m.tucciarone(at)hotmail.c Guest
Posted: Mon Dec 27, 2010 6:21 am Post subject: engine burping |
I had a guy tell me that his mechanic said that after he flies his plane, he should run the prop through and burp the engine again just like before flight. He said if you don’t do it, oil will collect in the cylinders. Has anyone been told to do this? On my plane my oil tank is above the engine. One time, after not flying the plane for about 2 weeks, I took out a spark plug at the lowest point on the engine. Some oil dripped out. I had not run the prop through first like I would if I was going to start it. Is any of this a problem? The mechanic said it is not good for the oil to be there but I didn’t think it was a problem if you run the prop through to burping before start.
Any thoughts?
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Mon Dec 27, 2010 8:23 am Post subject: Re: engine burping |
m.tucciarone(at)hotmail.c wrote: | I had a guy tell me that his mechanic said that after he flies his plane, he should run the prop through and burp the engine again just like before flight. He said if you don’t do it, oil will collect in the cylinders. Has anyone been told to do this? On my plane my oil tank is above the engine. One time, after not flying the plane for about 2 weeks, I took out a spark plug at the lowest point on the engine. Some oil dripped out. I had not run the prop through first like I would if I was going to start it. Is any of this a problem? The mechanic said it is not good for the oil to be there but I didn’t think it was a problem if you run the prop through to burping before start.
Usually I don't think enough oil collects in the crankcase for this to happen, but I guess that could depend on the installation. If it does, I don't see why not to burp it after the flight.
Is your oil return line in the hole at the lowest point? I.e. if cyls 1-2 are low when the plane is at rest, the oil return line banjo fitting should be in the
hole in the crankcase nearest the gearbox....
But yeah this is familar with any flat four. My VW's would sometimes collect oil in the cylinders if I parked em on the side of a hill....
LS
_________________ LS
Titan II SS |
Posted: Mon Dec 27, 2010 11:25 am Post subject: engine burping |
Yes,
But is it bad if some oil collects there? As I said, I always burp the
engine before start.
Roger Lee
Posted: Mon Dec 27, 2010 11:46 am Post subject: Re: engine burping |
Never ever heard of burping the engine after a flight. Doesn't make any sense.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Mon Dec 27, 2010 11:59 am Post subject: engine burping |
?That is exactly what I thought. I was just wondering if anyone else has
heard of this. I try to keep up with procedures. I have been flying this
912s for about 8 years now and never heard that.
rickofudall
Posted: Mon Dec 27, 2010 12:04 pm Post subject: engine burping |
Is the person making this recommendation an A & P by chance? As Roger said,
it doesn't make any sense. The engine has its own motion to "burp" the
engine while it was running. If it were to collect oil in the crankcase that
quickly after shut down, I'd be suspicious of the condition of the engine or
its installation.
While it's remote, their is one thing that might make burping a hot engine
dangerous. If there were a hot spark plug, i.e. acting like a glow plug, or
a bit of carbon doing the same, the engine could kick back. Like I said the
chances are remote, but they aren't zero.
Rick Girard
On Mon, Dec 27, 2010 at 1:23 PM, Matt Tucciarone
Yes,
rparigoris
Posted: Mon Dec 27, 2010 12:56 pm Post subject: Re: engine burping |
I have heard of folks checking their oil after flight and if OK and as long as they don't see a big puddle under the plane they go flying without checking the oil.
Is it possible that's what was meant?
Ron Parigoris
ronlee
Posted: Mon Dec 27, 2010 6:01 pm Post subject: Re: engine burping |
I can understand burping the engine say ten minuets after shut down. During this time the engine cools and the air in the engine shrinks causing a slight vacuum that can suck oil back into the crankcase. I believe the only reason a person would do that is to get an accurate oil level check.
_________________ Ron Lee
Tucson, Arizona |
Dick Maddux
Posted: Tue Dec 28, 2010 5:24 am Post subject: engine burping |
Matt,
You don't need to burp your engine right after you have run it as the engine has already done that BUT if you have a high oil tank as I do, on my Kitfox, the oil will migrate out of the tank back down into the engine over time. You can slow it down a bit by waiting for the engine to cool and the oil to thicken a bit then burp the engine, I usually do this when I am working on other projects in my hanger and do it later in the day. Then instead of a couple of days before the oil level sinks below the min on the dipstick it might take 4 days (as an example)
This procedure just decreases the number of revolutions you have to give the prop when you first burp the engine because you have less oil to pump back into the oil tank.(but really...whoopdedoo!)
Dick Maddux
912UL
Milton,Fl
Posted: Tue Dec 28, 2010 5:40 am Post subject: engine burping |
Thanks Dick,
I agree with you. The mechanic said that the oil that would get back in the cylinders would be bad for the engine. I disagree and it looks like from the response to my post that you and others disagree also.
Thanks to everyone for their input on this.
Matt
Sent: Tuesday, December 28, 2010 8:19 AM
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
Subject: Re: engine burping
Matt,
Dick Maddux
912UL
Milton,Fl
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List
