perry
  > To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
  > me know.
  > Phil
  > On Thu, Nov 11, 2010 at 10:35 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
  > --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
  > do not archive
  > -->  RV10-List message posted by: "David
  > Watterson"<davidw(at)dddirectories.com (davidw(at)dddirectories.com)>
		Kelly McMullen
				 Posted: Thu Nov 11, 2010 6:43 pm    Post subject: Looking for a quick build right wing! |
				Understand some things have changed. Other things like standard script
 by certain person(s) to questions they don't want to answer haven't
 changed. Had lunch next to Ken at Copperstate. He categorically denied
 there was anything wrong with the nose wheel/axle combination Vans
 supplies, that 410RV ever had any nose wheel shimmy, etc. I
 experienced it my self at demo flight, with follow up flight with
 Randy Debauw whose plane had none of the vibration in nose wheel that
 the factory plane had. You remember all the issues we had with our QB
 kits. IIRC you got a reply from Scott. I got missing parts and
 slightly better ailerons and flaps, but no acknowledgment that
 anything was ever wrong.
 On Thu, Nov 11, 2010 at 6:04 PM, Phillip Perry <philperry9(at)gmail.com> wrote:
 [quote] I purchased the carry through with the fuselage and separate from the wings
  Phil
  On Thu, Nov 11, 2010 at 6:01 PM, Kelly McMullen <apilot2(at)gmail.com> wrote:
 > models or both.
 > > David
 > > let
 > > me know.
 > > process
 > > because
 > > Phil
 > > do not archive
 > > builders
KCHD |
		AirMike
				 Posted: Thu Nov 11, 2010 9:18 pm    Post subject: Looking for a quick build right wing! |
				Sorry about the incident and the damage.
 I hope that I am not asking too foolish of a question, but from what I can see (wing ok from fuel tank inward), why don't you just pull the wing off and rebuild it with new parts from Vans. Maybe there is other damage that I cannot see. From the pic, I cannot imagine spending more than $300-500 on parts. If you are not the original builder or cannot retain him/her. Get an RV builder to help you and get it signed off by an I/A. I figure 100-150 hrs max to fix it (plus painting).
 By the way - how did the plane handle and land after the collision?
  _________________ See you OSH '18
Q/B - sold. |
		dlm46007(at)cox.net Guest
				 Posted: Fri Nov 12, 2010 7:14 am    Post subject: Looking for a quick build right wing! |
				I remember talking to Van's engineering years ago about the wings.  I remember the rumor going around that they were match drilled, but I was told that they were not match drilled, but were CNC drilled to very tight tolerances and were interchangeable.
 I do agree, however, that they do act ignorant of issues that are ongoing that they don't wish to address.  Also, it's important to know that there is one Ken there who is often considered a "problem" by builders.  There is another Ken there who is a great guy and great to deal with.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 C: 352-427-0285
 F: 815-377-3694
  models or both.
 > David
 > me know.
 > Phil
 > do not archive
