longg(at)pjm.com Guest
Posted: Tue Dec 07, 2010 11:03 am Post subject: G530 TX Issue |
My Garmin 530 is having an issue transmitting.
<![if !supportLists]>1. <![endif]>When I click on the PTT button the TX light comes on the Garmin and my test handheld radio goes silent as to receive the voice. No voice is transmitted/heard. I have to really speak up to hear myself talking when I press the button.
<![if !supportLists]>2. <![endif]>My other 2 com radios work perfectly.
<![if !supportLists]>3. <![endif]>Also when transmitting the Audio COM1 button blinks and recognizes the transmission.
<![if !supportLists]>4. <![endif]>The vol/sql knob appears to work as advertised.
Ideas appreciated.
Glenn E. Long
tperry(at)lvtofly.com Guest
Posted: Tue Dec 07, 2010 11:22 am Post subject: G530 TX Issue |
Had my 430 do the same thing. Had to send it to garmin, they ended up replacing the two boards. I have talked to several others have similar failures on the 430 and 530. For the 430 it was flat rate repair of $800.
1. When I click on the PTT button the TX light comes on the Garmin and my test handheld radio goes silent as to receive the voice. No voice is transmitted/heard. I have to really speak up to hear myself talking when I press the button.
2. My other 2 com radios work perfectly.
3. Also when transmitting the Audio COM1 button blinks and recognizes the transmission.
4. The vol/sql knob appears to work as advertised.
Ideas appreciated.
Glenn E. Long
Posted: Tue Dec 07, 2010 1:39 pm Post subject: G530 TX Issue |
On 12/7/2010 12:30 PM, longg(at)pjm.com (longg(at)pjm.com) wrote: | Quote: | 1024x768 <![endif]--> Clean false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} <![endif]--> <![endif]--> <![endif]-->
Ideas appreciated.
Glenn E. Long
| A friend had the same symptom with a factory new 430. Swapped into another a/c & it worked fine; bad again in his plane.
After perusing the wiring diagrams for days and contacting Garmin tech help & detailing every single pin that had wire (tech said it was wired correctly), he finally took it to a local avionics shop. They took one look at the back & told him he was missing one of the grounds (sorry; don't remember which one).
The harness was built by the vendor where he bought the radio.
Remember that even if it worked for a while, pins can back out of the housing if they are defective, or if they were not fully seated when they were installed.
Charlie
Posted: Wed Dec 08, 2010 5:08 am Post subject: G530 TX Issue |
Thanks everyone – I’ll give these ideas a go.
Glenn E. Long
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England
Sent: Tuesday, December 07, 2010 4:36 PM
Subject: Re: G530 TX Issue
Ideas appreciated.
Glenn E. Long
Charlie -- Please Support Your Lists This Month style='mso-spacerun:yes'> (And Get Some AWESOME FREE November is the Annual List Fund Raiser. Click style='mso-spacerun:yes'> the Contribution link style='mso-spacerun:yes'> this year's Terrific Free style='mso-spacerun:yes'> style='mso-spacerun:yes'> style='mso-spacerun:yes'> * AeroElectric www.aeroelectric.com * The Builder's Bookstore www.buildersbooks.com * HomebuiltHELP www.homebuilthelp.com List Contribution Web --> http://www.matronics.com/cfor your generous = -Matt Dralle, List style='mso-spacerun:yes'> - The AeroElectric-List Email Forum utilities such as List Photoshare, and much much --> http://www.matronics.com/Navigator?AeroElectric-List[/b] - MATRONICS WEB FORUMS via the Web --> http://forums.matronics.com=====[/b][b]
hooverra
Joined: 18 Jan 2009 Posts: 11 Location: The Plains, Virginia
Posted: Thu Dec 09, 2010 6:10 pm Post subject: Re: G530 TX Issue |
Glen,
You didn't say if it ever worked. From the symptoms you present it would appear to be the mic audio connection from the audio panel to the to the 530.
Other com working says the mic and audio input is OK.
The TX indicator and breaking squelch on the Hand Held Radio says the Mic Key and transmitter are working. You could have a defective Audio panel output or 530 Mic input but it is more likely a connection issue. Use a couple of pins crimped to a pair of stiff wires so you can probe the tray connectors and check continuity of both the Mic high and Mic Return lines. You will probably find A. A pin in the wrong place, B. A pin retracted from the connector, C. A bad crimp or D. A broken wire.
I had a similar symptom on an RV-10 with a 430 it was A pin in the wrong position. If it ever worked then I would suspect B
Good luck
_________________ Ralph & Laura Hoover
RV7A N527LR |
Posted: Fri Dec 10, 2010 6:23 am Post subject: G530 TX Issue |
Ralph,
Thanks for the tips. As far as I know it worked earlier this year. Since
I've been building I've not really used it for talking, just listening.
It also came back with a clean bill from a shop bench test. Of course
that doesn't guarantee anything.
I am using the Approach Stack bus so I'll check the connections and
re-seat everything too. They made the cables. Someone else mentioned to
check the case ground for continuity. Now that you mentioned Mic High, I
think Approached used a blue wire to represent that pin. It was either
High or Low that was supposed to go to ground?
Glenn E. Long
