Oil pressure
Goto page Previous  1, 2
JohnF
PostPosted: Tue Nov 16, 2010 1:27 pm    Post subject: Oil pressure Reply with quote
I purchased two 7.5 gallon 'cans' for the FLO FAST pump... one minute of
cranking and 5 gallons is put out through a rather long hose and up into the
RV-12 filler 'hole.' No lifting. Smooth and convenient....fill up at the
auto gas station, and crank the handle to deliver into the plane. Hose is
long enough for a high wing plane also. I am quite happy with the Flo Fast
'system.' As I recall the two containers plus the hand pump ran around
$250...I could be a bit off on that tho'
FWIW
flyadive(at)gmail.com
PostPosted: Fri Nov 19, 2010 6:05 am    Post subject: Oil pressure Reply with quote
Thom & Gaggle:
Speaking from strictly a mechanical engineer point of view:
If the leverage force and the rotational torque are equal the Fatigue Factor goes down with the Rotation Pump since there is a DEAD stop at the Top and Bottom of the leaver pump. Where you must overcome inertia at rest just to start pumping again.
Want to save some more energy?  Make the handle longer.
Barry
[quote] I agree that in principle that cranking a full rev can be easier than operating a lever because the mechanical advantage is probably higher. But the crank type is so easy that a little harder should not be too bad. I bought one today and will be installing and trying it out on Thursday.
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
“Everyone is entitled to his own opinion, but not his own facts.”
Daniel Patrick Moynihan
http://forums.matronics.com/viewtopic.php?p=319623#319623
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
Thom Riddle
PostPosted: Fri Nov 19, 2010 6:29 am    Post subject: Re: Oil pressure Reply with quote
FWIW
I changed the rotational crank pump for the reciprocal lever pump as per my plan. The lever pump does require a little more effort but it does not pump 9 oz per stroke as advertised. It pumps 16 oz per stroke or 8 strokes per gallon compared to the 16 revolutions per gallon for the cast iron crank pump.
I did not time it but would say that it takes about the same time to pump equivalent amount of fuel, same work being done, just different motions.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Page 2 of 2
