Posted: Sun Nov 28, 2010 7:06 pm Post subject: Thottle cable length |
I spent most of the day hooking up my control cables on the engine.
I was very surprised that the cables Vans provided with the kit were so tight and left little extra length to work with. I had installed eye ball pass throughs on my firewall in the same location as the stock SBs, But I had to drill out the aluminum cores so that the cables would fit through correctly. Unfortunely, I hadn't drilled the holes large enough and once the fittings where screwed down the cables were tight in the core. Hense, I needed to undo the eye balls so I could pull the cables tighter giving more room in the cable in the engine compartment. Even with that, I have no wiggle room.
I was also very careful to keep the location of the cable handles in the same location as the stock part even though I fabicated a different subpanel which holds all the control handles.
My mixture cable works through its full range of motion, but my throttle cable seems short by 1/4-3/8" even though the cable bracket on the throttle body is midway up the throttle cable threaded base.
Did other builders need to adjust double articulated arm on the throttle body so that the cable will make the throttle go to both stops- full open and full closed?
JOhn G #409
Tim Olson
Posted: Sun Nov 28, 2010 8:37 pm Post subject: Thottle cable length |
John, is this what you're speaking of?
http://www.myrv10.com/N104CD/finishing/20051228/index.html
See down the page on throttle cable.
On Nov 28, 2010, at 9:03 PM, John Gonzalez <indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)> wrote:
[quote] I spent most of the day hooking up my control cables on the engine.
JOhn G #409
Posted: Sun Nov 28, 2010 9:15 pm Post subject: Thottle cable length |
This what I am referring to, but you added a quadrant which must have made the length requirement change. I kept everything nearly the same and ran out of cable length.
I believe I will be able to fix this by adjusting the position of the servo arm as it can imcrementally articulate with the arm which hits the stops.
Just trying the figure why I ran out of length and whether others have had the problem.
Thank you for directing me to the exact location on your site.
John
Subject: Re: Thottle cable length
Date: Sun, 28 Nov 2010 22:30:05 -0600
JOhn G #409
com
10-List
Kelly McMullen
Posted: Mon Nov 29, 2010 4:49 am Post subject: Thottle cable length |
I suspect this is one of those issues that most everyone has heard about, but Van's chooses not to address. Kind of like the nose wheel/fork issues.
On Sun, Nov 28, 2010 at 10:12 PM, John Gonzalez <indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)> wrote:
| Quote: | This what I am referring to, but you added a quadrant which must have made the length requirement change. I kept everything nearly the same and ran out of cable length.
I believe I will be able to fix this by adjusting the position of the servo arm as it can incrementally articulate with the arm which hits the stops.
John
| Quote: | I spent most of the day hooking up my control cables on the engine.
JOhn G #409
com
10-List
_blank">www.aeroelectric.com
tp://forums.matronics.com
#avg_ls_inline_popup{position: absolute;z-index: 9999;padding: 0px 0px;margin-left: 0px;margin-top: 0px;overflow: hidden;word-wrap: break-word;color: black;font-size: 10px;text-align: left;line-height: 130%;} [quote][b]
A&P/IA, EAA Tech Counselor
KCHD |
jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Mon Nov 29, 2010 5:30 am Post subject: Re: Thottle cable length |
We had to order a longer cable. I think we used the RV-7 throttle cable, I assume Van's has not changed the lengths of either the 10 or the 7 cable in the past few years.
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
Tim Olson
Posted: Mon Nov 29, 2010 6:03 am Post subject: Thottle cable length |
Aren't we talking about 2 different things here? I mean, the cable
not being long enough is one thing, but John's original question
stated he didn't get enough throw to go stop-to-stop on the cable.
That isn't really determined by cable length...although I can see
where a straight run cable might perhaps give you a tiny bit better
throw than one that makes a bunch of curves. If the cable isn't
long enough to reach the attach points on each end, then you
get a longer cable. If the throw isn't going stop-to-stop, you
have to play with the lever arm connections a bit to make it
throw the way you want it. I had to redrill both ends on mine to
make it perfect. I didn't want a throttle that didn't go stop-to-stop.
I wanted it almost 99.9% back-stop when at idle, and 99.9% to
forward stop when WOT. This took a little eyeballing, but once
I did it, it worked perfectly. I used the standard cable that
came with the quadrant. For a couple cables, it would have been
nice to have an extra 1" or .5" of length, but it did work out
for me with the stock cables.
Regarding the melting of the prop gov. cable sheath, I found
that some aluminum tape around the cable worked well at
reflecting that heat so it wouldn't absorb. You could build
an insulated heat shield with some high-temp insulation
wrapped on the cable, and some aluminum tape over it. You
have to protect those things right near the exhaust...especially
the cowl.
Tim Olson - RV-10 N104CD
On 11/29/2010 7:30 AM, jkreidler wrote:
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=321568#321568
jkreidler
Posted: Mon Nov 29, 2010 6:34 am Post subject: Re: Thottle cable length |
The difference is the jacket of the cable. If the jacket is too short, or even marginal then you are forced to run the anchor nuts all the way to the end of the jacket. This sets in stone where the end of the cable will ultimately end up. In our case we might have been able to get the servo arms adjusted just far enough to work, but the intersecting angle between the cable and the arm would have been nearly 180 degrees or straight on. This does two things, first it creates the unlikely potential that the cable and arm may go over center and not function, secondly it makes the throttle harder to push for the first part of the travel. Of course even with a longer cable and the anchor nuts all the way at the end of the jacket you would have the same problem (Tim, to your point). By using a longer cable we were able to set anchor nuts away from the end of the jacket allowing the intersecting angle to be approximately 45 degrees at idle and wide open making the throttle pressure required at any point feel the same.
This topic has circulated in the past, I think the lengths Van's supplies for the quadrant are OK PER Tim’s and others feedback, but others beyond us have had to get longer cables for the standard setup.
Tim Olson
Posted: Mon Nov 29, 2010 6:56 am Post subject: Thottle cable length |
Ahh, that clears up the issue. Yeah, you definitely wouldn't
want it to go over-center and cause a problem. I've never
installed the push-pull type install, so I can't see it
all very clearly...on the quadrant install though, it seems
pretty simple.
On 11/29/2010 8:34 AM, jkreidler wrote:
"jkreidler"<jason.kreidler(at)regalbeloit.com>
idle and wide open making the throttle pre! ssure required at any
setup.
-------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony
Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying -
#40617
http://forums.matronics.com/viewtopic.php?p=321582#321582
Bob Turner
Posted: Mon Nov 29, 2010 11:43 am Post subject: Re: Thottle cable length |
You're not alone, mine were too short (standard set up). I sent photos back and forth to Vans, couldn't resolve the problem. In the end I used a different, more direct routing, and have just enough slack (for engine vibration) to feel okay about it. Yes, I did have to move the arms on the throttle body to get stop-to-stop movement. But they're no where near 180 to the cable.
_________________ Bob Turner
RV-10 QB |
ivankris
Joined: 29 May 2009 Posts: 21 Location: Guelph, Ontario. Canada
Posted: Wed Dec 01, 2010 7:34 pm Post subject: Re: Thottle cable length |
All three cables were too short in my installation. I returned all three to Vans for credit and then re-ordered the 50.5" throttle cable from Vans which is 3" longer than the one they ship with the kit.
I then ordered two new cables (Mix & Prop) directly from the Mfg. and specified the length I wanted. They are a bit pricey (about twice Vans prices) that way but well worth the extra money to get the proper length for proper routing.
The Mfg. is ACS Products. This company was started by the same man who started Aircraft Spruce and was originally part of that company but is now a separate entity.
These are the part numbers:
Blue Knob VProp A-1760-30-0745-V with 2.5" stroke
Red Knob Mixture A-1760-20-0535-V with 2.5" stroke
This is a special non refundable order at $159.95 each so be sure that this is what you need. The part numbers I have given here gives you cables two inches longer than the cables you get from Vans, this is what I used and they worked fine. If I had to do it again I believe I would, like the throttle cable, make them 3 inches longer which would make the installation even easier.
If you plan a std Vans panel order them 2" longer. If you use CF panel from Aerosport Products order them 3" longer.
To order cables three inches longer change the last number for the blue knob from 0745 to 0755 (75.5") and for the red knob from 0535 to 0545 (54.5")
Keep in mind that if you plan on using the CF instrument panel from http://www.aerosportproducts.com/ then this brings the attach point of these cables in the cockpit back almost one inch which makes longer cables a definite requirement.
To order call Anthony Garcia at Aircraft Spruce at (951) 372-9555 ex. 456 or e-mail him at anthonygarcia(at)aircraftspruce.com and give him quotation # 249314
_________________ Ivan Kristensen.
www.ivankristensen.com
Builder # 40838
Flying (430hrs.)
C-GMDV |
Kelly McMullen
Posted: Wed Dec 01, 2010 8:34 pm Post subject: Thottle cable length |
Thank you for that detail. Another option is to order cables you need from McFarlane Aviation. They make high quality PMA cables for Cessnas and some Pipers, and will custom make whatever you need. I haven't checked to see which would be cheaper.
Kelly
On Wed, Dec 1, 2010 at 8:34 PM, ivankris <ivankris(at)rogers.com (ivankris(at)rogers.com)> wrote:
| Quote: | --> RV10-List message posted by: "ivankris" <ivankris(at)rogers.com (ivankris(at)rogers.com)>
KCHD |
pilotdds(at)aol.com Guest
Posted: Wed Dec 01, 2010 8:58 pm Post subject: Thottle cable length |
aircraft spruce sells screw on extensions for the control cables-anybody tried them?
