woxofswa
Posted: Sun Nov 21, 2010 7:56 pm Post subject: cab-o-sil |
I just had gallbladder surgery and am starting on my doors. I'm not sure which is worse.
The plans call out "cab-o-sil" for an epoxy filler. I have West Systems 410 fairing filler. Will that do, or do I need the real cab-o-McCoy?
Thanks in advance.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
Posted: Sun Nov 21, 2010 8:34 pm Post subject: cab-o-sil |
Myron,
410 is a non-structural filler. Cabosil is a thickening agent that
won't significantly reduce the strength of the resin. It allows the
resin to adhere to vertical surfaces. Get some cabo. We get ours
from Spruce.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Sun, Nov 21, 2010 at 7:56 PM, woxofswa <woxof(at)aol.com> wrote:
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse in progress
http://forums.matronics.com/viewtopic.php?p=320399#320399
dlm46007(at)cox.net Guest
Posted: Sun Nov 21, 2010 8:40 pm Post subject: cab-o-sil |
I don't know about the replacement but cabosil is used to thicken the
mixture to make it less runny, like peanut butter.
Tim Olson
Posted: Sun Nov 21, 2010 9:05 pm Post subject: cab-o-sil |
If you use West System, use Colloidal silica....that's the equivalent in their product line.
On Nov 21, 2010, at 9:56 PM, "woxofswa" <woxof(at)aol.com> wrote:
Thanks in advance.
Myron Nelson
Mesa, AZ
Posted: Mon Nov 22, 2010 7:53 am Post subject: cab-o-sil |
They call out for Cabosil when bonding the inner and out door halves
together in particular. It will run all over the place inside the door
unless you thicken it up. One imagines that with the thickened stuff
you get a bit of a fillet on the inside of the joint where you otherwise
can't get to during the bonding process. Whatever happens, you can't
see it after you finish.
Enjoy the doors, it's was a learning journey for me.
Bill "planning to work on the doors for the very last time over
Christmas, i.e final paint " Watson
Myron,
from Spruce.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
woxofswa
Posted: Mon Nov 22, 2010 12:47 pm Post subject: Re: cab-o-sil |
Thanks for the tips.
I'll pick up the Colloidal silica and if I have some left over it sounds like it might help with my constipation.
Cheers,
Myron
Mesa, AZ
Flew May 10 2014 |
