AirMike
Posted: Thu Nov 25, 2010 10:51 pm Post subject: I-Pad question |
Thinking about buying an I-Pad. Should I get the 3G model so that I can get en-route weather (when I can get a cel signal). Or is it a waste of money to get the 3G model.
_________________ See you OSH '18
Q/B - sold. |
Lenny Iszak
Posted: Fri Nov 26, 2010 2:42 am Post subject: Re: I-Pad question |
Mike,
Only the 3G version has a built-in GPS.
You will still be able to use a bluetooth GPS in either unit as long as you have it jailbroken.
Lenny
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
Tim Olson
Posted: Fri Nov 26, 2010 4:41 am Post subject: I-Pad question |
Either way I'd get the 3G version...for
GPS and the occasional data plan since you can go month to month.
The GPS built in actually works well and it's nice to use in the car too.
On Nov 26, 2010, at 4:42 AM, "Lenny Iszak" <lenard(at)rapiddecision.com> wrote:
Posted: Fri Nov 26, 2010 4:44 am Post subject: I-Pad question |
Gotta have the 3G model if you want an internal GPS. The wifi model does not have a GPS. I have a 3G model but I don't have the 3G data activated (because i have an iphone and don't want to pay for 2 data plans) and it works great as a moving map gps, as long as you download the maps prior to flight. Just FYI, It is really hard (if not impossible) to get a signal in the air long enough for weather or map updates.
On Nov 26, 2010, at 1:51 AM, "AirMike" <Mikeabel(at)Pacbell.net> wrote:
See you OSH '11
Q/B - flying 1 yr+
http://forums.matronics.com/viewtopic.php?p=321066#321066
Tim Olson
Posted: Fri Nov 26, 2010 4:55 am Post subject: I-Pad question |
Definitely true....if you're planning to use 3G for in-flight
Wx you'll be really disappointed in most areas.
Tim Olson - RV-10 N104CD
On 11/26/2010 6:41 AM, Michael Kraus wrote:
> See you OSH '11
> Q/B - flying 1 yr+
Kelly McMullen
Posted: Fri Nov 26, 2010 5:02 am Post subject: I-Pad question |
No longer necessary. Bad Elf plug-in GPS and one blue tooth GPS are
Apple approved and work without jailbreaking. They cost 99 over the
cost of a wifi only iPad. http://bad-elf.com/products/gps/
The other is GNS 5870 MFI Bluetooth GPS , also sold through Amazon and
other sources.
On Fri, Nov 26, 2010 at 5:28 AM, Tim Olson <Tim(at)myrv10.com> wrote:
> Mike,
> Lenny
> Lenny
> #40803
> http://forums.matronics.com/viewtopic.php?p=321067#321067
A&P/IA, EAA Tech Counselor
KCHD |
Kelly McMullen
Posted: Fri Nov 26, 2010 5:14 am Post subject: I-Pad question |
While the internal GPS in the iPad works well enough, it is not WAAS
and is really a low end GPS. The external GPS units available are much
closer to state of the art, with the Bad Elf stating it is WAAS and
10Hz cycle, which is better than your certified units that update at 5
Hz. The blue tooth GNS5870gps doesn't state whether it has WAAS, so
don't know about it beyond it being 32 channel.
On Fri, Nov 26, 2010 at 5:41 AM, Michael Kraus
<n223rv(at)wolflakeairport.net> wrote:
> See you OSH '11
> Q/B - flying 1 yr+
KCHD |
jdriggs49(at)msn.com Guest
Posted: Fri Nov 26, 2010 7:25 am Post subject: I-Pad question |
I have the 3G model but have found that the ATT cell system to be fairly inadequate. Also have IPhone. I would get the 3G model however as you can get the GPS signal in a lot of places so you can usethemoving map features. However, it's not very robust. I bought the Bad Elf WAAS GPS and it works great. Locks on pretty quickly. It's 1"x1"x3/8" in size. Very small.
My son-in-law gave me a Verizon MiFi blue tooth that gives me access to their system. They have better coverage it seems to me from trying it out. Works pretty good in the air in a lot of places to update while flying. I'm dropping my ATT account and going to Verizon on this one. With the Bad Elf, the IPad is finally really usable for aviation. It won't be long until we will be able reliably get in route weather at all times and all places.
P.S. The MiFi works well as a wifi router. I was in the basement of our church and my son-in-law was able to pick up and use the wifi signal upstairs to access the Internet. He "claimed" he was looking up a Bible text.
| Quote: | Date: Fri, 26 Nov 2010 06:11:58 -0700
Subject: Re: RV10-List: I-Pad question
To: rv10-list@matronics.com
--> RV10-List message posted by: Kelly McMullen <apilot2@gmail.com>
<n223rv@wolflakeairport.net> wrote:
> --> RV10-List message posted by: Michael Kraus <n223rv@wolflakeairport.net>
> Sent from my iPhone
> On Nov 26, 2010, at 1:51 AM, "AirMike" <Mikeabel@Pacbell.net> wrote:
>> --> RV10-List message posted by: "AirMike" <Mikeabel@Pacbell.net>
>> See you OSH '11
>> Q/B - flying 1 yr+
_-============================================================
_-=
_-= -- Please Support Your Lists This Month --
_-= (And Get Some AWESOME FREE Gifts!)
_-=
_-= November is the Annual List Fund Raiser. Click on
_-= the Contribution link below to find out more about
_-= this year's Terrific Free Incentive Gifts provided
_-= by:
_-=
_-= * AeroElectric www.aeroelectric.com
_-= * The Builder's Bookstore www.buildersbooks.com
_-= * HomebuiltHELP www.homebuilthelp.com
_-=
_-= List Contribution Web Site:
_-=
_-= --> http://www.matronics.com/contribution
_-=
_-= Thank you for your generous support!
_-=
_-= -Matt Dralle, List Admin.
_-=
_-= - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= =
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
