				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| graeme bird
				|  Posted: Mon Nov 15, 2010 1:10 pm    Post subject: where to collect air for air instruments |   |
				| I am considering collecting the air for my air instruments from within the instrument panel molding and adding a row of holes at the top at the bottom of the windscreen, The plan being to draw air over the windscreen and keep it mist free. Is this normal? or is there some other aspect I should consider?
Its a venturi scheme I am using
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
 Graeme Bird
 kit4 (Wagstaff) TBD
 Kit 1 G-UMPY -  Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
		| Back to top |  |
		| gholland(at)content-strea Guest
				|  Posted: Mon Nov 15, 2010 1:34 pm    Post subject: where to collect air for air instruments |   |
				| Graham Hi!
I blew air up over front screen using 2 X 12V Computer Fans controlled by
 variable resistance from warmer air in Instrument panel housing. They worked
 well. The Fans were small at about 50cms maximum as remember. If you intend
 to draw air down screen in some way by reduced pressure I'm not sure that
 will work as you are drawing the cabin air down that is already causing
 mist.
 The screen will attract mist throughout Autumn to late spring so it's worth
 an investment in a solution. Others will make comment I'm sure.
 Gerry
		| Back to top |  |
		| rparigoris
				|  Posted: Tue Nov 16, 2010 12:26 am    Post subject: Re: where to collect air for air instruments |   |
				| Hi Graeme
 I put up some info on panel cooling and demisting ideas:
 http://www.europaowners.org/forums/gallery2.php?g2_itemId=78355
 My install is near the bottom of this page:
 http://www.europaowners.org/forums/gallery2.php?g2_itemId=27305
 I went with 4 tiny fans using a three position switch that offers me 2 speeds.
 I tested a lot of fans, the ones I selected really do offer twice the volume on haldf the amp draw of similar motors.
 When shop is quiet boy do 4 fans sound sweet.
 Demisting should be better than nothing and should be able to keep my Dynon and radios happier.
 Ron Parigoris
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
