peterthomson
Posted: Fri Nov 12, 2010 5:18 am Post subject: Dynon D180 tachometer on Jabiru 3300 reading low |
My friend had thought he lost RPM on the engine, butr in fact, it was
only on the Dynon D170 reading.
A TinyTach showed normal readings, where the Dynon showed a few
hundred RPM less, and even decreased while the engine RPM were stable.
The take-off is from the alternator, 6 pulses per RPM.
Has anyone else seen this problem with the Dynon ?
thanks
Peter
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
andysilvester
Posted: Fri Nov 12, 2010 5:48 am Post subject: Re: Dynon D180 tachometer on Jabiru 3300 reading low |
Peter,
Try swapping the Dynon's rpm sense wire to the other alternator output wire. It shouldn't make a difference, but I've found it does on the EIS. Otherwise, just check wiring, configuration and grounds. We've not had any such issues with the Dynon EMS D120; a similar instrument. The D120 can have two rpm inputs (left and right) to suit Lycomings, but just use the 'left' input and don't connect the 'right'.
Cheers, Andy
aprazer
Posted: Sun Nov 14, 2010 1:01 pm Post subject: Re: Dynon D180 tachometer on Jabiru 3300 reading low |
I had a similar problem. Go back and verify your wiring to the Dynon with the wiring schematic. I had two wires doing the job of one.
Mack
_________________ The poh-oh-unemployed farm boy from Idaho |
