AeroElectric-List Digest: 13 Msgs - 04/27/06
nghertner(at)verizon.net
PostPosted: Sun Apr 30, 2006 10:18 pm    Post subject: AeroElectric-List Digest: 13 Msgs - 04/27/06 Reply with quote
On 4/28/06 7:25 AM, "Terry Lamp" <tlamp(at)genesishcs.org> wrote:
Joe here is a picture of my install.
http://home.columbus.rr.com/tlamp/mvc-398f.jpg
and my entire construction page of the Long EZ at:
http://home.columbus.rr.com/tlamp/planpics.htm
I'm sure you have seen this type before, it has the typical microswitch
located behind the latch.
I think it would be better if I also had a magnetic switch inline to also
verify that the canopy is shut, as the latch can be locked and the canopy
not captured. It is pretty obvious if that happens, but it would be a safer
installation.
Terry Lamp
Long EZ N977JT
Ohio
________________________________ Message 5
_____________________________________
Time: 09:24:26 AM PST US
Subject: Canopy Latched Sensor
I'm looking for a better way to implement the canopy unlatched warning
system on a Long-EZ. The standard method is to use a small microswitch
that responds to "canopy latched". (This is not the same as "canopy
closed", which would be easy enough to implement but I want a "latched"
indication.)
Here's an illustration of the standard system:
http://users.lewiston.com/hth/jd/CanopyLockMicroswitch.jpg
When the canopy locking handle is pushed forward (left in the image) far
enough to latch the canopy locking mechanism, the head of the screw on
the handle (at the right in the image) fits in the hole on the latch and
actives the microswitch through its (specially bent) lever.
I'm not happy with the microswitch as it doesn't hold up well under use
and wonder if any Aeroelectric Connection readers can come up with a
better idea. I've searched for optical interrupters but can't find one
with a gap large enough for the head of the relatively large #10 screw.
I'm not familiar with any specific reflective-type optical sensors but
I'm guessing that would be the way to go.
Any ideas?
Joe
Long-EZ 821RP
Lewiston, ID
*****************Confidentiality Notice:******************************
The information contained in this e-mail message, including any
attachments, is intended only for use of the individual or entity
named above (addressee). This e-mail may contain information
that is privileged, confidential and/or otherwise exempt from
disclosure under applicable law. If the reader of this message is
not the intended recipient, any disclosure, dissemination,
distribution, copying or other use of the communication or its
substance is prohibited. If you have received this e-mail in error,
please reply to this e-mail indicating you are not the intended
recipient and immediately destroy all copies of this e-mail. Receipt
by anyone other than the intended recipient is not a waiver of any
privileged information.
Marya,
We are going to the opening, flying down , coming home on Thursday.
She is not there everyday, but would of course meet you.
Love, Nancy
