s.blanton(at)sbcglobal.ne Guest
Posted: Tue Nov 16, 2010 5:27 pm Post subject: Z-13/8 Rev. Q |
Is there a simplified schematic available for Z-13/8 that utilizes the always present battery to energize the SD-8?
Stan Blanton
Posted: Tue Nov 16, 2010 7:37 pm Post subject: Z-13/8 Rev. Q |
At 07:22 PM 11/16/2010, you wrote:
| Quote: | Is there a simplified schematic available for Z-13/8 that utilizes
Not sure I understand "simplified" or "energize".
The latest configuration is here:
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8Q.pdf
The extra diodes and resistors in the SD-8 wiring
along with diodes on the alternator disconnect
relay will use the battery to jump start the SD-8.
Is there some additional functional feature you
need?
Posted: Wed Nov 17, 2010 6:43 am Post subject: Z-13/8 Rev. Q |
I believe I should have used the term SD8 “self excitation”.
Wasn’t the self excitation feature added to allow the SD8 to come online without a battery on line?
With a Z-13/8 architecture the battery is always connected to the SD8 circuit.
Assuming proper maintenance of the battery, is there any significant/reasonable simplified component reduction possible or advisable in the self excitation feature for the SD-8 ? (ref. message 44709 below)
Stan Blanton
Match:
#11
Message:
#44709
Date:
Apr 05, 2009
"Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Subject:
Re: SD-8 self-excitation in Z-13/8 | Quote: | | At 09:35 AM 4/4/2009, you wrote:> >Robert L. Nuckolls, III wrote:>> | 012345678901234567
Posted: Wed Nov 17, 2010 8:38 am Post subject: Z-13/8 Rev. Q |
At 08:35 AM 11/17/2010, you wrote:
| Quote: | Bob,
I believe I should have used the term SD8 "self excitation".
Wasn't the self excitation feature added to allow the SD8 to come
Yes, and the diodes added to the disconnect relay to allow it
to energize from EITHER the SD-8 or the Battery . . .
| Quote: | With a Z-13/8 architecture the battery is always connected to the SD8 circuit.
???? No, normal ops call for the SD-8 to be in the
OFF position.
| Quote: | Assuming proper maintenance of the battery, is there any
Your right. The self excitation feature is based
on the notion that one might find themselves airborne
with a dead battery. I recall the conversation now. I
think we decided that the band-aid stacked on top of
the original Z-13/8 design goals was unnecessary
and presumes that an OBAM airplane builder would
find themselves in that situation after takeoff.
Given that you, I and 99.9% of the folks who read
this list will have a well considered Plan-B and
a preventative maintenance program to support it,
the SD-8 self-excitation and dual-feed for the
alternator relay are unnecessary and only adds to
parts count.
Thanks for the reminder! I think I'll take those
out.
