Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
beauford(at)tampabay.rr.c Guest
Posted: Tue May 02, 2006 4:55 am Post subject: Rotax Relapse |
Kolbers and Kolbettes:
Once again the mighty 447 asserts its total dominance over
a thoroughly beaten, sniveling and craven Beauford....
Last 5 hours -- Head temps are too high... they both climb steadily at =
full power, reaching=20
400 plus in about 20 seconds... and the fan-end cylinder remains hot, =
stabilizing
about 390 when one throttles back to normal (5800) cruise. Rear cylinder =
comes=20
down to about 360.
Data:
-- Engine had complete top end rebuild at Lockwood 16 hours ago...new =
pistons
and rings. Has consistently run hotter since rebuild, but not this hot =
until
last five hours.
-- Swapped plug thermocouples...verified front is hot cylinder and temp =
reads accurately
-- Same jetting as always... it previously ran at 340 CHT on these same =
jets
and with needle in this same (second) notch
-- No change in prop loading... turns 6050 static, 6450 wot in flight
-- Temps remain together up to 4400 rpm...then front takes off as =
throttle
is pushed up further...eventually gets to 40 degree difference
-- Both EGT's remain normal (1020) at WOT... 1090 at cruise.=20
-- Plugs are clean and pretty...good color,slightly on light side... no =
trace=20
of excess carbon
-- Running Amsoil Saber 100 to one, but I'm mixing it at 70 to one
-- Ran a test tank of Pennzoil AC 50 to 1, no change in problem
-- All new gaskets throughout top of engine... heads and both manifolds
are torqued and re-torqued. No evidence of leakage at head or exhaust =
gaskets.
--Have not yet pulled exhaust to verify rings are free..that is next =
step, followed
by compression check.
I'm thinking air leak. Anyone have any other "hot" ideas?
Also, is there any reliable way to leak-check the case and crank
seals without tearing down the engine...? =20
Beat-up Beauford
FF#076
Brandon, FL
Posted: Tue May 02, 2006 5:10 am Post subject: Rotax Relapse |
Beauford, you may be sniveling but I have never seen such a display of
manly persistence. -not to mention an indomitable and durable bank
account. This must be the 21st century's equivalent of the hair shirt.
Maybe if you borrowed a carb off of someone's happily running 447
to eliminate that angle?
-ignorant 4stroker BB do not archive
On 2, May 2006, at 9:05 AM, Beauford wrote:
stabilizing
cylinder =
comes=20
down to about 360.
Data:
pistons
until
last five hours.
temp =
reads accurately
same =
jets
throttle
no =
trace=20
of excess carbon
gaskets.
step, followed
Beat-up Beauford
FF#076
Brandon, FL
herbgh
Posted: Tue May 02, 2006 5:49 am Post subject: Rotax Relapse |
Beauford
I feel for you! My Firefly is sitting in the garage, not flying, on
account of lack of power which has been discussed before ... Likely
crank center seals since all else has been checked..
There is a fellow in East Tenn who has mounted a 40 some odd horsepower
half vw on his Firefly.. Just about ready to take a test flight ...
Won't be as good as a 447 in performance------. He flew it previously
but got some bad gas which caused him to abort his first flight with
light damage to the Fly.. Ready to go again.. Definitely bad gas as he
had put it in some equipment around his farm and screwed the engines up
on those also.. That was when he knew what was going on...
I fly a half vw on an N3 pup and am satisfied with it... Not as
smooth as a 447. I have a second half vw and will look at the
installation in East Tenn before I decide to go that way... 5 gal tank
will give 2+ hours of cruise. It won't be a Firefly in terms of climb and
performance.. However-- 100 dollars buys two pistons , jugs, rings and
wrist pins.. valves cost 4 to 5 bucks.. main and cam bearing set
costs abt $40 for both. Rear seal 7 bucks.. Gasket set about 10 ..
Uses av gas with no worry..
You did not say that the fan belt was in good shape? Herb
On Tue, 2 May 2006 09:05:06 -0400 "Beauford" <beauford(at)tampabay.rr.com>
writes:
at =
hot, =
stabilizing
cylinder =
comes=20
down to about 360.
WhiskeyVictor36(at)aol.co Guest
Posted: Tue May 02, 2006 6:10 am Post subject: Rotax Relapse |
In a message dated 5/2/2006 8:56:25 A.M. Eastern Standard Time,
beauford(at)tampabay.rr.com writes:
Beauford,
As Herb just mentioned, check the fan belt. High head temps usually point
to an air cooling problem, whereas high EGT readings point to a fuel mixture
(lean or rich) condition. While you look at the fan belt, also look for
obstructions in the cylinder fin area (like a rats nest or birds nest?)
Bill Varnes
Original Kolb FireStar
Audubon NJ
tkrolfe(at)usadatanet.net Guest
Posted: Tue May 02, 2006 6:42 am Post subject: Rotax Relapse |
Herb Gayheart wrote:
Beauford
writes:
>at =
>hot, =
>stabilizing
>cylinder =
>comes=20
>down to about 360.
Herb & Beauford,
Herb & Beauford,
Boy, I feel really lucky with my 447! I have had nothing but good
results with it even after doing all of the rookie dumb stuff to it
in the 500 hr.'s it's been running including a prop strike.
I can just imagine your frustration on being grounded with one of the
best little airplanes there is to fly!
Too bad you don't live close by, I have a two cylinder guru as a flying
buddy who repairs snowmobiles and jetski's as well as solves all of the
local guy's problems and mistakes, mine included.
I will say something to him, but it's hard to diagnose with out seeing and
hearing it.
Terry - FireFly #95
DO NOT ARCHIVE
ul15rhb(at)juno.com Guest
Posted: Tue May 02, 2006 7:05 am Post subject: Rotax Relapse |
Beauford, it needs a good Seafoam treatment
Seriously, have you retorqued the head bolts since the rebuild? You have to loosen them all up, then retorque according to the bolt pattern in many of the order catalogs.
Ralph
Original Firestar
19 years flying it
stabilizing
comes=20
down to about 360.
Data:
pistons
until
last five hours.
reads accurately
jets
throttle
trace=20
of excess carbon
gaskets.
step, followed
Beat-up Beauford
FF#076
Brandon, FL
________________________________________________________________________
Try Juno Platinum for Free! Then, only $9.95/month!
Unlimited Internet Access with 1GB of Email Storage.
Visit http://www.juno.com/value to sign up today!
EnaudZ(at)aol.com Guest
Posted: Tue May 02, 2006 8:56 am Post subject: Rotax Relapse |
check fan belt
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Tue May 02, 2006 10:36 am Post subject: Re: Rotax Relapse |
| beauford(at)tampabay.rr.c wrote: |
seals without tearing down the engine...? |
Beauford,
I'm pretty sure that your problem is not a leak, be it case or crank seals. A leak should cause high exhaust gas temps. I would check the fan, like others suggested, and after that, I would want to see the inside of the engine. Have you asked the people that did the work on it? I've been told that excess friction causes high CH temps, but I don't know a likely cause of that.
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
jr(at)rometool.com Guest
Posted: Tue May 02, 2006 11:18 am Post subject: Rotax Relapse |
Hey all, I had high cht temps many years ago with a 447, this engine was
brand new out of the box, cht temps were getting close to 500 degs.
Eventually, I removed the heads to find that the head gaskets were not
there.....this little bit of higher compression created the overheating.
In cases where I thought I may have a air leak, this works great on
motorcycles or any 2 cycle, with the engine running at idle take a can
of starting fluid and spray the suspected air leak areas, the engine
will rev upon finding a leak.
John
John Jung wrote:
Beauford,
John Jung
Firestar II N6163J
Surprise, AZ
http://forums.matronics.com/viewtopic.php?p=32353#32353
Ralph Hoover
Joined: 09 Jan 2006 Posts: 206 Location: Central Ohio
Posted: Tue May 02, 2006 12:20 pm Post subject: Re: Rotax Relapse |
"In cases where I thought I may have a air leak, this works great on
will rev upon finding a leak. "
I love that! I knew that in my old ring-ding days, there was a way to check, and you defined it! I truely hope this gives Beuford the edge he needs.
Ohio Ralph
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Tue May 02, 2006 12:30 pm Post subject: Rotax Relapse |
Works on 4 cycles as well... I've used WD-40 to find leaks on Continentals
and Lycomings... Same thing happens, engine RPM increases...
DVD
On 5/2/06, Ralph Hoover <flht99reh(at)columbus.rr.com> wrote:
| Quote: | >
needs.
Ohio Ralph
http://forums.matronics.com/viewtopic.php?p=3D32374#32374
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=F4=BF=F4 "Failure lies not in falling down. Failure lies in not getting u=
p."
(traditional Chinese proverb)
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
jadamson
Posted: Tue May 02, 2006 1:14 pm Post subject: Re: Rotax Relapse |
| Ralph Hoover wrote: | "In cases where I thought I may have a air leak, this works great on
Ohio Ralph |
Gee, Ralph, I'da thought you'd remembered that from your "old Harley days" as well. WD-40 or starting fluid around the intake manifold is the standard way to check for leaks on early Evos and prior, especially the ones with the rubber compliance boots. Oh, I forgot, you ride one of them new-fangled Twin Cams. (Sorry, couldn't resist. )
John A
jindoguy(at)gmail.com Guest
Posted: Tue May 02, 2006 1:32 pm Post subject: Rotax Relapse |
Just remember to cone off the carb(s) to keep a combustible compound from
going in the engine that way and giving a false positive. The opposite is
also true, use water or carb cleaner and listen for the engine to slow down
On 5/2/06, jadamson <j-adamson(at)tamu.edu> wrote:
needs.
> Ohio Ralph
Gee, Ralph, I'da thought you'd remembered that from your "old Harley days=
| Quote: | as well. WD-40 or starting fluid around the intake manifold is the stand=
ard
| Quote: | way to check for leaks on early Evos and prior, especially the ones with =
the
| Quote: | rubber compliance boots. Oh, I forgot, you ride one of them new-fangled
John A
http://forums.matronics.com/viewtopic.php?p=3D32392#32392
Rick Girard
"Pining for a home on the Range"
worrybear(at)verizon.net Guest
Posted: Tue May 02, 2006 4:21 pm Post subject: Rotax Relapse |
I know you did but I have to check, you did removed the gaskets from the
spark plugs?
Dan,
Ultrastar
Palmyra PA.
Posted: Tue May 02, 2006 6:52 pm Post subject: Rotax relapse |
My sincere thanks to all who have responded generously with ideas about =
this
clear-cut instance of Austrian revenge....
Here is where it stands with regard to your suggestions...
-- The fan is OK... belt is tensioned, in good shape, and there is =
nothing foreign in the shroud
except this diabolical little motor...
-- Heads have been re-torqued twice... loosened and re-set to specs in =
proper sequence.
-- Head gasket is new and is OK... I put it there myself.
-- No washers under the plugs.
-- Ralph...this is just between us girls, but in a moment of reckless =
abandon, I actually=20
stooped to putting a goodly shot of --foam into the plug holes... =
waiting a while... taking a good
shot of --foam myself, and then running it out of the Rotax... no change =
other=20
than in my personal hydraulic habits....(3 stops on the way home... my =
rings
are free, thank you...)... "Hello, my name is Beauford, and I use =
---foam..."
-- Not sure about the internal friction angle... except that the new =
pistons were
installed by pros and they mic'd it all several times in my presence =
while they
were installing them.... who d'ya trust...?
-- I have a virtually new Bing 54 in a box...it is from a 447. I will =
install it and test run
it before surrendering.
--Will pay-up my Blue Cross, extinguish the stogie, and get a bottle of =
ether and/or WD-40=20
and sniff the seals if all else fails...
For Brother Frantz, who has 500 trouble free hours on his 447... =
Evidently mere gin and Partegas
are not enough... Whatever incense and incantations you are using, I =
want some....500 hours...?
"it just ain't natural..." as my in-laws say in South Georgia....
For Brother Gayheart... half VW's are looking better all the time... I =
would settle for 15 or 20
honest horsepower and 50 lbs of air in the tires at this juncture...and =
I'll go on another diet.=20
=20
Immediate plan: Based on input from a kind benefactor who repairs these =
contrivances for a living, I will next
unload the prop to 6250 static and revert to 50 to 1 oil mix...then hide =
and watch temps... He sez 447's are
highly sensitive to being overpropped.... mebbe I am too....
Thanks again to you all... Will advise...
Beauford
FF#076
Possum
Posted: Tue May 02, 2006 9:17 pm Post subject: Rotax relapse |
At 11:04 PM 5/2/2006, you wrote:
My sincere thanks to all who have responded generously with ideas about .
Rookie
Posted: Wed May 03, 2006 5:14 am Post subject: Rotax Relapse |
Beauford, another thing to do is borrow a known good carburetor and swap it with the one you've got. If everything straightens up, then you've got it nailed.
I keep my old carb for just that purpose.
Ralph
Original Firestar
19 years flying it
stabilizing
comes=20
down to about 360.
Data:
pistons
until
last five hours.
reads accurately
jets
throttle
trace=20
of excess carbon
gaskets.
step, followed
Beat-up Beauford
FF#076
Brandon, FL
Posted: Wed May 03, 2006 5:25 am Post subject: Rotax relapse |
..yeah.... I know...... but at this point I'd take help from Lord
Lockwood himself...
sigh...
Subject: Re: Re: Rotax relapse
DieselsRcool
Joined: 03 May 2006 Posts: 2 Location: Los Barriles Baja,MX & Gig Harbor WA
Posted: Wed May 03, 2006 6:00 pm Post subject: Re: Rotax Relapse |
Are you 100% sure your gauge is correct? What brand/type is it? I've seen the cheap ones do some funny stuff.
If EGT is right on and CHT is amiss, cooling system correct/stock and you havn't changed anything, I'd be sure and double check the source of your info. You could put both thermocouples under the same plug and see if they read the same.
Larry
Joined: 09 Jan 2006 Posts: 3697 Location: Titus, Alabama (hauck's holler)
Posted: Wed May 03, 2006 8:25 pm Post subject: Rotax relapse |
| I will next
hide =
| Beauford
| FF#076
Beauford/All:
I would even go a little further and say "all" two strokes are highly
sensitive to "overpropping" and also "underpropping".
Overpropping pulls down EGT and pushes up CHT. Sorta like running
around in your 6 speed Ferrari, in 6th gear at 25 mph WOT climbing a
mountain. My turbo Cummins Diesel will kick the EGT past the red line
in a flash if I am pulling low rpm and high throttle setting. Drop a
gear or two or three, get the engine and turbo winding and the air
moving through the engine; EGT drops significantly. I know, I know.
It is not a two stroke. Works about the same though, in a lot of
respects.
Can not speak for Beauford's particular 447, but I never had EGT or
CHT problems with mine as long as I left the engine set up like it
came out of the box, PLUS prop the engine so that it will just bump
the red line at WOT straight and level flight. I prop my airplanes
same as I prop my boat, WOT straight heading and bump the red line.
As long as I prop the engine this way, EGT's will be right in the ball
park, and CHT's will remain in the green. This was also true for my
582. With a ground adjustable prop, or a fixed pitch prop, adjusted
this way will give you the best climb and cruise configuration, plus
the engine will also be happy!!!
May not work for everyone, but it has worked for me, very
satisfactorily.
Take care,
PS: If this reply does not make sense it is because I just walked in
the house after 4 days driving 33.5 hours, and 2,211 miles. I am the
new Daddy of a 1936 Farmall F-20. At 4,400 lbs, if it had wings it
would fly too. Was a nice solo trip to Hampton, Iowa, pulling an
empty 20 foot flat bed trailer one way, and hauling the F-20 the
other. Diesel fuel is out of sight. Paid 2.85 a gal when I refueled
the first time for the return trip. Kinda takes the fun out of
burning up the highway.
_________________ John Hauck
hauck's holler, alabama |
